[mapguide-users] What to write to "Server" slot on "Log on to a MapGuide Server" ?
Laura Kauria lacation at gmail.com
Fri May 24 04:13:04 PDT 2013
Hi!
Thanks for your quick answer!
Sorry, that I have been bit unclear. I have manage to open Maestro with
http://localhost/mapguide/mapagent/mapagent.fcgi (as was in "Introduction
to MapGuide" site in tutorial videos). So this isn´t the problem.
So my question actually was: At this moment I have already downloaded both
Maestro and MapGuide OS 2.5 on both my home computer and the "cloud
computer" (server). Should I operate both MapGuide OS and Maestro in cloud
and use this http://localhost/mapguide/mapagent/mapagent.fcgi OR should I
use Maestro on my home computer and write instead of "localhost" my cloud
server number eg. 87.23x.xx.xx? I know I´m bit lost. Thanks for all help!
Laura
<http://localhost/mapguide/mapagent/mapagent.fcgi>
2013/5/24 Jackie Ng <jumpinjackie at gmail.com>
> When you install MapGuide, you had two pre-defined choices:
>  * Bundled install
>  * IIS install
> Assuming you picked default values, then:
>  * Bundled install installs the Apache Web Server that listens on port 8008
>  * IIS install integrates with your existing IIS Web Server that usually
> listens on port 80
> Thus when connecting with Maestro your server url is either:
>  * Bundled install:
> http://yourservername:8008/mapguide/mapagent/mapagent.fcgi
>  * IIS install: http://yourservername/mapguide/mapagent/mapagent.fcgi
> Username and password the credentials for the MapGuide author/administrator
> account. The default Administrator account login is:
>  * Username: Administrator
>  * Password: admin
> This should be all the information you need to be able to connect with
> Maestro.
> For a production installation, you are strongly advised to change the
> Administrator password.
> Hope that helps.
> - Jackie
> http://osgeo-org.1560.x6.nabble.com/What-to-write-to-Server-slot-on-Log-on-to-a-MapGuide-Server-tp5055461p5055469.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130524/62afa01c/attachment.html>
