[mapguide-users] Updating Feature Sources without restarting MG
Reservoirdog c.schmidt at relis.ch
Wed May 10 04:07:39 PDT 2017
thx guys for your inputs.
@Jackie, I have to stick to SQLite because of its performance-benefits.
Up to 200MB size, there's quite nothing as fast as (Spatial) SQLites.
Where can I check if SQLite is excluded from Connection Pooling?
Also what I see often, is if I replace a SQLite-File, I cannot see any
Schema-Changes
e.g. when modifying a layer. So it seems, also schema-definition of the
SQLites are somehow cached.
Also here, restart of Mapguide or renaming the file to a new filename fixes
this.
@Kajar, thx for your hints. Unfortunately SHP is not a format, which can
hold much attributive information, you also need one shapefile for each
featureclass which gets unhandy when dealing with
LARGE databases. My SQLites contain 100-200 feature classes.
Something needs to have changed in the SQLite-Provider, as with the old
MG-Versions re-saving the Feature Source was sufficient.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Updating-Feature-Sources-without-restarting-MG-tp5319874p5320030.html
