[mapserver-commits] r7457 - trunk/mapserver
Mon Mar 17 14:44:51 EDT 2008
Author: dmorissette
Date: 2008-03-17 14:44:51 -0400 (Mon, 17 Mar 2008)
New Revision: 7457
   trunk/mapserver/Makefile.in
   trunk/mapserver/configure
   trunk/mapserver/configure.in
   trunk/mapserver/maperror.c
   trunk/mapserver/mapstring.c
Added FriBidi for left-to-right label support, e.g. Hebrew (#956)
Modified: trunk/mapserver/Makefile.in
--- trunk/mapserver/Makefile.in	2008-03-14 12:28:06 UTC (rev 7456)
+++ trunk/mapserver/Makefile.in	2008-03-17 18:44:51 UTC (rev 7457)
@@ -162,6 +162,12 @@
 CURL_INC=@CURL_INC@
 CURL_LIB=@CURL_LIB@
+# libfribibi ...
+FRIBIDI=@FRIBIDI_ENABLED@
+FRIBIDI_INC=@FRIBIDI_INC@
+FRIBIDI_LIB=@FRIBIDI_LIB@
 # libxml2 ... required for OGC SOS Server
 XML2_INC=@XML2_INC@
 XML2_LIB=@XML2_LIB@
@@ -224,12 +230,12 @@
 XTRALIBS= @XTRALIBS@
 RUNPATHS= @RPATHS@
-DEFINES = $(IGNORE_MISSING_DATA) $(USE_POINT_Z_M) $(STRINGS) @ALL_ENABLED@
+DEFINES = $(IGNORE_MISSING_DATA) $(USE_POINT_Z_M) $(STRINGS) @ALL_ENABLED@ $(FRIBIDI)
 INCLUDES = $(REGEX_INC) $(PNG_INC) $(GD_INC) $(AGG_INC) $(PDF_INC) $(PROJ_INC) $(TIFF_INC) $(JPEG_INC) $(EGIS_INC) \
         $(SDE_INC) $(GDAL_INC) $(POSTGIS_INC) $(MYGIS_INC) \
         $(CURL_INC) $(MING_INC) $(ORACLESPATIAL_INC) $(GEOS_INC) $(ICONV_INC) \
-        $(FASTCGI_INC) $(ZLIB_INC) $(XML2_INC)
+        $(FASTCGI_INC) $(ZLIB_INC) $(XML2_INC) $(FRIBIDI_INC)
 FLAGS = @DEBUG_FLAGS@ $(DEFINES) $(INCLUDES)
@@ -241,7 +247,7 @@
           $(JPEG_LIB) $(PNG_LIB) $(SDE_LIB) $(GDAL_LIB) $(MING_LIB) $(POSTGIS_LIB) \
 	  $(MYGIS_LIB) $(CURL_LIB) $(ORACLESPATIAL_LIB) $(GEOS_LIB) \
 	  $(THREAD_LIB) $(ICONV_LIB) $(FASTCGI_LIB) \
-	  $(ZLIB_LIB) $(XML2_LIB) $(XTRALIBS)
+	  $(ZLIB_LIB) $(XML2_LIB) $(FRIBIDI_LIB) $(XTRALIBS)
 # STATIC_LIBS is full filename with path of libs that will be statically linked
 STATIC_LIBS= $(GD_STATIC)
Modified: trunk/mapserver/configure
--- trunk/mapserver/configure	2008-03-14 12:28:06 UTC (rev 7456)
+++ trunk/mapserver/configure	2008-03-17 18:44:51 UTC (rev 7457)
@@ -742,6 +742,10 @@
 LIBCURL_CONFIG
 CURL_INC
 CURL_LIB
+FRIBIDI_CONFIG
+FRIBIDI_ENABLED
+FRIBIDI_INC
+FRIBIDI_LIB
 LIBXML2_CONFIG
 XML2_INC
 XML2_LIB
@@ -1428,6 +1432,8 @@
   --with-sos              Enable OGC SOS Server Support (libxml2 and PROJ4 and
                           OGR required).
   --with-curl-config=PATH Specify path to curl-config.
+  --with-fribidi-config[=ARG] Include FriBidi Support (ARG=yes/path to
+                          fribidi-config)
   --with-xml2-config=PATH Specify path to xml2-config.
   --with-fastcgi=path     Enable FastCGI, point to installed tree.
   --with-httpd            Specify path to 'httpd' executable.
@@ -11474,6 +11480,92 @@
+{ echo "$as_me:$LINENO: checking if FriBidi support requested" >&5
+echo $ECHO_N "checking if FriBidi support requested... $ECHO_C" >&6; }
+# Check whether --with-fribidi-config was given.
+if test "${with_fribidi_config+set}" = set; then
+  withval=$with_fribidi_config;
+fi
+if test "$with_fribidi_config" = "no" -o "$with_fribidi_config" = "" ; then
+  { echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6; }
+  FRIBIDI_CONFIG="no"
+elif test "$with_fribidi_config" = "yes" ; then
+  { echo "$as_me:$LINENO: result: yes" >&5
+echo "${ECHO_T}yes" >&6; }
+  # Extract the first word of "fribidi-config", so it can be a program name with args.
+set dummy fribidi-config; ac_word=$2
+{ echo "$as_me:$LINENO: checking for $ac_word" >&5
+echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6; }
+if test "${ac_cv_path_FRIBIDI_CONFIG+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  case $FRIBIDI_CONFIG in
+  ac_cv_path_FRIBIDI_CONFIG="$FRIBIDI_CONFIG" # Let the user override the test with a path.
+  as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+for as_dir in $PATH
+do
+  IFS=$as_save_IFS
+  test -z "$as_dir" && as_dir=.
+  for ac_exec_ext in '' $ac_executable_extensions; do
+  if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then
+    ac_cv_path_FRIBIDI_CONFIG="$as_dir/$ac_word$ac_exec_ext"
+    echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5
+    break 2
+  fi
+done
+done
+IFS=$as_save_IFS
+  test -z "$ac_cv_path_FRIBIDI_CONFIG" && ac_cv_path_FRIBIDI_CONFIG="no"
+esac
+fi
+FRIBIDI_CONFIG=$ac_cv_path_FRIBIDI_CONFIG
+if test -n "$FRIBIDI_CONFIG"; then
+  { echo "$as_me:$LINENO: result: $FRIBIDI_CONFIG" >&5
+echo "${ECHO_T}$FRIBIDI_CONFIG" >&6; }
+else
+fi
+else
+  FRIBIDI_CONFIG=$with_fribidi_config
+fi
+if test "$FRIBIDI_CONFIG" = "no" ; then
+  FRIBIDI_ENABLED=
+  FRIBIDI_INC=
+  FRIBIDI_LIB=
+else
+  { echo "$as_me:$LINENO: result: yes, user supplied fribidi-config" >&5
+echo "${ECHO_T}yes, user supplied fribidi-config" >&6; }
+  FRIBIDI_ENABLED=-DUSE_FRIBIDI
+  FRIBIDI_LIB=`$FRIBIDI_CONFIG --libs`
+  FRIBIDI_INC=`$FRIBIDI_CONFIG --cflags`
+fi
+FRIBIDI_ENABLED=$FRIBIDI_ENABLED
+FRIBIDI_INC=$FRIBIDI_INC
+FRIBIDI_LIB=$FRIBIDI_LIB
+ALL_ENABLED="$FRIBIDI_ENABLED $ALL_ENABLED"
+ALL_INC="$FRIBIDI_INC $ALL_INC"
+ALL_LIB="$FRIBIDI_LIB $ALL_LIB"
 { echo "$as_me:$LINENO: checking for libxml2" >&5
 echo $ECHO_N "checking for libxml2... $ECHO_C" >&6; }
@@ -13486,6 +13578,10 @@
 LIBCURL_CONFIG!$LIBCURL_CONFIG$ac_delim
 CURL_INC!$CURL_INC$ac_delim
 CURL_LIB!$CURL_LIB$ac_delim
+FRIBIDI_CONFIG!$FRIBIDI_CONFIG$ac_delim
+FRIBIDI_ENABLED!$FRIBIDI_ENABLED$ac_delim
+FRIBIDI_INC!$FRIBIDI_INC$ac_delim
+FRIBIDI_LIB!$FRIBIDI_LIB$ac_delim
 LIBXML2_CONFIG!$LIBXML2_CONFIG$ac_delim
 XML2_INC!$XML2_INC$ac_delim
 XML2_LIB!$XML2_LIB$ac_delim
@@ -13526,7 +13622,7 @@
 LTLIBOBJS!$LTLIBOBJS$ac_delim
 _ACEOF
-  if test `sed -n "s/.*$ac_delim\$/X/p" conf$$subs.sed | grep -c X` = 70; then
+  if test `sed -n "s/.*$ac_delim\$/X/p" conf$$subs.sed | grep -c X` = 74; then
     break
   elif $ac_last_try; then
     { { echo "$as_me:$LINENO: error: could not make $CONFIG_STATUS" >&5
@@ -13903,6 +13999,8 @@
 echo "${ECHO_T}  Proj.4 support:            ${PROJ_ENABLED}" >&6; }
 { echo "$as_me:$LINENO: result:   Libxml2 support:           ${XML2_ENABLED}" >&5
 echo "${ECHO_T}  Libxml2 support:           ${XML2_ENABLED}" >&6; }
+{ echo "$as_me:$LINENO: result:   FriBidi support:           ${FRIBIDI_ENABLED}" >&5
+echo "${ECHO_T}  FriBidi support:           ${FRIBIDI_ENABLED}" >&6; }
 { echo "$as_me:$LINENO: result:   Curl support:              ${CURL_ENABLED}" >&5
 echo "${ECHO_T}  Curl support:              ${CURL_ENABLED}" >&6; }
 { echo "$as_me:$LINENO: result:   FastCGI support:           ${FASTCGI_ENABLED}" >&5
Modified: trunk/mapserver/configure.in
--- trunk/mapserver/configure.in	2008-03-14 12:28:06 UTC (rev 7456)
+++ trunk/mapserver/configure.in	2008-03-17 18:44:51 UTC (rev 7457)
@@ -1787,6 +1787,45 @@
 ALL_LIB="$CURL_LIB $ALL_LIB"
+dnl ---------------------------------------------------------------------------
+dnl Try to find FriBidi if FriBidi support requested.
+AC_MSG_CHECKING(if FriBidi support requested)
+AC_ARG_WITH(fribidi-config,
+[  --with-fribidi-config[[=ARG]] Include FriBidi Support (ARG=yes/path to
+                          fribidi-config)],,)
+  AC_MSG_RESULT(no)
+  AC_MSG_RESULT(yes)
+  AC_PATH_PROG(FRIBIDI_CONFIG, fribidi-config, no)
+else
+fi
+  FRIBIDI_ENABLED=
+  FRIBIDI_INC=
+  FRIBIDI_LIB=
+else
+  AC_MSG_RESULT([yes, user supplied fribidi-config])
+fi
+AC_SUBST(FRIBIDI_ENABLED,$FRIBIDI_ENABLED)
+AC_SUBST(FRIBIDI_INC,$FRIBIDI_INC)
+AC_SUBST(FRIBIDI_LIB,$FRIBIDI_LIB)
 dnl Look for libxml2 if SOS Server requested
@@ -2431,6 +2470,7 @@
 AC_MSG_RESULT([ -------------- Support Libraries --------- ])
 AC_MSG_RESULT([  Proj.4 support:            ${PROJ_ENABLED}])
 AC_MSG_RESULT([  Libxml2 support:           ${XML2_ENABLED}])
+AC_MSG_RESULT([  FriBidi support:           ${FRIBIDI_ENABLED}])
 AC_MSG_RESULT([  Curl support:              ${CURL_ENABLED}])
 AC_MSG_RESULT([  FastCGI support:           ${FASTCGI_ENABLED}])
 AC_MSG_RESULT([  Threading support:         ${THREAD_FLAG}])
Modified: trunk/mapserver/maperror.c
--- trunk/mapserver/maperror.c	2008-03-14 12:28:06 UTC (rev 7456)
+++ trunk/mapserver/maperror.c	2008-03-17 18:44:51 UTC (rev 7457)
@@ -505,6 +505,12 @@
 #ifdef USE_GD_FT
   strcat(version, " SUPPORTS=FREETYPE");
 #endif
+#ifdef USE_ICONV
+  strcat(version, " SUPPORTS=ICONV");
+#endif
+#ifdef USE_FRIBIDI
+  strcat(version, " SUPPORTS=FRIBIDI");
+#endif
 #ifdef USE_WMS_SVR
   strcat(version, " SUPPORTS=WMS_SERVER");
 #endif
Modified: trunk/mapserver/mapstring.c
--- trunk/mapserver/mapstring.c	2008-03-14 12:28:06 UTC (rev 7456)
+++ trunk/mapserver/mapstring.c	2008-03-17 18:44:51 UTC (rev 7457)
@@ -34,6 +34,11 @@
 #include <ctype.h>
+#ifdef USE_FRIBIDI
+#include <fribidi/fribidi.h>
+#define MAX_STR_LEN 65000
+#endif
 #ifdef USE_ICONV
 #include <iconv.h>
 #include <wchar.h>
@@ -1063,6 +1068,103 @@
+** Use FRIBIDI to encode the string.
+** The return value must be freed by the caller.
+#ifdef USE_FRIBIDI
+char *msGetFriBidiEncodedString(const char *string, const char *encoding)
+  FriBidiChar logical[MAX_STR_LEN];
+  FriBidiCharType base = FRIBIDI_TYPE_ON;
+  size_t len;
+#ifdef FRIBIDI_NO_CHARSETS
+  iconv_t to_ucs4, from_ucs4;
+#else
+  int to_char_set_num;
+  int from_char_set_num;
+#endif
+  len = strlen(string);
+  to_ucs4 = iconv_open ("WCHAR_T", encoding);
+  from_ucs4 = iconv_open ("UTF-8", "WCHAR_T");
+#else
+  to_char_set_num = fribidi_parse_charset ((char*)encoding);
+  from_char_set_num = fribidi_parse_charset ("UTF-8");
+#endif
+  if (to_ucs4 == (iconv_t) (-1) || from_ucs4 == (iconv_t) (-1))
+#else
+  if (!to_char_set_num || !from_char_set_num)
+#endif
+    msSetError(MS_IDENTERR, "Encoding not supported (%s).",
+               "msGetFriBidiEncodedString()", encoding);
+    return NULL;
+    char *st = string, *ust = (char *) logical;
+    int in_len = (int) len;
+    len = sizeof logical;
+    iconv (to_ucs4, &st, &in_len, &ust, (int *) &len);
+    len = (FriBidiChar *) ust - logical;
+#else
+  len = fribidi_charset_to_unicode (to_char_set_num, (char*)string, len, logical);
+#endif
+    FriBidiChar *visual;
+    char outstring[MAX_STR_LEN];
+    FriBidiStrIndex *ltov, *vtol;
+    FriBidiLevel *levels;
+    FriBidiStrIndex new_len;
+    fribidi_boolean log2vis;
+    visual = (FriBidiChar *) malloc (sizeof (FriBidiChar) * (len + 1));
+    ltov = NULL;
+    vtol = NULL;
+    levels = NULL;
+    /* Create a bidi string. */
+    log2vis = fribidi_log2vis (logical, len, &base,
+       /* output */
+       visual, ltov, vtol, levels);
+    if (!log2vis) {
+      msSetError(MS_IDENTERR, "Failed to create bidi string.",
+             "msGetFriBidiEncodedString()");
+      return NULL;
+    new_len = len;
+    /* Convert it to utf-8 for display. */
+      char *str = outstring, *ust = (char *) visual;
+      int in_len = len * sizeof visual[0];
+      new_len = sizeof outstring;
+      iconv (from_ucs4, &ust, &in_len, &str, (int *) &new_len);
+      *str = '\0';
+      new_len = str - outstring;
+#else
+     new_len =
+       fribidi_unicode_to_charset (from_char_set_num,
+           visual, len, outstring);
+#endif
+     return strdup(outstring);
+#endif
 ** Simple charset converter. Converts string from specified encoding to UTF-8.
@@ -1074,6 +1176,10 @@
   char *outp, *out = NULL;
   size_t len, bufsize, bufleft, status;
+#ifdef USE_FRIBIDI
+  if(fribidi_parse_charset ((char*)encoding))
+    return msGetFriBidiEncodedString(string, encoding);
+#endif
   if (len == 0 || (encoding && strcasecmp(encoding, "UTF-8")==0))
