[mapguide-users] Updating Feature Sources without restarting MG
Kajar kajar.kuldsepp at gmail.com
Tue May 9 13:32:16 PDT 2017
I do almost same but using SHP. I wanted to use Sqlite at first, but Autocad
MAP 3d have bug to export to Sqlite using command in command line scripts,
so I was pushed to use SHP. Every night scripts collects information from 80
drawings and creating one SHP from dwg data. So SHP is overwrite the old one
every night.
I'm using connection to SHP not uploading it to repository and for me its
work perfectly.
Maybe you need to use alternative format.
Kajar
View this message in context: http://osgeo-org.1560.x6.nabble.com/Updating-Feature-Sources-without-restarting-MG-tp5319874p5319963.html
