[mapserver-commits] r7482 - trunk/mapserver
Thu Mar 27 15:09:19 EDT 2008
Author: tomkralidis
Date: 2008-03-27 15:09:19 -0400 (Thu, 27 Mar 2008)
New Revision: 7482
   trunk/mapserver/mapwfs11.c
small coding convention changes
Modified: trunk/mapserver/mapwfs11.c
--- trunk/mapserver/mapwfs11.c	2008-03-26 21:48:49 UTC (rev 7481)
+++ trunk/mapserver/mapwfs11.c	2008-03-27 19:09:19 UTC (rev 7482)
@@ -92,7 +92,7 @@
 /*                             msWFSDumpLayer11                         */
-static xmlNodePtr msWFSDumpLayer11(mapObj *map, layerObj *lp, xmlNsPtr psOwsNs)
+static xmlNodePtr msWFSDumpLayer11(mapObj *map, layerObj *lp, xmlNsPtr psNsOws)
     rectObj ext;
@@ -125,7 +125,7 @@
     if (value)
         msLibXml2GenerateList(
-            xmlNewChild(psRootNode, psOwsNs, BAD_CAST "Keywords", NULL),
+            xmlNewChild(psRootNode, psNsOws, BAD_CAST "Keywords", NULL),
             NULL, "Keyword", value, ',' );
     /*srs only supposrt DefaultSRS with the same logic as for wfs1.0
@@ -157,13 +157,13 @@
           msProjectRect(&map->projection, NULL, &ext);
         xmlAddChild(psRootNode,
-                    msOWSCommonWGS84BoundingBox( psOwsNs, 2,
+                    msOWSCommonWGS84BoundingBox( psNsOws, 2,
                                                  ext.minx, ext.miny,
                                                  ext.maxx, ext.maxy));
     else
-        xmlNewChild(psRootNode, psOwsNs, BAD_CAST "WGS84BoundingBox", NULL);
+        xmlNewChild(psRootNode, psNsOws, BAD_CAST "WGS84BoundingBox", NULL);
         xmlAddSibling(psNode,
                       xmlNewComment(BAD_CAST "WARNING: Mandatory WGS84BoundingBox could not be established for this layer.  Consider setting LAYER.EXTENT or wfs_extent metadata."));
@@ -204,7 +204,7 @@
     xmlNodePtr psRootNode, psMainNode, psNode, psFtNode;
     xmlNodePtr psTmpNode;
     const char *updatesequence=NULL;
-    xmlNsPtr psOwsNs, psXLinkNs, psNsOgc, psWfsNs;
+    xmlNsPtr psNsOws, psNsXLink, psNsOgc, psNsWfs;
     char *schemalocation = NULL;
     char *xsi_schemaLocation = NULL;
@@ -247,7 +247,7 @@
 /*      Name spaces                                                     */
-    psWfsNs = xmlNewNs(NULL, BAD_CAST "http://www.opengis.net/wfs", BAD_CAST "wfs");
+    psNsWfs = xmlNewNs(NULL, BAD_CAST "http://www.opengis.net/wfs", BAD_CAST "wfs");
     /*default name space*/
     xmlNewProp(psRootNode, BAD_CAST "xmlns", BAD_CAST "http://www.opengis.net/wfs");
@@ -255,8 +255,8 @@
     xmlSetNs(psRootNode, xmlNewNs(psRootNode, BAD_CAST "http://www.opengis.net/gml", BAD_CAST "gml"));
     xmlSetNs(psRootNode, xmlNewNs(psRootNode, BAD_CAST "http://www.opengis.net/wfs", BAD_CAST "wfs"));
-    psOwsNs = xmlNewNs(psRootNode, BAD_CAST MS_OWSCOMMON_OWS_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_OWS_NAMESPACE_PREFIX);
-    psXLinkNs = xmlNewNs(psRootNode, BAD_CAST MS_OWSCOMMON_W3C_XLINK_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_W3C_XLINK_NAMESPACE_PREFIX);
+    psNsOws = xmlNewNs(psRootNode, BAD_CAST MS_OWSCOMMON_OWS_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_OWS_NAMESPACE_PREFIX);
+    psNsXLink = xmlNewNs(psRootNode, BAD_CAST MS_OWSCOMMON_W3C_XLINK_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_W3C_XLINK_NAMESPACE_PREFIX);
     xmlNewNs(psRootNode, BAD_CAST MS_OWSCOMMON_W3C_XSI_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_W3C_XSI_NAMESPACE_PREFIX);
     xmlNewNs(psRootNode, BAD_CAST MS_OWSCOMMON_OGC_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_OGC_NAMESPACE_PREFIX );
@@ -272,7 +272,7 @@
     xsi_schemaLocation = strdup("http://www.opengis.net/wfs");
     xsi_schemaLocation = msStringConcatenate(xsi_schemaLocation, " ");
     xsi_schemaLocation = msStringConcatenate(xsi_schemaLocation, schemalocation);
-    xsi_schemaLocation = msStringConcatenate(xsi_schemaLocation, "/wfs/1.1.0/");
+    xsi_schemaLocation = msStringConcatenate(xsi_schemaLocation, "/wfs/1.1.0/wfs.xsd");
     xsi_schemaLocation = msStringConcatenate(xsi_schemaLocation, "wfs.xsd");
     xmlNewNsProp(psRootNode, NULL, BAD_CAST "xsi:schemaLocation", BAD_CAST xsi_schemaLocation);
@@ -281,11 +281,11 @@
     psTmpNode = xmlAddChild(psRootNode,
-                            msOWSCommonServiceIdentification(psOwsNs, map, "OGC WFS", params->pszVersion));
+                            msOWSCommonServiceIdentification(psNsOws, map, "OGC WFS", params->pszVersion));
     /*service provider*/
     psTmpNode = xmlAddChild(psRootNode, msOWSCommonServiceProvider(
-                                psOwsNs, psXLinkNs, map));
+                                psNsOws, psNsXLink, map));
     /*operation metadata */
     if ((script_url=msOWSGetOnlineResource(map, "FO", "onlineresource", req)) == NULL
@@ -299,24 +299,24 @@
 /*      Operations metadata.                                            */
-    psMainNode= xmlAddChild(psRootNode,msOWSCommonOperationsMetadata(psOwsNs));
+    psMainNode= xmlAddChild(psRootNode,msOWSCommonOperationsMetadata(psNsOws));
 /*      GetCapabilities                                                 */
     psNode = xmlAddChild(psMainNode,
-                         msOWSCommonOperationsMetadataOperation(psOwsNs,psXLinkNs,"GetCapabilities",
+                         msOWSCommonOperationsMetadataOperation(psNsOws,psNsXLink,"GetCapabilities",
        OWS_METHOD_GETPOST, script_url_encoded));
     xmlAddChild(psMainNode, psNode);
     xmlAddChild(psNode, msOWSCommonOperationsMetadataDomainType(
-                    ows_version, psOwsNs, "Parameter", "service", "WFS"));
+                    ows_version, psNsOws, "Parameter", "service", "WFS"));
     /*accept version*/
-    xmlAddChild(psNode, msOWSCommonOperationsMetadataDomainType(ows_version, psOwsNs,
+    xmlAddChild(psNode, msOWSCommonOperationsMetadataDomainType(ows_version, psNsOws,
        "Parameter", "AcceptVersions",
        "1.0.0, 1.1.0"));
     /*format*/
        "Parameter", "AcceptFormats",
        "text/xml"));
@@ -325,12 +325,12 @@
 /*      DescribeFeatureType                                             */
-                          msOWSCommonOperationsMetadataOperation(psOwsNs,psXLinkNs,"DescribeFeatureType",
+                          msOWSCommonOperationsMetadataOperation(psNsOws,psNsXLink,"DescribeFeatureType",
      /*output format*/
        "Parameter", "outputFormat",
        "XMLSCHEMA,text/xml; subtype=gml/2.1.2,text/gml; subtype=gml/3.1.1"));
@@ -338,20 +338,20 @@
 /*      GetFeatureType                                                  */
-                          msOWSCommonOperationsMetadataOperation(psOwsNs,psXLinkNs,"GetFeature",
+                          msOWSCommonOperationsMetadataOperation(psNsOws,psNsXLink,"GetFeature",
      /*resultType: TODO support hits*/
        "Parameter", "resultType",
        "results"));
        "results, hits"));
        "text/gml; subtype=gml/3.1.1"));
@@ -371,7 +371,7 @@
          /* List only vector layers in which DUMP=TRUE */
          if (msWFSIsLayerSupported(lp))
-           xmlAddChild(psFtNode, msWFSDumpLayer11(map, lp, psOwsNs));
+           xmlAddChild(psFtNode, msWFSDumpLayer11(map, lp, psNsOws));
