[mapguide-users] Problem with Fusion and compound symbols
dan.nilsson dan.nilsson at tyrens.se
Sun Jun 30 05:37:20 PDT 2013
Hi!
I have got the layer to show up in Fusion for MapGuide 2.5, if I do as
follow:
1. I create the layerdefinition in Autodesk Infrastructure Studio. The xml
for the layer looks like this:
      <CompositeTypeStyle>
        <CompositeRule>
          <LegendLabel></LegendLabel>
          <CompositeSymbolization>
            <SymbolInstance>
              <SimpleSymbolDefinition>
                <Name>Circle</Name>
                <Description>Default Point Symbol</Description>
                <Graphics>
                  <Path>
                    <Geometry>M -1,0 A 1,1 0 1 1 1,0 A 1,1 0 1 1
-1,0</Geometry>
                    <ScaleX>%StyleEditorGenerated_ScaleX_0%</ScaleX>
                    <ScaleY>%StyleEditorGenerated_ScaleY_0%</ScaleY>
                    <FillColor>%FILLCOLOR%</FillColor>
                    <LineColor>%LINECOLOR%</LineColor>
                    <LineWeight>%LINEWEIGHT%</LineWeight>
                    <LineCap>%StyleEditorGenerated_LineCap_0%</LineCap>
                    <LineJoin>%StyleEditorGenerated_LineJoin_0%</LineJoin>
                  </Path>
                </Graphics>
                <PointUsage>
                  <Angle>%ROTATION%</Angle>
                </PointUsage>
                <ParameterDefinition>
                  <Parameter>
                    <Identifier>FILLCOLOR</Identifier>
                    <DefaultValue>0xffffffff</DefaultValue>
                    <DisplayName>&Fill Color</DisplayName>
                    <Description>Fill Color</Description>
                    <DataType>FillColor</DataType>
                  </Parameter>
                  <Parameter>
                    <Identifier>LINECOLOR</Identifier>
                    <DefaultValue>0xff000000</DefaultValue>
                    <DisplayName>Line &Color</DisplayName>
                    <Description>Line Color</Description>
                    <DataType>LineColor</DataType>
                  </Parameter>
                  <Parameter>
                    <Identifier>LINEWEIGHT</Identifier>
                    <DefaultValue>0.0</DefaultValue>
                    <DisplayName>Line &Thickness</DisplayName>
                    <Description>Line Thickness</Description>
                    <DataType>LineWeight</DataType>
                  </Parameter>
                  <Parameter>
                    <Identifier>ROTATION</Identifier>
                    <DisplayName>&Rotation</DisplayName>
                    <Description>Rotation</Description>
                    <DataType>Angle</DataType>
                  </Parameter>
                  <Parameter>
                    <Identifier>StyleEditorGenerated_ScaleX_0</Identifier>
                    <DefaultValue>1.0</DefaultValue>
                    <DisplayName>Path ScaleX</DisplayName>
                    <Description>Path ScaleX</Description>
                    <DataType>Real</DataType>
                  </Parameter>
                  <Parameter>
                    <Identifier>StyleEditorGenerated_ScaleY_0</Identifier>
                    <DisplayName>Path ScaleY</DisplayName>
                    <Description>Path ScaleY</Description>
                  </Parameter>
                  <Parameter>
                    <Identifier>StyleEditorGenerated_LineCap_0</Identifier>
                    <DefaultValue>'Round'</DefaultValue>
                    <DisplayName>Line Cap</DisplayName>
                    <Description>The cap type to use at the ends of each
segment in the path outline.  This must evaluate to one of: None, Round
(default), Triangle, or Square.</Description>
                  </Parameter>
                  <Parameter>
                    <Identifier>StyleEditorGenerated_LineJoin_0</Identifier>
                    <DisplayName>Line Join</DisplayName>
                    <Description>The join type to use at each vertex in the
path outline.  This must evaluate to one of: None, Bevel, Round (default),
or Miter.</Description>
                  </Parameter>
                </ParameterDefinition>
              </SimpleSymbolDefinition>
              <ParameterOverrides>
                <Override>
                  <SymbolName>Circle</SymbolName>
                  <ParameterIdentifier>FILLCOLOR</ParameterIdentifier>
                  <ParameterValue>0xffff0000</ParameterValue>
                </Override>
                <Override>
                  <ParameterIdentifier>LINECOLOR</ParameterIdentifier>
                  <ParameterValue>0xff000000</ParameterValue>
                </Override>
                <Override>
                  <ParameterIdentifier>LINEWEIGHT</ParameterIdentifier>
                  <ParameterValue>0.0</ParameterValue>
                </Override>
                <Override>
                  <ParameterIdentifier>ROTATION</ParameterIdentifier>
                </Override>
                <Override>
<ParameterIdentifier>StyleEditorGenerated_ScaleX_0</ParameterIdentifier>
                  <ParameterValue>1000</ParameterValue>
                </Override>
                <Override>
<ParameterIdentifier>StyleEditorGenerated_ScaleY_0</ParameterIdentifier>
                </Override>
                <Override>
<ParameterIdentifier>StyleEditorGenerated_LineCap_0</ParameterIdentifier>
                  <ParameterValue>'Round'</ParameterValue>
                </Override>
                <Override>
<ParameterIdentifier>StyleEditorGenerated_LineJoin_0</ParameterIdentifier>
                </Override>
              </ParameterOverrides>
              <SizeContext>MappingUnits</SizeContext>
              <AddToExclusionRegion>true</AddToExclusionRegion>
              <UsageContext>Point</UsageContext>
              <GeometryContext>Point</GeometryContext>
            </SymbolInstance>
          </CompositeSymbolization>
        </CompositeRule>
      </CompositeTypeStyle>
This doesn't work in Fusion.
2. I edit the XML for the layer in Maestro to look like this instead:
            <SymbolInstance>
                <Name>Circle</Name>
                <Graphics>
                  <Path>
-1,0</Geometry>
                    <ScaleX>1000</ScaleX>
                    <ScaleY>1000</ScaleY>
                    <FillColor>0xffff0000</FillColor>
                    <LineColor>0xff000000</LineColor>
                    <LineWeight>0.0</LineWeight>
                    <LineCap>'Round'</LineCap>
                    <LineJoin>'Round'</LineJoin>
                  </Path>
                </Graphics>
                <PointUsage>
                  <Angle>0</Angle>
                </PointUsage>
            </SymbolInstance>
        </CompositeRule>
Now I can show the layer in Fusion.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-with-Fusion-and-compound-symbols-tp5062756p5063084.html
