[mapserver-commits] r8067 - trunk/docs/references/compilation
svn at osgeo.org
svn at osgeo.org
Sun Nov 23 19:09:56 EST 2008
Author: hobu
Date: 2008-11-23 19:09:56 -0500 (Sun, 23 Nov 2008)
New Revision: 8067
trunk/docs/references/compilation/unix.txt
titling
Modified: trunk/docs/references/compilation/unix.txt
--- trunk/docs/references/compilation/unix.txt 2008-11-24 00:07:53 UTC (rev 8066)
+++ trunk/docs/references/compilation/unix.txt 2008-11-24 00:09:56 UTC (rev 8067)
@@ -1,45 +1,18 @@
-.. $Id$
+ Compiling on Unix
- RULE #1: No tabs in this document!
- RULE #2: Indent is 4 characters.
- RULE #3: There is no rule 3.
- Thank you.
- reStructured Text is part of the Python docutils module
- http://docutils.sourceforge.net/
- Documentation on reStructured Text is found at
- http://docutils.sourceforge.net/rst.html
- First reST note is about comments: a double period begins a comment
- block (like a /* in C) and a double period on a line all by itself
- closes the comment block.
-.. Below is our main heading (becomes H1). Note that we require empty
- lines between every different reST element such as the empty line
- between the end of this comment and the begining of the heading.
-:Release: 4.8.4
+:Release: 5.2
:Revision: $Revision$
:Date: $Date$
:Author: J.F. Doyon
-:Contact: jdoyon at nrcan.gc.ca
+:Contact: jdoyon at nrcan.gc.ca
:Author: Howard Butler
-:Contact: hobu at iastate.edu
+:Contact: hobu.inc at gmail.com
-.. The next heading encountered becomes our H2
.. sectnum::
-.. contents::
+.. contents:: Table of Contents
:depth: 2
:backlinks: top
@@ -249,10 +222,11 @@
p = gdImageGetPixel(im,x,y);
More detail about this patch (if you need any) was described by Steve Lime
-in a `post to mapserver-users`_. *NOTE*: Windows builds that are built
-with the buildkit (this includes MS4W) have this patch already and do not
-need to be updated.
+in a `post to mapserver-users`_.
+.. note: Windows builds that are built with the buildkit (this includes MS4W
+and OSGeo4W) have this patch already and do not need to be updated.
Curved label support
More information about the mapserver-commits
