[mapserver-commits] r8459 - in trunk/docs: installation mapscript/php
Tue Jan 27 13:13:56 EST 2009
Author: jmckenna
Date: 2009-01-27 13:13:56 -0500 (Tue, 27 Jan 2009)
New Revision: 8459
   trunk/docs/installation/php.txt
   trunk/docs/mapscript/php/class-intro.txt
   trunk/docs/mapscript/php/index.txt
point to ported wiki pages on trac-wiki
Modified: trunk/docs/installation/php.txt
--- trunk/docs/installation/php.txt	2009-01-27 14:16:37 UTC (rev 8458)
+++ trunk/docs/installation/php.txt	2009-01-27 18:13:56 UTC (rev 8459)
@@ -61,7 +61,7 @@
 - More information on the PHP/MapScript module can be found on the
   `PHP/MapScript page`_ on MapTools.org.
-- The old `MapServer Wiki`_ also has PHP/MapScript build and installation notes
+- The `MapServer Wiki`_ also has PHP/MapScript build and installation notes
   and some php code snippets.
 - Questions regarding the module should be forwarded to the :ref:`MapServer mailing list <lists>`.
@@ -318,7 +318,7 @@
     their member variables, see the :ref:`MapScript reference <mapscript>`
     and the :ref:`MapFile reference <mapfile>`.
+    The `MapServer Wiki`_ also has PHP/MapScript build and installation
     notes and some php code snippets.
@@ -455,7 +455,7 @@
 .. _`DM Solutions Group`: http://www.dmsolutions.ca/
 .. _`Mapgears`: http://www.mapgears.com
 .. _`PHP/MapScript page`: http://www.maptools.org/php_mapscript/
-.. _`MapServer Wiki`: http://old-mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScript
+.. _`MapServer Wiki`: http://trac.osgeo.org/mapserver/wiki/PHPMapScript
 .. _`PHP web site`: http://www.php.net/
 .. _`Installation on Unix systems`: http://php.net/manual/en/install.unix.php
 .. _`MS4W (MapServer For Windows)`: http://www.maptools.org/ms4w/
Modified: trunk/docs/mapscript/php/class-intro.txt
--- trunk/docs/mapscript/php/class-intro.txt	2009-01-27 14:16:37 UTC (rev 8458)
+++ trunk/docs/mapscript/php/class-intro.txt	2009-01-27 18:13:56 UTC (rev 8459)
@@ -44,5 +44,5 @@
 - Refer to the `main PHP site`_ for their official documentation
 .. _`main PHP site`: http://www.php.net
Modified: trunk/docs/mapscript/php/index.txt
--- trunk/docs/mapscript/php/index.txt	2009-01-27 14:16:37 UTC (rev 8458)
+++ trunk/docs/mapscript/php/index.txt	2009-01-27 18:13:56 UTC (rev 8459)
@@ -39,8 +39,8 @@
 There are documentation and examples for PHP MapScript available via
 the MapServer :ref:`documentation <documentation>`
-See also the MapServer Wiki for links to more informations on this module:
-http://old-mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScript
+See also the MapServer Wiki for links to more information on this module:
+http://trac.osgeo.org/mapserver/wiki/PHPMapScript
 Very important notes
@@ -2077,7 +2077,7 @@
 The grid is always embedded inside a layer object defined as
 a grid (layer->connectiontype = MS_GRATICULE)
-(for more docs : http://old-mapserver.gis.umn.edu/cgi-bin/wiki.pl?MapServerGrid)
+(for more docs : http://trac.osgeo.org/mapserver/wiki/MapServerGrid)
 A layer can become a grid layer by adding a grid object to it using :
 ms_newGridObj(layerObj layer)
