[mapserver-commits] r7912 - trunk/mapserver/rfc
Wed Sep 17 00:50:28 EDT 2008
Author: hobu
Date: 2008-09-17 00:50:28 -0400 (Wed, 17 Sep 2008)
New Revision: 7912
Added:
   trunk/mapserver/rfc/ms-rfc-46.txt
ODP -- Operation Ditch Plone
Added: trunk/mapserver/rfc/ms-rfc-46.txt
--- trunk/mapserver/rfc/ms-rfc-46.txt	                        (rev 0)
+++ trunk/mapserver/rfc/ms-rfc-46.txt	2008-09-17 04:50:28 UTC (rev 7912)
@@ -0,0 +1,166 @@
+	Operation Ditch Plone
+:Date:  2008/09/16
+:Author: Howard Butler
+:Contact: hobu.inc at gmail.com
+:Last Edited: $Date$
+:Status: Proposed
+.. sectnum::
+.. contents::
+    :depth: 3
+    :backlinks: top
+Purpose
+Developers have expressed dissatisfaction with the current MapServer Plone
+site, the Plone site rather poorly serves the needs of the project, and its
+maintenance and upkeep is limited to a single system administrator (Howard
+Butler).  Operation Ditch Plone (ODP) will aspire to replace Plone's usage
+in the MapServer website with a hybrid setup that is similar to the
+infrastructure that the OpenLayers_ currently maintains.
+Failures of the Current Website
+The MapServer Plone website could be considered the 2.0 version of the
+MapServer project's web presence.  The 1.0 version of the website was a
+completely static.  The Plone version of the website looked to allow through-the-web
+editing to lessen the burden for documenters.  Over three years into the effort,
+it is pretty clear that the website has not had the desired effect with respect
+to documentation, and it is getting in the way of the project doing other business.
+Other failures, in no particular order:
+* Plone is a bitch to maintain
+* Plone is a bitch to configure to run speedily
+* Plone is a bitch to upgrade
+* Plone is a bitch
+Administrative Failures
+Our uptime has been ok, but one effect of the current setup is that no one
+except Howard Butler takes responsibility for our web infrastructure.  Part of
+the reason for this is there are very few Plone admins available (they must be
+getting paid well to put up with it somewhere else) and part of the reason is
+that Howard bootstrapped the 2.0 version of the site and it was easy to leave
+it in his hands.  Howard doesn't have the time to be able to keep things up at
+anything over a subsistence level, and administration of MapServer's web
+presence must be distributed if we are to achieve any progress.
+Goals
+Here are some goals that the 3.0 version of the MapServer website should achieve:
+* Make it easy for folks to find the docs
+* Stay the hell out of developers' way
+* Allow documenters to get their job done
+* Allow limited user-contributed information in the form of wiki pages
+* Have a gallery that doesn't suck
+* Move off of UMN computing and integrate within OSGeo's infrastructure
+Make it easy for folks to find the docs
+Some people have complained that it is difficult to find documents on the Plone
+website unless you know the exact place in the hierarchy.   Because our mind-reading
+webpage finding software isn't quite up to snuff, the new website should make it easy enough
+for documenters to organize and reorganize information in logical and interlinked
+ways.  It seems the strictly-enforced Plone hierarchy causes more problems than
+it solves in this regard.
+Stay the hell out of developers' way
+The current website is quite slow.  Slow to edit, slow to view, and slow to
+change.  There's lots of pointing and clicking involved to do the simplest
+tasks.  So much so, that folks will only update the website when they
+absolutely have to.  Developers have subversion access by definition of
+being developers.  They should be able to edit the website through text files
+in subversion and have the website be updated automatically.
+Allow documenters to get their job done
+The Plone website fails documenters in a number of ways, but the most important
+failure is the inability to tie documents to specific MapServer versions.  A
+new iteration of the MapServer website must allow this to happen.  Luckily,
+we already have tools to version documents (our source code repository), so
+we should just leverage that to accomplish this goal.
+Allow limited user-contributed information in the form of wiki pages
+From time to time, users do contribute significant documentation describing
+how to accomplish a particular task with MapServer.  Our new infrastructure
+must still allow this to happen without too much friction.  MapServer's Trac
+instance already provides this capability (along with single-signon), and we
+can take advantage of it to accomplish this goal.
+Have a gallery that doesn't suck
+The `OpenLayers Gallery`_ doesn't suck, and it does an excellent job of highlighting
+how people are using OpenLayers_.  Our gallery does suck, it is hard to add
+new entries, and doesn't really highlight anything.
+Move off of UMN computing and integrate within OSGeo's infrastructure
+Just recently (Sept 15th -- Sept 16th, 2008), the server that houses the Plone
+site was having power supply unit issues (they have been resolved), but it is a
+fact that the Plone site is running on a very old Solaris machine that could be
+decommissioned at any point without much of a head's up.  MapServer no longer
+brings grant monies to the UMN, and while they have been gracious to continue
+hosting us, we need to move somewhere where we have more control over our
+destiny.  Reasons like this are exactly why OSGeo exists, there are
+resources there for us to use, and we should move the website there at the
+same time as we dump Plone.
+Implementation
+We are going to unabashedly rip off OpenLayers' web infrastructure.  This includes
+the gallery, static website, and Trac integration.  OpenLayers' web infrastructure
+meets a lot of the goals above, it stays the hell out of the way of the developers
+and does a good job of serving the users' documentation needs.  The mechanics of
+how this transition will take place are described below:
+1) Migrate everything in http://mapserver.gis.umn.edu/development to Trac
+   and add redirects of /development to a landing page on the Trac wiki.
+2) Migrate everything in http://mapserver.gis.umn.edu/community to Trac
+   and add redirects of /community to a landing page on the Trac wiki.
+3) Migrate everything in http://mapserver.gis.umn.edu/download to Trac
+   and add redirects of /download to a landing page on the Trac wiki.
+4) Stand up an Apache instance for MapServer on OSGeo infrastructure.  Howard
+   will coordinate with OSGeo's System Administration Committee to get this
+   done.  Our new URL will be http://mapserver.osgeo.org
+5) Stand up an instance of the `OpenLayers Gallery`_ at http://mapserver.osgeo.org/gallery
+   and port over our existing gallery entries.  Any culling of these entries
+   must be done by some volunteer effort.
+6) Migrate existing documents (notice of when to be given) in /docs to
+   Subversion http://svn.osgeo.org/mapserver/trunk/docs/  All subsequent editing
+   on major MapServer documents from that point forward should happen in svn, and
+   the documents on the Plone website will be considered frozen.
+7) Stand up a cron process that takes the docs in Subversion and generates a
+   static HTML website from them.  This website will be what exists at
+   http://mapserver.osgeo.org
+.. _OpenLayers: http://openlayers.org
+.. _OpenLayers Gallery: http://gallery.openlayers.org
\ No newline at end of file
Property changes on: trunk/mapserver/rfc/ms-rfc-46.txt
___________________________________________________________________
   + text/x-rst
   + Author Date Id Revision
