[mapserver-commits] r9181 - sandbox/davidK
Sun Jul 19 17:44:14 EDT 2009
Author: davidK
Date: 2009-07-19 17:44:13 -0400 (Sun, 19 Jul 2009)
New Revision: 9181
   sandbox/davidK/mapdraw.c
modified codeblocks containing MS_MAP2IMAGE macro
Modified: sandbox/davidK/mapdraw.c
--- sandbox/davidK/mapdraw.c	2009-07-17 14:23:42 UTC (rev 9180)
+++ sandbox/davidK/mapdraw.c	2009-07-19 21:44:13 UTC (rev 9181)
@@ -755,10 +755,10 @@
 							"msDrawLayer()");
 					return (MS_FAILURE);
-			} else {
-				image_draw->format->vtable->startNewLayer(image_draw,layer->opacity);
+		image_draw->format->vtable->startNewLayer(image_draw, layer);
 #ifdef USE_AGG
   else if(MS_RENDERER_AGG(image_draw->format)) {
@@ -1529,9 +1529,15 @@
 #endif
     if(layer->transform == MS_TRUE) {
-      center.x = MS_MAP2IMAGE_X(center.x, map->extent.minx, map->cellsize);
-      center.y = MS_MAP2IMAGE_Y(center.y, map->extent.maxy, map->cellsize);
-      r /= map->cellsize;
+		if(!(MS_RENDERER_PLUGIN(image->format) && image->format->renderer == MS_RENDER_WITH_KML))
+			center.x = MS_MAP2IMAGE_X(center.x, map->extent.minx, map->cellsize);
+			center.y = MS_MAP2IMAGE_Y(center.y, map->extent.maxy, map->cellsize);
+		r /= map->cellsize;
     } else
       msOffsetPointRelativeTo(&center, layer);
@@ -1663,8 +1669,11 @@
         else
           annocallret = msPolygonLabelPoint(shape, &annopnt, -1);
-        annopnt.x = MS_MAP2IMAGE_X(annopnt.x, map->extent.minx, map->cellsize);
-        annopnt.y = MS_MAP2IMAGE_Y(annopnt.y, map->extent.maxy, map->cellsize);
+			annopnt.x = MS_MAP2IMAGE_X(annopnt.x, map->extent.minx, map->cellsize);
+			annopnt.y = MS_MAP2IMAGE_Y(annopnt.y, map->extent.maxy, map->cellsize);
@@ -1712,8 +1721,12 @@
 	    if(!msPointInRect(point, &map->extent)) return(MS_SUCCESS);
-	    point->x = MS_MAP2IMAGE_X(point->x, map->extent.minx, map->cellsize);
-	    point->y = MS_MAP2IMAGE_Y(point->y, map->extent.maxy, map->cellsize);
+			point->x = MS_MAP2IMAGE_X(point->x, map->extent.minx, map->cellsize);
+			point->y = MS_MAP2IMAGE_Y(point->y, map->extent.maxy, map->cellsize);
 	  } else
             msOffsetPointRelativeTo(point, layer);
@@ -1759,8 +1772,11 @@
 	  if(!msPointInRect(point, &map->extent)) continue; /* next point */
 	} else
@@ -1944,8 +1960,11 @@
       else
     for(s=0;s<layer->class[c]->numstyles;s++){
@@ -2058,8 +2077,13 @@
   case MS_LAYER_ANNOTATION:
       if(!msPointInRect(point, &map->extent)) return(0);
     } else
@@ -2087,8 +2111,12 @@
   case MS_LAYER_POINT:
     } else
@@ -2503,7 +2531,12 @@
         if( MS_RENDERER_PDF(map->outputformat) )
             msDrawStartShapePDF(map, layer, image, shape);
 #endif
+		if(MS_RENDERER_PLUGIN(image->format))
+			if (image->format->vtable->startShape)
+				image->format->vtable->startShape(image, shape);
