[MapProxy-dev] MapProxy PSC, RFCs and GitHub PR
Denis Rykov rykovd at gmail.com
Fri May 15 10:29:20 PDT 2020
Hi folks!
I've been using MapProxy for about 8 years in different side projects. It
helped me so much in so many different use cases. I really like its great
architecture, clean code and amazing documentation.
Thanks Oliver for the opportunity to participate in the future of MapProxy.
Denis
On Wed, May 13, 2020 at 2:16 PM Oliver Tonnhofer <olt at omniscale.de> wrote:
> Hi everyone,
> sorry for the slow progress on the PSC.
> I'm happy that we now have a list of seven candidates for the PSC. All of
> you are long time users of MapProxy and most of you also contributed in the
> past. So far we have:
> Denis Rykov
> Johannes Weskamm
> Just van den Broecke
> Matt Walker
> Oliver Tonnhofer
> Ramūnas Dronga
> Tom Kralidis
> Maybe you can all introduce yourself with 2-3 sentences on how you are
> using MapProxy, your affiliation with a company that uses MapProxy, do you
> have any plans within your PSC membership?
> Next step is, that we all agree on the PSC guidelines. Please take a look
> at https://github.com/mapproxy/mapproxy/wiki/PSC-Guidelines which is more
> a less a copy of the guidelines from MapServer, OpenLayers and PyGeoAPI.
> Make sure you all understood the responsibilities:
> https://github.com/mapproxy/mapproxy/wiki/PSC-Guidelines#membership-responsibilities
> The only major change is that I increased the review period from two days
> to five business days. I think two days is quite short. (Minor changes
> aren't affected by the voting process anyways and a revert is just one
> command away.)
> I'm also not sure how we should handle GitHub issues & pull requests? Do
> we want to keep all discussion on this list? Do we want an RFC for each PR?
> Would be it be OK if the PR is the RFC and we only vote on the mailing
> list? Should we just add a PR template [0] and mention that they should
> write to the mailing list if they want to bring this PR forward? (Otherwise
> they would need to wait till one of us is enough interested in the PR to
> make an RFC on their own.)
> I'm quite open to all of these options.
> [0]
> https://help.github.com/en/github/building-a-strong-community/creating-a-pull-request-template-for-your-repository
> Regards,
> Oliver
> Oliver Tonnhofer  | Omniscale GmbH & Co KG  | https://omniscale.com
> OpenStreetMap WMS and tile services         | https://maps.omniscale.com
> MapProxy-dev mailing list
> MapProxy-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapproxy-dev
URL: <http://lists.osgeo.org/pipermail/mapproxy-dev/attachments/20200515/4a23e5e6/attachment.html>
More information about the MapProxy-dev mailing list
