[mapguide-users] What to write to "Server" slot on "Log on to a MapGuide Server" ?
Jackie Ng jumpinjackie at gmail.com
Fri May 24 05:25:37 PDT 2013
If you installed MapGuide on the cloud server with the same configuration,
then yes using the cloud server IP address should work.
As to which one to operate? In software development, we have the notion of a
dev/test environment and a production environment. Assuming the cloud server
is your production environment, then I'd say you should do the bulk of your
authoring/development on your localhost where you can experiment and play
around. Then when everything's all right and set, migrate your
data/applications/settings over from your localhost to the cloud server.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/What-to-write-to-Server-slot-on-Log-on-to-a-MapGuide-Server-tp5055461p5055571.html
