[mapserver-commits] r7827 - trunk/mapserver
Tue Jul 22 11:05:45 EDT 2008
Author: dmorissette
Date: 2008-07-22 11:05:45 -0400 (Tue, 22 Jul 2008)
New Revision: 7827
   trunk/mapserver/configure
   trunk/mapserver/configure.in
Stop configure execution with an error if path to one of the -config scripts is invalid (#2710)
Modified: trunk/mapserver/configure
--- trunk/mapserver/configure	2008-07-21 18:52:26 UTC (rev 7826)
+++ trunk/mapserver/configure	2008-07-22 15:05:45 UTC (rev 7827)
@@ -1419,7 +1419,7 @@
   --without-tiff          Disable TIFF support.
   --with-tiff[=DIR]       Include TIFF support (DIR is LibTIFF's install dir).
   --with-postgis[=ARG]    Include PostGIS Support (ARG=yes/path to pg_config)
-  --with-mygis[=ARG]      Include MyGIS Support (ARG=yes/path to my_config)
+  --with-mygis[=ARG]      Include MyGIS Support (ARG=yes/path to mysql_config)
   --with-oraclespatial[=ARG] Include OracleSpatial Support (ARG=yes/path to
                           Oracle home)
   --with-ming[=DIR]       Include MING/Flash Support (DIR=path to Ming
@@ -11255,8 +11255,15 @@
   POSTGIS_INC=
   POSTGIS_LIB=
 else
-  { echo "$as_me:$LINENO: result: yes, user supplied pg_config" >&5
-echo "${ECHO_T}yes, user supplied pg_config" >&6; }
+  if test -f "$PG_CONFIG" -a -x "$PG_CONFIG" ; then
+    { echo "$as_me:$LINENO: result: yes, user supplied pg_config ($PG_CONFIG)" >&5
+echo "${ECHO_T}yes, user supplied pg_config ($PG_CONFIG)" >&6; }
+  else
+    { { echo "$as_me:$LINENO: error: '$PG_CONFIG' is not an executable.  Make sure you use --with-postgis=/path/to/pg_config" >&5
+echo "$as_me: error: '$PG_CONFIG' is not an executable.  Make sure you use --with-postgis=/path/to/pg_config" >&2;}
+   { (exit 1); exit 1; }; }
+  fi
   POSTGIS_ENABLED=-DUSE_POSTGIS
   POSTGIS_LIB="-L`$PG_CONFIG --libdir` -lpq"
   POSTGIS_INC="-I`$PG_CONFIG --includedir`"
@@ -11341,8 +11348,15 @@
   MYGIS_INC=
   MYGIS_LIB=
 else
-  { echo "$as_me:$LINENO: result: yes, user supplied my_config" >&5
-echo "${ECHO_T}yes, user supplied my_config" >&6; }
+  if test -f "$MY_CONFIG" -a -x "$MY_CONFIG" ; then
+    { echo "$as_me:$LINENO: result: yes, user supplied mysql_config ($MY_CONFIG)" >&5
+echo "${ECHO_T}yes, user supplied mysql_config ($MY_CONFIG)" >&6; }
+  else
+    { { echo "$as_me:$LINENO: error: '$MY_CONFIG' is not an executable.  Make sure you use --with-mygis=/path/to/mysql_config" >&5
+echo "$as_me: error: '$MY_CONFIG' is not an executable.  Make sure you use --with-mygis=/path/to/mysql_config" >&2;}
+  fi
   MYGIS_ENABLED=-DUSE_MYGIS
   MYGIS_LIB="`$MY_CONFIG --libs` -lmysqlclient"
 #  MYGIS_LIB="-L/usr/lib/mysql -lmysqlclient"
@@ -11674,8 +11688,8 @@
 fi
-{ echo "$as_me:$LINENO: checking for curl-config..." >&5
-echo "$as_me: checking for curl-config..." >&6;}
+{ echo "$as_me:$LINENO: checking for curl-config" >&5
+echo $ECHO_N "checking for curl-config... $ECHO_C" >&6; }
 # Check whether --with-curl-config was given.
 if test "${with_curl_config+set}" = set; then
@@ -11689,6 +11703,14 @@
   if test "`basename xx/$with_curl_config`" = "curl-config" ; then
     LIBCURL_CONFIG="$with_curl_config"
+    if test -f "$LIBCURL_CONFIG" -a -x "$LIBCURL_CONFIG" ; then
+      { echo "$as_me:$LINENO: result: yes, user supplied curl-config ($LIBCURL_CONFIG)" >&5
+echo "${ECHO_T}yes, user supplied curl-config ($LIBCURL_CONFIG)" >&6; }
+    else
+      { { echo "$as_me:$LINENO: error: '$LIBCURL_CONFIG' is not an executable.  Make sure you use --with-curl-config=/path/to/curl-config" >&5
+echo "$as_me: error: '$LIBCURL_CONFIG' is not an executable.  Make sure you use --with-curl-config=/path/to/curl-config" >&2;}
+    fi
   else
     # Extract the first word of "curl-config", so it can be a program name with args.
 set dummy curl-config; ac_word=$2
@@ -11810,15 +11832,20 @@
     { echo "$as_me:$LINENO: result: libxml2 not required." >&5
 echo "${ECHO_T}libxml2 not required." >&6; }
   fi
-else
-  { echo "$as_me:$LINENO: result: --with-xml2-config=$with_xml2_config specified." >&5
-echo "${ECHO_T}--with-xml2-config=$with_xml2_config specified." >&6; }
 fi
 if test "$with_xml2_config" != "no" ; then
   if test "`basename xx/$with_xml2_config`" = "xml2-config" ; then
     LIBXML2_CONFIG="$with_xml2_config"
+    if test -f "$LIBXML2_CONFIG" -a -x "$LIBXML2_CONFIG" ; then
+      { echo "$as_me:$LINENO: result: yes, user supplied xml2-config ($LIBXML2_CONFIG)" >&5
+echo "${ECHO_T}yes, user supplied xml2-config ($LIBXML2_CONFIG)" >&6; }
+    else
+      { { echo "$as_me:$LINENO: error: '$LIBXML2_CONFIG' is not an executable.  Make sure you use --with-xml2-config=/path/to/xml2-config" >&5
+echo "$as_me: error: '$LIBXML2_CONFIG' is not an executable.  Make sure you use --with-xml2-config=/path/to/xml2-config" >&2;}
+    fi
   else
     # Extract the first word of "xml2-config", so it can be a program name with args.
 set dummy xml2-config; ac_word=$2
@@ -11993,8 +12020,14 @@
      FRIBIDI_LIB=`$PKG_CONFIG --libs $FRIBIDI_CONFIG`
      FRIBIDI_INC=`$PKG_CONFIG --cflags $FRIBIDI_CONFIG`
   else
-     { echo "$as_me:$LINENO: result: yes, user supplied fribidi-config" >&5
-echo "${ECHO_T}yes, user supplied fribidi-config" >&6; }
+     if test -f "$FRIBIDI_CONFIG" -a -x "$FRIBIDI_CONFIG" ; then
+       { echo "$as_me:$LINENO: result: yes, user supplied fribidi-config ($FRIBIDI_CONFIG)" >&5
+echo "${ECHO_T}yes, user supplied fribidi-config ($FRIBIDI_CONFIG)" >&6; }
+     else
+       { { echo "$as_me:$LINENO: error: '$FRIBIDI_CONFIG' is not an executable.  Make sure you use --with-fribidi-config=/path/to/fribidi-config or fribidi.pc" >&5
+echo "$as_me: error: '$FRIBIDI_CONFIG' is not an executable.  Make sure you use --with-fribidi-config=/path/to/fribidi-config or fribidi.pc" >&2;}
+     fi
      FRIBIDI_ENABLED=-DUSE_FRIBIDI
      FRIBIDI_LIB=`$FRIBIDI_CONFIG --libs`
      FRIBIDI_INC=`$FRIBIDI_CONFIG --cflags`
Modified: trunk/mapserver/configure.in
--- trunk/mapserver/configure.in	2008-07-21 18:52:26 UTC (rev 7826)
+++ trunk/mapserver/configure.in	2008-07-22 15:05:45 UTC (rev 7827)
@@ -1455,7 +1455,12 @@
   POSTGIS_INC=
   POSTGIS_LIB=
 else
-  AC_MSG_RESULT([yes, user supplied pg_config])
+    AC_MSG_RESULT([yes, user supplied pg_config ($PG_CONFIG)])
+  else
+    AC_MSG_ERROR(['$PG_CONFIG' is not an executable.  Make sure you use --with-postgis=/path/to/pg_config])
+  fi
@@ -1475,7 +1480,7 @@
 AC_MSG_CHECKING(if MyGIS support requested)
-AC_ARG_WITH(mygis,[  --with-mygis[[=ARG]]      Include MyGIS Support (ARG=yes/path to my_config)],,)
+AC_ARG_WITH(mygis,[  --with-mygis[[=ARG]]      Include MyGIS Support (ARG=yes/path to mysql_config)],,)
 if test "$with_mygis" = "no" -o "$with_mygis" = "" ; then
   AC_MSG_RESULT(no)
@@ -1492,7 +1497,12 @@
   MYGIS_INC=
   MYGIS_LIB=
 else
-  AC_MSG_RESULT([yes, user supplied my_config])
+    AC_MSG_RESULT([yes, user supplied mysql_config ($MY_CONFIG)])
+  else
+    AC_MSG_ERROR(['$MY_CONFIG' is not an executable.  Make sure you use --with-mygis=/path/to/mysql_config])
+  fi
@@ -1769,7 +1779,7 @@
 dnl Look for libcurl if WMS and WFS Client requested
 dnl ---------------------------------------------------------------------
-AC_CHECKING(for curl-config)
+AC_MSG_CHECKING(for curl-config)
 AC_ARG_WITH(curl-config,
 [  --with-curl-config=PATH Specify path to curl-config.],,)
@@ -1780,6 +1790,11 @@
+      AC_MSG_RESULT([yes, user supplied curl-config ($LIBCURL_CONFIG)])
+    else
+      AC_MSG_ERROR(['$LIBCURL_CONFIG' is not an executable.  Make sure you use --with-curl-config=/path/to/curl-config])
+    fi
   else
     AC_PATH_PROG(LIBCURL_CONFIG, curl-config, no)
   fi
@@ -1851,14 +1866,17 @@
     with_xml2_config=no
     AC_MSG_RESULT([libxml2 not required.])
   fi
-else
-  AC_MSG_RESULT([--with-xml2-config=$with_xml2_config specified.])
 fi
+      AC_MSG_RESULT([yes, user supplied xml2-config ($LIBXML2_CONFIG)])
+    else
+      AC_MSG_ERROR(['$LIBXML2_CONFIG' is not an executable.  Make sure you use --with-xml2-config=/path/to/xml2-config])
+    fi
   else
     AC_PATH_PROG(LIBXML2_CONFIG, xml2-config, no)
   fi
@@ -1941,7 +1959,11 @@
   else
-     AC_MSG_RESULT([yes, user supplied fribidi-config])
+       AC_MSG_RESULT([yes, user supplied fribidi-config ($FRIBIDI_CONFIG)])
+     else
+       AC_MSG_ERROR(['$FRIBIDI_CONFIG' is not an executable.  Make sure you use --with-fribidi-config=/path/to/fribidi-config or fribidi.pc])
+     fi
