[mapserver-commits] r8068 - in trunk/docs: . references references/mapfile references/mapscript references/output
Sun Nov 23 19:24:41 EST 2008
Author: hobu
Date: 2008-11-23 19:24:41 -0500 (Sun, 23 Nov 2008)
New Revision: 8068
Added:
   trunk/docs/references/mapscript/index.txt
Removed:
   trunk/docs/references/mapfile/index.txt
   trunk/docs/index.txt
   trunk/docs/references/index.txt
   trunk/docs/references/mapfile/introduction.txt
   trunk/docs/references/output/antialias.txt
start some sphinx indexes
Modified: trunk/docs/index.txt
--- trunk/docs/index.txt	2008-11-24 00:09:56 UTC (rev 8067)
+++ trunk/docs/index.txt	2008-11-24 00:24:41 UTC (rev 8068)
@@ -9,7 +9,9 @@
 .. toctree::
    :maxdepth: 2
+   references
 Indices and tables
Modified: trunk/docs/references/index.txt
--- trunk/docs/references/index.txt	2008-11-24 00:09:56 UTC (rev 8067)
+++ trunk/docs/references/index.txt	2008-11-24 00:24:41 UTC (rev 8068)
@@ -0,0 +1,19 @@
+.. _reference:
+ MapServer Reference
+:Release: |version|
+:Date: |today|
+see also :ref:`mapscript`.
+.. toctree::
+   :maxdepth: 2
+   mapfile
+   mapscript
Deleted: trunk/docs/references/mapfile/index.txt
Modified: trunk/docs/references/mapfile/introduction.txt
--- trunk/docs/references/mapfile/introduction.txt	2008-11-24 00:09:56 UTC (rev 8067)
+++ trunk/docs/references/mapfile/introduction.txt	2008-11-24 00:24:41 UTC (rev 8068)
@@ -1,3 +1,29 @@
+.. _mapfile:
+ Mapfile Reference
+:Date: |today|
+see also MapScript :ref:`mapscript`.
+.. toctree::
+   :maxdepth: 2
+   class
+   feature
+   expressions
+   fontset
+   grid
+   Include
 The Mapfile is the heart of MapServer.  It defines the relationships between
 objects, points MapServer to where data are located and defines how things are
 to be drawn.
Added: trunk/docs/references/mapscript/index.txt
--- trunk/docs/references/mapscript/index.txt	                        (rev 0)
+++ trunk/docs/references/mapscript/index.txt	2008-11-24 00:24:41 UTC (rev 8068)
@@ -0,0 +1,21 @@
+.. _mapscript:
+ MapScript
+:Date: |today|
+see also Mapfile :ref:`mapfile`.
+.. toctree::
+   :maxdepth: 2
+   mapscript
+   imagery
+   mapfile
Modified: trunk/docs/references/output/antialias.txt
--- trunk/docs/references/output/antialias.txt	2008-11-24 00:09:56 UTC (rev 8067)
+++ trunk/docs/references/output/antialias.txt	2008-11-24 00:24:41 UTC (rev 8068)
@@ -65,7 +65,7 @@
         ANTIALIAS TRUE
       END
     END # end class
   END # end layer
 END # end map
