[mapserver-commits] r7464 - trunk/docs/references/cgi
Wed Mar 19 15:45:25 EDT 2008
Author: jmckenna
Date: 2008-03-19 15:45:25 -0400 (Wed, 19 Mar 2008)
New Revision: 7464
   trunk/docs/references/cgi/introduction.txt
added small note on 5.0 changes
Modified: trunk/docs/references/cgi/introduction.txt
--- trunk/docs/references/cgi/introduction.txt	2008-03-19 15:30:41 UTC (rev 7463)
+++ trunk/docs/references/cgi/introduction.txt	2008-03-19 19:45:25 UTC (rev 7464)
@@ -1,28 +1,36 @@
- Notes
+Notes
-    *  Variable names are not case sensitive.
-    *  In cases where multiple values are associated with a variable (eg.
-       mapext), the values must be seperated by spaces (or their escaped
-       equivalents for GET requests).
-    *  Variable contents are checked for appropriate data types and magnitude
-       as they are loaded.
-    *  Any CGI Variable not listed below is simply stored and can be
-       referenced within a template file.
+*  Variable names are not case sensitive.
+*  In cases where multiple values are associated with a variable (eg.
+   mapext), the values must be seperated by spaces (or their escaped
+   equivalents for GET requests).
+*  Variable contents are checked for appropriate data types and magnitude
+   as they are loaded.
+*  Any CGI Variable not listed below is simply stored and can be
+   referenced within a template file.
- Changes
-This section lists changes in move from MapServer version 3.x to version 4.x:
+Changes
-    *  New way to perform attribute queries: No longer do you set a layer
-       filter, but rather you pass a query string (and optionally an query
-       item) to the query function. To do this 2 new CGI parameters were
-       added to MapServer: QSTRING and QITEM.
-    *  SAVEMAP is switched off: The SAVEMAP functionality is considered
-       insecure, since the saved files are accessible by everyone.
-    *  TEMPLATE has been removed, since the map_web_template syntax can be
-       used to alter a template file. Simplifies security maintenance by only
-       having to deal with this option in a single place. Note that the
-       TEMPLATEPATTERN of the mapfile has to be used to enable this feature.
\ No newline at end of file
+From MapServer version 4.x to version 5.x
+*  Modifying map parameters through a URL has changed to allow for
+   chunks of a mapfile to be modified at once.  The syntax has changed
+   accordingly, so please see the *Changing map file parameters via a form or a URL*
+   section.
+From MapServer version 3.x to version 4.x
+*  New way to perform attribute queries: No longer do you set a layer
+   filter, but rather you pass a query string (and optionally an query
+   item) to the query function. To do this 2 new CGI parameters were
+   added to MapServer: QSTRING and QITEM.
+*  SAVEMAP is switched off: The SAVEMAP functionality is considered
+   insecure, since the saved files are accessible by everyone.
+*  TEMPLATE has been removed, since the map_web_template syntax can be
+   used to alter a template file. Simplifies security maintenance by only
+   having to deal with this option in a single place. Note that the
+   TEMPLATEPATTERN of the mapfile has to be used to enable this feature.
