[mapguide-users] Creating tiled map from untiled
nmicra nisanov.n at gmail.com
Sun Mar 5 11:11:10 PST 2017
I've got untiled map, what is the best way to create a tiled map from the
given map?
I've compared the xmls and found that <MapLayer> in untiled map, was renamed
to <BaseMapLayer>.
And there are <FiniteDisplayScale> parameters in tiled map.
Should I edit xml, manually or there is a better way to achieve this?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Creating-tiled-map-from-untiled-tp5310792.html
