[mapserver-commits] r7826 - trunk/mapserver
Mon Jul 21 14:52:27 EDT 2008
Author: dmorissette
Date: 2008-07-21 14:52:26 -0400 (Mon, 21 Jul 2008)
New Revision: 7826
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapogr.cpp
Several enhancements to STYLEITEM AUTO support for labels in OGR layers
(#2708)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-07-17 21:14:10 UTC (rev 7825)
+++ trunk/mapserver/HISTORY.TXT	2008-07-21 18:52:26 UTC (rev 7826)
@@ -10,15 +10,20 @@
 For a complete change history, please see the Subversion log comments.
 Current Version (5.3-dev, SVN trunk):
+- Several enhancements to STYLEITEM AUTO support for labels in OGR
+  layers (#2708)
 Version 5.2.0 (2008-07-16):
-- mapfile.c: Fixed a bug that prevented using named symbols via URL configuration. (#2700)
+- mapfile.c: Fixed a bug that prevented using named symbols via URL
+  configuration. (#2700)
 Version 5.2.0-rc1 (2008-07-09):
 - mapowscommon.c: fix support multiple namespaces (#2690)
@@ -78,7 +83,8 @@
 - mapsde.c: Test for an active connection before closing it (#2498).
-- mapdraw.c: Fixed issue where path following labels were not being drawn if FORCEd. (#2600)
+- mapdraw.c: Fixed issue where path following labels were not being drawn
+  if FORCEd. (#2600)
 - mapshape.c: Applied patch to make the location of tiled data relative to the
   tileindex directory if SHAPEPATH is not set. (#2369)
Modified: trunk/mapserver/mapogr.cpp
--- trunk/mapserver/mapogr.cpp	2008-07-17 21:14:10 UTC (rev 7825)
+++ trunk/mapserver/mapogr.cpp	2008-07-21 18:52:26 UTC (rev 7826)
@@ -2212,29 +2212,70 @@
               if (!bIsNull && OGR_ST_GetRGBFromString(hLabelStyle, pszColor,
                                                       &r, &g, &b, &t))
-                  MS_INIT_COLOR(c->label.color, r, g, b);
+                  MS_INIT_COLOR(c->label.backgroundcolor, r, g, b);
+              pszColor = OGR_ST_GetParamStr(hLabelStyle,
+                                            OGRSTLabelHColor,
+                                            &bIsNull);
+              if (!bIsNull && OGR_ST_GetRGBFromString(hLabelStyle, pszColor,
+                                                      &r, &g, &b, &t))
+                  MS_INIT_COLOR(c->label.shadowcolor, r, g, b);
+#if GDAL_VERSION_NUM >= 1600
+                                            OGRSTLabelOColor,
+                                            &bIsNull);
+                                                      &r, &g, &b, &t))
+                  MS_INIT_COLOR(c->label.outlinecolor, r, g, b);
+#endif /* GDAL_VERSION_NUM >= 1600 */
               // Label font... do our best to use TrueType fonts, otherwise
               // fallback on bitmap fonts.
 #if defined(USE_GD_TTF) || defined (USE_GD_FT)
-              const char *pszName = OGR_ST_GetParamStr(hLabelStyle,
-                                                       OGRSTLabelFontName,
-                                                       &bIsNull);
-              if (pszName != NULL && !bIsNull && pszName[0] != '\0' &&
-                  msLookupHashTable(&(map->fontset.fonts), (char*)pszName) != NULL)
+              const char *pszBold = OGR_ST_GetParamNum(hLabelStyle,
+                                                           OGRSTLabelBold,
+                                                           &bIsNull) ? "-bold" : "";
+              const char *pszItalic = OGR_ST_GetParamNum(hLabelStyle,
+                                                           OGRSTLabelItalic,
+                                                           &bIsNull) ? "-italic" : "";
+              const char *pszFontName = OGR_ST_GetParamStr(hLabelStyle,
+                                                           OGRSTLabelFontName,
+                                                           &bIsNull);
+              const char *pszName = CPLSPrintf("%s%s%s", pszFontName, pszBold, pszItalic);
+              bool bFont = true;
+              if (pszFontName != NULL && !bIsNull && pszFontName[0] != '\0')
-                  c->label.type = MS_TRUETYPE;
-                  c->label.font = strdup(pszName);
-                  // msDebug("** Using '%s' TTF font **\n", pszName);
+                  if (msLookupHashTable(&(map->fontset.fonts), (char*)pszName) != NULL)
+                      c->label.type = MS_TRUETYPE;
+                      c->label.font = strdup(pszName);
+                      // msDebug("** Using '%s' TTF font **\n", pszName);
+                  else if ( (strcmp(pszFontName,pszName) != 0) &&
+                            msLookupHashTable(&(map->fontset.fonts), (char*)pszFontName) != NULL)
+                      c->label.font = strdup(pszFontName);
+                      // msDebug("** Using '%s' TTF font **\n", pszFontName);
+                  else if (msLookupHashTable(&(map->fontset.fonts),"default") != NULL)
+                      c->label.font = strdup("default");
+                      // msDebug("** Using 'default' TTF font **\n");
+                  else
+                      bFont = false;
-              else if (msLookupHashTable(&(map->fontset.fonts),"default") != NULL)
-                  c->label.font = strdup("default");
-                  // msDebug("** Using 'default' TTF font **\n");
-              else
+              if (!bFont)
 #endif /* USE_GD_FT || USE_GD_FT */
                   c->label.type = MS_BITMAP;
@@ -2270,27 +2311,50 @@
               pszColor = poLabelStyle->BackColor(bIsNull);
               if (!bIsNull && poLabelStyle->GetRGBFromString(pszColor,r,g,b,t))
+              pszColor = poLabelStyle->ShadowColor(bIsNull);
+              if (!bIsNull && poLabelStyle->GetRGBFromString(pszColor,r,g,b,t))
-              const char *pszName = poLabelStyle->FontName(bIsNull);
+              const char *pszBold = poLabelStyle->Bold(bIsNull)  ? "-bold" : "";
+              const char *pszItalic = poLabelStyle->Italic(bIsNull) ? "-italic" : "";
+              const char *pszFontName = poLabelStyle->FontName(bIsNull);
+                  else
+                      bFont = false;
-              else
+              if (!bFont)
