[mapserver-commits] r7913 - trunk/mapserver
Wed Sep 17 15:52:42 EDT 2008
Author: Assefa
Date: 2008-09-17 15:52:42 -0400 (Wed, 17 Sep 2008)
New Revision: 7913
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapsvg.c
Add possibility  to use a full resolution setting for svg output (#1706)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-09-17 04:50:28 UTC (rev 7912)
+++ trunk/mapserver/HISTORY.TXT	2008-09-17 19:52:42 UTC (rev 7913)
@@ -12,6 +12,8 @@
 Current Version (5.3-dev, SVN trunk):
+- Add possibility  to use a full resolution setting for svg output (#1706)
 - Fixed GetFeature through tileindex bug: the tileindex of the shape found
   wasn't set properly in the resultcache object. (#2359)
Modified: trunk/mapserver/mapsvg.c
--- trunk/mapserver/mapsvg.c	2008-09-17 04:50:28 UTC (rev 7912)
+++ trunk/mapserver/mapsvg.c	2008-09-17 19:52:42 UTC (rev 7913)
@@ -315,7 +315,7 @@
 static void imagePolyline(FILE *fp, int bCompressed, shapeObj *p,
                           colorObj *color, int size,
-                          int symbolstylelength, int *symbolstyle)
+                          int symbolstylelength, int *symbolstyle, int bFullRes)
     int i, j, k;
     char *pszDashArray = NULL;
@@ -350,11 +350,18 @@
         else
           msIO_fprintfgz(fp, bCompressed,"<polyline fill=\"none\" stroke=\"#%02x%02x%02x\" stroke-width=\"%d\" points=\"",color->red, color->green, color->blue,size);
-        msIO_fprintfgz(fp, bCompressed, "%d,%d", (int)p->line[i].point[0].x, (int)p->line[i].point[0].y);
+        if (bFullRes)
+          msIO_fprintfgz(fp, bCompressed, "%.2f,%.2f", p->line[i].point[0].x, p->line[i].point[0].y);
+        else
+          msIO_fprintfgz(fp, bCompressed, "%d,%d", (int)p->line[i].point[0].x, (int)p->line[i].point[0].y);
         for(j=1; j<p->line[i].numpoints; j++)
-            msIO_fprintfgz(fp, bCompressed, " %d,%d", (int)p->line[i].point[j].x, (int)p->line[i].point[j].y);
+            if (bFullRes)
+              msIO_fprintfgz(fp, bCompressed, " %.2f,%.2f", p->line[i].point[j].x, p->line[i].point[j].y);
+            else
+              msIO_fprintfgz(fp, bCompressed, " %d,%d", (int)p->line[i].point[j].x, (int)p->line[i].point[j].y);
@@ -427,19 +434,19 @@
                 for(j=0; j < shape->line[i].numpoints; j++ )
                     shape->line[i].point[j].x =
                       (shape->line[i].point[j].x - extent.minx)/cellsize;
                     shape->line[i].point[j].y =
                       (extent.maxy - shape->line[i].point[j].y)/cellsize;
                     shape->line[i].point[j].x = MS_MAP2IMAGE_X(shape->line[i].point[j].x,
        extent.minx, cellsize);
                     shape->line[i].point[j].y = MS_MAP2IMAGE_Y( shape->line[i].point[j].y,
        extent.maxy,
        cellsize);
@@ -511,17 +518,22 @@
     int width;
     /* gdPoint points[MS_MAXVECTORPOINTS]; */
     symbolObj *symbol;
+    int bFullRes;
 /*      if not SVG, return.                                             */
     if (!image || !MS_DRIVER_SVG(image->format) )
         return;
     if(!p) return;
     if(p->numlines <= 0) return;
+    bFullRes = 0;
+    if (strcasecmp(msGetOutputFormatOption(image->format, "FULL_RESOLUTION",""),
+                   "TRUE") == 0)
+      bFullRes = 1;
     if(style->size == -1) {
       size = (int)msSymbolGetDefaultSize( symbolset->symbol[style->symbol] );
@@ -561,11 +573,11 @@
     if(style->symbol == 0)
       imagePolyline(image->img.svg->stream, image->img.svg->compressed,
                     p, &style->color, width,
-                    symbol->patternlength,  symbol->pattern);
+                    symbol->patternlength,  symbol->pattern, bFullRes);
     else
                     p, &style->color, (int)size,
         return;
@@ -589,7 +601,7 @@
 static void imageFillPolygon(FILE *fp, int bCompressed,
                              shapeObj *p, colorObj *psFillColor,
                              colorObj *psOutlineColor, int size,
     int i, j, k,max;
@@ -671,9 +683,18 @@
         if(p->line[i].numpoints > 2)
-          msIO_fprintfgz(fp,  bCompressed, "M %d %d ", (int)p->line[i].point[0].x, (int)p->line[i].point[0].y);
-        for(j=1; j<p->line[i].numpoints; j++)
-          msIO_fprintfgz(fp,  bCompressed, "L %d %d ", (int)p->line[i].point[j].x, (int)p->line[i].point[j].y);
+            if (bFullRes)
+              msIO_fprintfgz(fp,  bCompressed, "M %.2f %.2f ", p->line[i].point[0].x, p->line[i].point[0].y);
+            else
+              msIO_fprintfgz(fp,  bCompressed, "M %d %d ", (int)p->line[i].point[0].x, (int)p->line[i].point[0].y);
+            for(j=1; j<p->line[i].numpoints; j++)
+                if (bFullRes)
+                  msIO_fprintfgz(fp,  bCompressed, "L %.2f %.2f ", p->line[i].point[j].x, p->line[i].point[j].y);
+                else
+                  msIO_fprintfgz(fp,  bCompressed, "L %d %d ", (int)p->line[i].point[j].x, (int)p->line[i].point[j].y);
             /*msIO_fprintfgz(fp,  bCompressed, " %d,%d", (int)p->line[i].point[j].x, (int)p->line[i].point[j].y);*/
@@ -699,6 +720,8 @@
     colorObj    sOc;
     symbolObj   *symbol;
     int         size;
+    int bFullRes = 0;
 /*      if not svg, return.                                             */
@@ -708,6 +731,10 @@
     if(p == NULL || p->numlines <= 0)
       return;
+     bFullRes = 0;
+                   "TRUE") == 0)
+      bFullRes = 1;
     symbol = symbolset->symbol[style->symbol];
@@ -742,7 +769,7 @@
       psOutlineColor = &sOc;
     imageFillPolygon(image->img.svg->stream, image->img.svg->compressed ,p, psFillColor, psOutlineColor, size,
