[mapguide-users] Only portions of a layer appears at some scales
Berg, James James.Berg at stantec.com
Fri May 10 11:22:42 PDT 2013
Yup, the shp file works perfectly without the join to the SQL table. It won't throw any errors either.
I suppose you could say the problem might with sql table data, but that's been difficult for me to determine. I've made a second table out the shp file's .dbf file to compare them using SQL queries and they seem to match up.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Steve G
Sent: Friday, May 10, 2013 1:18 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Only portions of a layer appears at some scales
Is the shapefile layer visible at all scales without the join to the ODBC feature source?  Any errors?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Only-portions-of-a-layer-appears-at-some-scales-tp5052150p5052631.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
