[mapguide-users] EPSG:3763 missing in Mapguide Open Source
Ricardo Pinho ricardodepinho at gmail.com
Mon Jan 26 01:31:41 PST 2015
Hi GordonL,
Yes, it seems to require it to be registered even if you define the
Coordinate System with WKT code.
I use the WKT definition below, that if correctly implemented would define
EPSG:3763.
But MG OS simply ignores the EPSG code, when I try to reference it, for
instance on WMS, etc
Cheers,
Ricardo
http://spatialreference.org/ref/epsg/3763/prettywkt/
PROJCS["ETRS89 / Portugal TM06",GEOGCS["ETRS89",
DATUM["European_Terrestrial_Reference_System_1989",
SPHEROID["GRS
1980",6378137,298.2572221010002,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6258"]],
PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4258"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",39.66825833333333],
PARAMETER["central_meridian",-8.133108333333334],
PARAMETER["scale_factor",1],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","3763"]]
2015-01-26 2:15 GMT+00:00 GordonL <gordon.luckett at arrowgeomatics.com>:
> I'm curious, when you put the WKT into your data source, can you use it in
> your map, do it require to be registered?
> <http://osgeo-org.1560.x6.nabble.com/file/n5183660/3763.png>
> http://osgeo-org.1560.x6.nabble.com/EPSG-3763-missing-in-Mapguide-Open-Source-tp5183548p5183660.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Ricardo Pinho
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20150126/521e38ee/attachment.html>
