[mapserver-commits] r7465 - trunk/docs/references/cgi
Wed Mar 19 16:11:38 EDT 2008
Author: jmckenna
Date: 2008-03-19 16:11:37 -0400 (Wed, 19 Mar 2008)
New Revision: 7465
   trunk/docs/references/cgi/controls.txt
added 5.0 changes to URL section
Modified: trunk/docs/references/cgi/controls.txt
--- trunk/docs/references/cgi/controls.txt	2008-03-19 19:45:25 UTC (rev 7464)
+++ trunk/docs/references/cgi/controls.txt	2008-03-19 20:11:37 UTC (rev 7465)
@@ -1,6 +1,5 @@
- Variables
+Variables
 BUFFER [distance]
     A distance, in the same coordinate system as the map file, used in
@@ -234,36 +233,62 @@
     ZOOMDIR is limited to MAXZOOM compiled into the MapServer (25 by default).
- ROSA-Applet specific
+Changing map file parameters via a form or a URL
-The ROSA Applet parameters were added to the CGI MapServer in version 3.6.
-This Java Applet provides a more intuitive user interface to MapServer. The
-MapTools site provides detailed information on the ROSA Applet.
+Begining with version 3.3 it is possible to change virtually any map file
+value from a form or a URL. The syntax for this is fairly straight forward,
+and depends on what version of MapServer you are using. One potentially very
+powerful use of this ability to change mapfile parameters through a URL
+involves changing class expressions on-the-fly.  Try it out.
-The parameters can also be used by other interfaces/tools, if set to the right
-values. Please note that the two parameters have to be handed over to te CGI
-application in the order identified below.
-INPUT_TYPE (auto_rect | auto_point)
-    The INPUT_TYPE parameter is needed to identify if the coordinates handed
-    over to the mapserver have to be interpreted as rectangular or point data.
+Using MapServer version >= 5
-INPUT_COORD [minx,miny;maxx,maxy]
-    The ROSA-Applet always fills the pair of coordinates. In case of a point
-    (input_type=auto_point) min and max coordinate are equal (Mapserver
-    uses the min value).
+Previous versions of the MapServer CGI program allowed certain parameters
+to be changed via a URL using a cumbersome syntax such as
+map_layer_0_class_0_color=255+0+0 which changes the color in one classObj.
+Not only was this cumbersome for users but also from a code maintenance
+perspective since we had to maintain separate loaders for URL-based config
+and file-based config. RFC-31 attempts to streamline both by migrating to
+a single object loading function that can be used with strings (either in
+MapScript or via URL) or with files.
- Changing map file parameters via a form or a URL
+So, in the past you have to change parameters one-at-a-time. Now you can
+pass chunks of mapfiles (with security restrictions) to the CGI interface.
+The map_object notation is still necessary to identify which object you
+want to modify but you can change multiple properties at one time. Note
+that you can use either a '_' or a '.' to seperate identifiers.
-Begining with version 3.3 it is now possible to change virtually any map file
-value from a form or a URL. The syntax for this is fairly straight forward.
-Any value can be expressed using the hierarchy used in a map file. A map
-contains a layer, which contains a class, which contains a label, which has a
-color. This hierarchy is expressed as a sequence of MapServer keywords
+Example 1, changing a scalebar object:
+  ...&map.scalebar=UNITS+MILES+COLOR+121+121+121+SIZE+300+2&...
+Example 2, changing a presentation style:
+ ...&map.layer[lakes].class[0].style[0]=SYMBOL+crosshatch+COLOR+151+51+151+SIZE+15&...
+Example 3, creating a new feature
+  ...&map_layer[3]=FEATURE+POINTS+500000+1000000+END+TEXT+'A+test+point'+END&...
+The variable identifies an object uniquely (by name or index in the case of
+layerObj's and classObj's). The value is a snippet of a mapfile. You
+cannot create new objects other than inline features at this point.
+Using MapServer version < 5
+For MapServer version < 5, any value can be expressed using the hierarchy used
+in a map file. A map contains a layer, which contains a class, which contains a label,
+which has a color. This hierarchy is expressed as a sequence of MapServer keywords
 seperated by underscores. For example to change the color of a layer called
 "lakes" with only one class defined you would use a form variable named
 "map_lakes_class_color" and could assign it a color like "0 0 255". Layers can
@@ -289,7 +314,25 @@
 feature. You can repeat the process to create additional features. This is
 really intended for very small (point, rectangle) amounts of data.
-It's quite possible that we'll come up with some shortcuts for this
-processing, but until we know how useful this is to users this is it. One
-potentially very powerful use involves changing class expressions on-the-fly.
-Anyway, try it out.
\ No newline at end of file
+ROSA-Applet Controls
+*note: Active development and maintenance of the ROSA Applet has stopped*
+The ROSA Applet parameters were added to the CGI MapServer in version 3.6.
+This Java Applet provides a more intuitive user interface to MapServer. The
+MapTools site provides detailed information on the ROSA Applet.
+The parameters can also be used by other interfaces/tools, if set to the right
+values. Please note that the two parameters have to be handed over to te CGI
+application in the order identified below.
+INPUT_TYPE (auto_rect | auto_point)
+    The INPUT_TYPE parameter is needed to identify if the coordinates handed
+    over to the mapserver have to be interpreted as rectangular or point data.
+INPUT_COORD [minx,miny;maxx,maxy]
+    The ROSA-Applet always fills the pair of coordinates. In case of a point
+    (input_type=auto_point) min and max coordinate are equal (Mapserver
+    uses the min value).
