[mapserver-commits] r8415 - in sandbox: MapServer opengl
Thu Jan 8 22:27:00 EST 2009
Author: jbourke
Date: 2009-01-08 22:27:00 -0500 (Thu, 08 Jan 2009)
New Revision: 8415
Added:
   sandbox/MapServer/maperror.h
Removed:
   sandbox/opengl/maperror.h
Moved remotely
Copied: sandbox/MapServer/maperror.h (from rev 8414, sandbox/opengl/maperror.h)
--- sandbox/MapServer/maperror.h	                        (rev 0)
+++ sandbox/MapServer/maperror.h	2009-01-09 03:27:00 UTC (rev 8415)
@@ -0,0 +1,173 @@
+ * $Id: maperror.h 6749 2007-08-30 18:39:42Z dmorissette $
+ * Project:  MapServer
+ * Purpose:  Declarations for Error and Debug functions.
+ * Author:   Steve Lime and the MapServer team.
+ * Copyright (c) 1996-2005 Regents of the University of Minnesota.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included in
+ * all copies of this Software or works derived from this Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
+ * OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+#ifndef MAPERROR_H
+#define MAPERROR_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+ *   maperror.c
+#define MS_NOERR 0 /* general error codes */
+#define MS_IOERR 1
+#define MS_MEMERR 2
+#define MS_TYPEERR 3
+#define MS_SYMERR 4
+#define MS_REGEXERR 5
+#define MS_TTFERR 6
+#define MS_DBFERR 7
+#define MS_GDERR 8
+#define MS_IDENTERR 9
+#define MS_EOFERR 10
+#define MS_PROJERR 11
+#define MS_MISCERR 12
+#define MS_CGIERR 13
+#define MS_WEBERR 14
+#define MS_IMGERR 15
+#define MS_HASHERR 16
+#define MS_JOINERR 17
+#define MS_NOTFOUND 18 /* empty search results */
+#define MS_SHPERR 19
+#define MS_PARSEERR 20
+#define MS_SDEERR 21
+#define MS_OGRERR 22
+#define MS_QUERYERR 23
+#define MS_WMSERR 24      /* WMS server error */
+#define MS_WMSCONNERR 25  /* WMS connectiontype error */
+#define MS_ORACLESPATIALERR 26
+#define MS_WFSERR 27      /* WFS server error */
+#define MS_WFSCONNERR 28  /* WFS connectiontype error */
+#define MS_MAPCONTEXTERR 29 /* Map Context error */
+#define MS_HTTPERR 30
+#define MS_CHILDERR 31    /* Errors involving arrays of child objects */
+#define MS_WCSERR 32
+#define MS_GEOSERR 33
+#define MS_RECTERR 34
+#define MS_TIMEERR 35
+#define MS_GMLERR 36
+#define MS_SOSERR 37
+#define MS_NULLPARENTERR 38
+#define MS_AGGERR 39
+#define MS_NUMERRORCODES 40
+#define MS_OGLERR 41
+#define MESSAGELENGTH 2048
+#define ROUTINELENGTH 64
+#define MS_ERROR_LANGUAGE "en-US"
+#if defined(_WIN32) && !defined(__CYGWIN__)
+#  define MS_DLL_EXPORT     __declspec(dllexport)
+#else
+#define  MS_DLL_EXPORT
+#endif
+typedef struct error_obj {
+  int code;
+  char routine[ROUTINELENGTH];
+  char message[MESSAGELENGTH];
+#ifndef SWIG
+  struct error_obj *next;
+#endif
+} errorObj;
+** Function prototypes
+MS_DLL_EXPORT errorObj *msGetErrorObj(void);
+MS_DLL_EXPORT void msResetErrorList(void);
+MS_DLL_EXPORT char *msGetVersion(void);
+MS_DLL_EXPORT int  msGetVersionInt(void);
+MS_DLL_EXPORT char *msGetErrorString(char *delimiter);
+#ifndef SWIG
+MS_DLL_EXPORT void msSetError(int code, const char *message, const char *routine, ...);
+MS_DLL_EXPORT void msWriteError(FILE *stream);
+MS_DLL_EXPORT void msWriteErrorXML(FILE *stream);
+MS_DLL_EXPORT char *msGetErrorCodeString(int code);
+MS_DLL_EXPORT char *msAddErrorDisplayString(char *source, errorObj *error);
+struct map_obj;
+MS_DLL_EXPORT void msWriteErrorImage(struct map_obj *map, char *filename, int blank);
+#endif /* SWIG */
+ *   mapdebug.c (See also MS-RFC-28)
+typedef enum { MS_DEBUGLEVEL_ERRORSONLY = 0,  /* DEBUG OFF, log fatal errors */
+               MS_DEBUGLEVEL_DEBUG      = 1,  /* DEBUG ON */
+               MS_DEBUGLEVEL_TUNING     = 2,  /* Reports timing info */
+               MS_DEBUGLEVEL_V          = 3,  /* Verbose */
+               MS_DEBUGLEVEL_VV         = 4,  /* Very verbose */
+               MS_DEBUGLEVEL_VVV        = 5   /* Very very verbose */
+} debugLevel;
+#ifndef SWIG
+typedef enum { MS_DEBUGMODE_OFF,
+               MS_DEBUGMODE_FILE,
+               MS_DEBUGMODE_STDERR,
+               MS_DEBUGMODE_STDOUT,
+               MS_DEBUGMODE_WINDOWSDEBUG
+} debugMode;
+typedef struct debug_info_obj
+    debugLevel  global_debug_level;
+    debugMode   debug_mode;
+    char        *errorfile;
+    FILE        *fp;
+    /* The following 2 members are used only with USE_THREAD (but we won't #ifndef them) */
+    int         thread_id;
+    struct debug_info_obj *next;
+} debugInfoObj;
+MS_DLL_EXPORT void msDebug( const char * pszFormat, ... );
+MS_DLL_EXPORT int msSetErrorFile(const char *pszErrorFile);
+MS_DLL_EXPORT void msCloseErrorFile( void );
+MS_DLL_EXPORT const char *msGetErrorFile( void );
+MS_DLL_EXPORT void msSetGlobalDebugLevel(int level);
+MS_DLL_EXPORT debugLevel msGetGlobalDebugLevel( void );
+MS_DLL_EXPORT int msDebugInitFromEnv( void );
+MS_DLL_EXPORT void msDebugCleanup( void );
+#endif /* SWIG */
+#ifdef __cplusplus
+#endif
+#endif /* MAPERROR_H */
Deleted: sandbox/opengl/maperror.h
--- sandbox/opengl/maperror.h	2009-01-09 03:26:19 UTC (rev 8414)
+++ sandbox/opengl/maperror.h	2009-01-09 03:27:00 UTC (rev 8415)
@@ -1,173 +0,0 @@
- * $Id: maperror.h 6749 2007-08-30 18:39:42Z dmorissette $
- * Project:  MapServer
- * Purpose:  Declarations for Error and Debug functions.
- * Author:   Steve Lime and the MapServer team.
- * Copyright (c) 1996-2005 Regents of the University of Minnesota.
- * Permission is hereby granted, free of charge, to any person obtaining a
- * copy of this software and associated documentation files (the "Software"),
- * to deal in the Software without restriction, including without limitation
- * the rights to use, copy, modify, merge, publish, distribute, sublicense,
- * and/or sell copies of the Software, and to permit persons to whom the
- * Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included in
- * all copies of this Software or works derived from this Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
- * OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
- * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
- * DEALINGS IN THE SOFTWARE.
-#ifndef MAPERROR_H
-#define MAPERROR_H
-#ifdef __cplusplus
-extern "C" {
-#endif
- *   maperror.c
-#define MS_NOERR 0 /* general error codes */
-#define MS_IOERR 1
-#define MS_MEMERR 2
-#define MS_TYPEERR 3
-#define MS_SYMERR 4
-#define MS_REGEXERR 5
-#define MS_TTFERR 6
-#define MS_DBFERR 7
-#define MS_GDERR 8
-#define MS_IDENTERR 9
-#define MS_EOFERR 10
-#define MS_PROJERR 11
-#define MS_MISCERR 12
-#define MS_CGIERR 13
-#define MS_WEBERR 14
-#define MS_IMGERR 15
-#define MS_HASHERR 16
-#define MS_JOINERR 17
-#define MS_NOTFOUND 18 /* empty search results */
-#define MS_SHPERR 19
-#define MS_PARSEERR 20
-#define MS_SDEERR 21
-#define MS_OGRERR 22
-#define MS_QUERYERR 23
-#define MS_WMSERR 24      /* WMS server error */
-#define MS_WMSCONNERR 25  /* WMS connectiontype error */
-#define MS_ORACLESPATIALERR 26
-#define MS_WFSERR 27      /* WFS server error */
-#define MS_WFSCONNERR 28  /* WFS connectiontype error */
-#define MS_MAPCONTEXTERR 29 /* Map Context error */
-#define MS_HTTPERR 30
-#define MS_CHILDERR 31    /* Errors involving arrays of child objects */
-#define MS_WCSERR 32
-#define MS_GEOSERR 33
-#define MS_RECTERR 34
-#define MS_TIMEERR 35
-#define MS_GMLERR 36
-#define MS_SOSERR 37
-#define MS_NULLPARENTERR 38
-#define MS_AGGERR 39
-#define MS_NUMERRORCODES 40
-#define MS_OGLERR 41
-#define MESSAGELENGTH 2048
-#define ROUTINELENGTH 64
-#define MS_ERROR_LANGUAGE "en-US"
-#if defined(_WIN32) && !defined(__CYGWIN__)
-#  define MS_DLL_EXPORT     __declspec(dllexport)
-#else
-#define  MS_DLL_EXPORT
-#endif
-typedef struct error_obj {
-  int code;
-  char routine[ROUTINELENGTH];
-  char message[MESSAGELENGTH];
-#ifndef SWIG
-  struct error_obj *next;
-#endif
-} errorObj;
-** Function prototypes
-MS_DLL_EXPORT errorObj *msGetErrorObj(void);
-MS_DLL_EXPORT void msResetErrorList(void);
-MS_DLL_EXPORT char *msGetVersion(void);
-MS_DLL_EXPORT int  msGetVersionInt(void);
-MS_DLL_EXPORT char *msGetErrorString(char *delimiter);
-#ifndef SWIG
-MS_DLL_EXPORT void msSetError(int code, const char *message, const char *routine, ...);
-MS_DLL_EXPORT void msWriteError(FILE *stream);
-MS_DLL_EXPORT void msWriteErrorXML(FILE *stream);
-MS_DLL_EXPORT char *msGetErrorCodeString(int code);
-MS_DLL_EXPORT char *msAddErrorDisplayString(char *source, errorObj *error);
-struct map_obj;
-MS_DLL_EXPORT void msWriteErrorImage(struct map_obj *map, char *filename, int blank);
-#endif /* SWIG */
- *   mapdebug.c (See also MS-RFC-28)
-typedef enum { MS_DEBUGLEVEL_ERRORSONLY = 0,  /* DEBUG OFF, log fatal errors */
-               MS_DEBUGLEVEL_DEBUG      = 1,  /* DEBUG ON */
-               MS_DEBUGLEVEL_TUNING     = 2,  /* Reports timing info */
-               MS_DEBUGLEVEL_V          = 3,  /* Verbose */
-               MS_DEBUGLEVEL_VV         = 4,  /* Very verbose */
-               MS_DEBUGLEVEL_VVV        = 5   /* Very very verbose */
-} debugLevel;
-#ifndef SWIG
-typedef enum { MS_DEBUGMODE_OFF,
-               MS_DEBUGMODE_FILE,
-               MS_DEBUGMODE_STDERR,
-               MS_DEBUGMODE_STDOUT,
-               MS_DEBUGMODE_WINDOWSDEBUG
-} debugMode;
-typedef struct debug_info_obj
-    debugLevel  global_debug_level;
-    debugMode   debug_mode;
-    char        *errorfile;
-    FILE        *fp;
-    /* The following 2 members are used only with USE_THREAD (but we won't #ifndef them) */
-    int         thread_id;
-    struct debug_info_obj *next;
-} debugInfoObj;
-MS_DLL_EXPORT void msDebug( const char * pszFormat, ... );
-MS_DLL_EXPORT int msSetErrorFile(const char *pszErrorFile);
-MS_DLL_EXPORT void msCloseErrorFile( void );
-MS_DLL_EXPORT const char *msGetErrorFile( void );
-MS_DLL_EXPORT void msSetGlobalDebugLevel(int level);
-MS_DLL_EXPORT debugLevel msGetGlobalDebugLevel( void );
-MS_DLL_EXPORT int msDebugInitFromEnv( void );
-MS_DLL_EXPORT void msDebugCleanup( void );
-#endif /* SWIG */
-#ifdef __cplusplus
-#endif
-#endif /* MAPERROR_H */
