[mapserver-commits] r9183 - sandbox/davidK
Sun Jul 19 17:51:14 EDT 2009
Author: davidK
Date: 2009-07-19 17:51:14 -0400 (Sun, 19 Jul 2009)
New Revision: 9183
   sandbox/davidK/mapogl.cpp
added msStartShapeOgl and msEndShapeOgl functions
Modified: sandbox/davidK/mapogl.cpp
--- sandbox/davidK/mapogl.cpp	2009-07-19 21:47:53 UTC (rev 9182)
+++ sandbox/davidK/mapogl.cpp	2009-07-19 21:51:14 UTC (rev 9183)
@@ -1,255 +1,268 @@
- * mapogl.c
- *  Created on: 12/01/2009
- *      Author: toby
-#include "mapserver.h"
-#ifdef USE_OGL
-#include <assert.h>
-#include "mapoglrenderer.h"
-#include "mapoglcontext.h"
-OglRenderer* getOglRenderer(imageObj* img)
-	return (OglRenderer*) img->img.plugin;
-void msDrawLineOgl(imageObj *img, shapeObj *p, colorObj *c, double width,
-		int patternlength, double* pattern)
-	OglRenderer* renderer = getOglRenderer(img);
-	renderer->renderPolyline(p, c, width, patternlength, pattern);
-void msDrawPolygonOgl(imageObj *img, shapeObj *p, colorObj *c, colorObj *oc,
-		double outlineWidth)
-	renderer->renderPolygon(p, c, oc, outlineWidth);
-void msFreeTileOgl(void *tile)
-	delete (OglCache*)tile;
-void msDrawLineTiledOgl(imageObj *img, shapeObj *p, void* tile)
-	renderer->renderPolylineTile(p, (OglCache*)tile);}
-void msDrawPolygonTiledOgl(imageObj *img, shapeObj *p, colorObj *oc, double outlineWidth, void *tile)
-	renderer->renderPolygon(p, NULL, oc, outlineWidth, (OglCache*)tile);
-void msRenderPixmapOgl(imageObj *img, double x, double y, symbolObj *symbol,
-		double scale, double angle)
-	renderer->renderPixmap(symbol, x, y, angle, scale);
-void msRenderVectorSymbolOgl(imageObj *img, double x, double y,
-		symbolObj *symbol, double scale, double angle, colorObj *c,
-		colorObj *oc, double ow)
-	renderer->renderVectorSymbol(x, y, symbol, scale, angle, c, oc, ow);
-void* msCreateTilePixmapOgl(symbolObj *symbol, double scale, double angle, colorObj *bc)
-	double canvasWidth = symbol->sizex*scale;
-	double canvasHeight = symbol->sizey*scale;
-	OglTexture* renderer = new OglTexture(canvasWidth, canvasHeight, bc);
-	renderer->renderPixmap(symbol, 0, 0, angle, scale);
-	OglCache* tile = renderer->renderToTile();
-	delete renderer;
-	return tile;
-void *msCreateTileEllipseOgl(double width, double height, double angle,
-		colorObj *c, colorObj *bc, colorObj *oc, double ow)
-	double canvasWidth = angle == 0.0 ? width : MS_MAX(height, width);
-	double canvasHeight = angle == 0.0 ? height : MS_MAX(height, width);
-	renderer->renderEllipse(ceil(canvasWidth/2), ceil(canvasHeight/2), angle, width, height, c, NULL, ow);
-	delete renderer;
-	return tile;
-void* msCreateTileVectorOgl(symbolObj *symbol, double scale, double angle,
-	OglTexture* renderer = new OglTexture(symbol->sizex*scale, symbol->sizey*scale, bc);
-	renderer->renderVectorSymbol(0,0, symbol, scale, angle, c, bc, ow);
-	delete renderer;
-	return tile;
-void* msCreateTileTruetypeOgl(imageObj *img, char *text, char *font,
-		double size, double angle, colorObj *c, colorObj *bc, colorObj *oc,
-		double ow)
-	OglTexture* renderer = new OglTexture(size, size, bc);
-	renderer->renderGlyphs(0, 0, c, oc, size, font, text, angle, NULL, 0, 0);
-	delete renderer;
-	return tile;
-void msRenderTileOgl(imageObj *img, void *tile, double x, double y, double angle)
-	renderer->renderTile((OglCache*)tile, x, y, angle);
-int msGetTruetypeTextBBoxOgl(imageObj *img, char *font, double size, char *string, rectObj *rect, double **advances)
-	renderer->getStringBBox(font, size, string, rect, advances);
-	return 0;
-void msRenderGlyphsOgl(imageObj *img, double x, double y, colorObj *c,
-		colorObj *outlinecolor, double size, char *font, char *thechars,
-		double angle, colorObj *shadowcolor, double shdx, double shdy,
-		int outlinewidth)
-	renderer->renderGlyphs(x, y, c, outlinecolor, size, font, thechars, angle, shadowcolor, shdx, shdy);
-void msMergeImagesOgl(imageObj *dest, imageObj *overlay, int opacity, int dstX,
-		int dstY)
-	//	cairo_renderer *rd = getCairoRenderer(dest);
-	//	cairo_renderer *ro = getCairoRenderer(overlay);
-	//	cairo_set_source_surface (rd->cr,ro->surface,dstX,dstY);
-	//	cairo_paint_with_alpha(rd->cr,opacity*0.01);
-imageObj* msImageCreateOgl(int width, int height, outputFormatObj *format, colorObj* bg)
-	imageObj *pNewImage = NULL;
-	if (format->imagemode != MS_IMAGEMODE_RGB && format->imagemode
-			!= MS_IMAGEMODE_RGBA)
-		msSetError(
-				MS_OGLERR, "OpenGL driver only supports RGB or RGBA pixel models.",
-				"msImageCreateOGL()");
-		return NULL;
-	pNewImage = (imageObj*)calloc(1, sizeof(imageObj));
-	if (!pNewImage)
-		return pNewImage;
-	OglRenderer *ren = new OglRenderer(width, height, bg);
-	pNewImage->img.plugin = (void *) ren;
-	return pNewImage;
-int msSaveImageOgl(imageObj *img, char *filename, outputFormatObj *format)
-	imageObj* gdImg = msImageCreateGD(img->width, img->height, format, filename, NULL, 72);
-	OglRenderer* ogl = getOglRenderer(img);
-	ogl->attach(gdImg);
-	char *pFormatBuffer;
-	char cGDFormat[128];
-	int iReturn = 0;
-	pFormatBuffer = format->driver;
-	strcpy(cGDFormat, "gd/");
-	strcat(cGDFormat, &(format->driver[4]));
-	format->driver = &cGDFormat[0];
-	iReturn = msSaveImageGD(gdImg->img.gd, filename, format);
-	format->driver = pFormatBuffer;
-	return 1;
-void msRenderEllipseOgl(imageObj *img, double x, double y, double width,
-		double height, double angle, colorObj *color, colorObj *outlinecolor,
-		double outlinewidth)
-	renderer->renderEllipse(x, y, angle, width, height, color, outlinecolor, outlinewidth);
-void msFreeImageOgl(imageObj *img)
-	if (renderer)
-		delete renderer;
-	img->img.plugin=NULL;
-void msStartNewLayerOgl(imageObj *img, layerObj *layer)
-	double opacity = layer->opacity/100;
-	getOglRenderer(img)->setTransparency(opacity);
-void msCloseNewLayerOgl(imageObj *img, layerObj *layer)
-	getOglRenderer(img)->setTransparency(1.0);
-void msFreeSymbolOgl(symbolObj *s)
-#endif /* USE_OGL */
-int msPopulateRendererVTableOGL(rendererVTableObj *renderer) {
-#ifdef USE_OGL
-    	renderer->supports_transparent_layers = 1;
-    	renderer->startNewLayer = msStartNewLayerOgl;
-    	renderer->closeNewLayer = msCloseNewLayerOgl;
-        renderer->renderLine=&msDrawLineOgl;
-        renderer->createImage=&msImageCreateOgl;
-        renderer->saveImage=&msSaveImageOgl;
-        renderer->transformShape=&msTransformShapeAGG;
-        renderer->renderPolygon=&msDrawPolygonOgl;
-        renderer->renderGlyphs=&msRenderGlyphsOgl;
-        renderer->renderEllipseSymbol = &msRenderEllipseOgl;
-        renderer->renderVectorSymbol = &msRenderVectorSymbolOgl;
-        renderer->renderPixmapSymbol = &msRenderPixmapOgl;
-        renderer->mergeRasterBuffer = &msMergeImagesOgl;
-        renderer->getTruetypeTextBBox = &msGetTruetypeTextBBoxOgl;
-        renderer->createPixmapSymbolTile = &msCreateTilePixmapOgl;
-        renderer->createVectorSymbolTile = &msCreateTileVectorOgl;
-        renderer->createEllipseSymbolTile = &msCreateTileEllipseOgl;
-        renderer->createTruetypeSymbolTile = &msCreateTileTruetypeOgl;
-        renderer->renderTile = &msRenderTileOgl;
-        renderer->renderPolygonTiled = &msDrawPolygonTiledOgl;
-        renderer->renderLineTiled = &msDrawLineTiledOgl;
-        renderer->freeTile = &msFreeTileOgl;
-        renderer->freeSymbol = &msFreeSymbolOgl;
-        renderer->freeImage=&msFreeImageOgl;
-        return MS_SUCCESS;
-    #else
-        msSetError(MS_MISCERR,"OGL driver requested but it is not compiled in this release",
-                "msPopulateRendererVTableOGL()");
-        return MS_FAILURE;
-#endif
+ * mapogl.c
+ *  Created on: 12/01/2009
+ *      Author: toby
+#include "mapserver.h"
+#ifdef USE_OGL
+#include <assert.h>
+#include "mapoglrenderer.h"
+#include "mapoglcontext.h"
+OglRenderer* getOglRenderer(imageObj* img)
+	return (OglRenderer*) img->img.plugin;
+void msDrawLineOgl(imageObj *img, shapeObj *p, colorObj *c, double width,
+		int patternlength, double* pattern)
+	OglRenderer* renderer = getOglRenderer(img);
+	renderer->renderPolyline(p, c, width, patternlength, pattern);
+void msDrawPolygonOgl(imageObj *img, shapeObj *p, colorObj *c, colorObj *oc,
+		double outlineWidth)
+	renderer->renderPolygon(p, c, oc, outlineWidth);
+void msFreeTileOgl(void *tile)
+	delete (OglCache*)tile;
+void msDrawLineTiledOgl(imageObj *img, shapeObj *p, void* tile)
+	renderer->renderPolylineTile(p, (OglCache*)tile);}
+void msDrawPolygonTiledOgl(imageObj *img, shapeObj *p, colorObj *oc, double outlineWidth, void *tile)
+	renderer->renderPolygon(p, NULL, oc, outlineWidth, (OglCache*)tile);
+void msRenderPixmapOgl(imageObj *img, double x, double y, symbolObj *symbol,
+		double scale, double angle)
+	renderer->renderPixmap(symbol, x, y, angle, scale);
+void msRenderVectorSymbolOgl(imageObj *img, double x, double y,
+		symbolObj *symbol, double scale, double angle, colorObj *c,
+		colorObj *oc, double ow)
+	renderer->renderVectorSymbol(x, y, symbol, scale, angle, c, oc, ow);
+void* msCreateTilePixmapOgl(symbolObj *symbol, double scale, double angle, colorObj *bc)
+	double canvasWidth = symbol->sizex*scale;
+	double canvasHeight = symbol->sizey*scale;
+	OglTexture* renderer = new OglTexture(canvasWidth, canvasHeight, bc);
+	renderer->renderPixmap(symbol, 0, 0, angle, scale);
+	OglCache* tile = renderer->renderToTile();
+	delete renderer;
+	return tile;
+void *msCreateTileEllipseOgl(double width, double height, double angle,
+		colorObj *c, colorObj *bc, colorObj *oc, double ow)
+	double canvasWidth = angle == 0.0 ? width : MS_MAX(height, width);
+	double canvasHeight = angle == 0.0 ? height : MS_MAX(height, width);
+	renderer->renderEllipse(ceil(canvasWidth/2), ceil(canvasHeight/2), angle, width, height, c, NULL, ow);
+	delete renderer;
+	return tile;
+void* msCreateTileVectorOgl(symbolObj *symbol, double scale, double angle,
+	OglTexture* renderer = new OglTexture(symbol->sizex*scale, symbol->sizey*scale, bc);
+	renderer->renderVectorSymbol(0,0, symbol, scale, angle, c, bc, ow);
+	delete renderer;
+	return tile;
+void* msCreateTileTruetypeOgl(imageObj *img, char *text, char *font,
+		double size, double angle, colorObj *c, colorObj *bc, colorObj *oc,
+		double ow)
+	OglTexture* renderer = new OglTexture(size, size, bc);
+	renderer->renderGlyphs(0, 0, c, oc, size, font, text, angle, NULL, 0, 0);
+	delete renderer;
+	return tile;
+void msRenderTileOgl(imageObj *img, void *tile, double x, double y, double angle)
+	renderer->renderTile((OglCache*)tile, x, y, angle);
+int msGetTruetypeTextBBoxOgl(imageObj *img, char *font, double size, char *string, rectObj *rect, double **advances)
+	renderer->getStringBBox(font, size, string, rect, advances);
+	return 0;
+void msRenderGlyphsOgl(imageObj *img, double x, double y, colorObj *c,
+		colorObj *outlinecolor, double size, char *font, char *thechars,
+		double angle, colorObj *shadowcolor, double shdx, double shdy,
+		int outlinewidth)
+	renderer->renderGlyphs(x, y, c, outlinecolor, size, font, thechars, angle, shadowcolor, shdx, shdy);
+void msMergeImagesOgl(imageObj *dest, imageObj *overlay, int opacity, int dstX,
+		int dstY)
+	//	cairo_renderer *rd = getCairoRenderer(dest);
+	//	cairo_renderer *ro = getCairoRenderer(overlay);
+	//	cairo_set_source_surface (rd->cr,ro->surface,dstX,dstY);
+	//	cairo_paint_with_alpha(rd->cr,opacity*0.01);
+imageObj* msImageCreateOgl(int width, int height, outputFormatObj *format, colorObj* bg)
+	imageObj *pNewImage = NULL;
+	if (format->imagemode != MS_IMAGEMODE_RGB && format->imagemode
+			!= MS_IMAGEMODE_RGBA)
+		msSetError(
+				MS_OGLERR, "OpenGL driver only supports RGB or RGBA pixel models.",
+				"msImageCreateOGL()");
+		return NULL;
+	pNewImage = (imageObj*)calloc(1, sizeof(imageObj));
+	if (!pNewImage)
+		return pNewImage;
+	OglRenderer *ren = new OglRenderer(width, height, bg);
+	pNewImage->img.plugin = (void *) ren;
+	return pNewImage;
+int msSaveImageOgl(imageObj *img, char *filename, outputFormatObj *format)
+	imageObj* gdImg = msImageCreateGD(img->width, img->height, format, filename, NULL, 72);
+	OglRenderer* ogl = getOglRenderer(img);
+	ogl->attach(gdImg);
+	char *pFormatBuffer;
+	char cGDFormat[128];
+	int iReturn = 0;
+	pFormatBuffer = format->driver;
+	strcpy(cGDFormat, "gd/");
+	strcat(cGDFormat, &(format->driver[4]));
+	format->driver = &cGDFormat[0];
+	iReturn = msSaveImageGD(gdImg->img.gd, filename, format);
+	format->driver = pFormatBuffer;
+	return 1;
+void msRenderEllipseOgl(imageObj *img, double x, double y, double width,
+		double height, double angle, colorObj *color, colorObj *outlinecolor,
+		double outlinewidth)
+	renderer->renderEllipse(x, y, angle, width, height, color, outlinecolor, outlinewidth);
+void msFreeImageOgl(imageObj *img)
+	if (renderer)
+		delete renderer;
+	img->img.plugin=NULL;
+void msStartNewLayerOgl(imageObj *img, layerObj *layer)
+	double opacity = layer->opacity/100;
+	getOglRenderer(img)->setTransparency(opacity);
+void msCloseNewLayerOgl(imageObj *img, layerObj *layer)
+	getOglRenderer(img)->setTransparency(1.0);
+void msFreeSymbolOgl(symbolObj *s)
+void msStartShapeOgl(imageObj *img, shapeObj *shape)
+void msEndShapeOgl(imageObj *img, shapeObj *shape)
+#endif /* USE_OGL */
+int msPopulateRendererVTableOGL(rendererVTableObj *renderer) {
+#ifdef USE_OGL
+    	renderer->supports_transparent_layers = 1;
+    	renderer->startNewLayer = msStartNewLayerOgl;
+    	renderer->closeNewLayer = msCloseNewLayerOgl;
+        renderer->renderLine=&msDrawLineOgl;
+        renderer->createImage=&msImageCreateOgl;
+        renderer->saveImage=&msSaveImageOgl;
+        renderer->transformShape=&msTransformShapeAGG;
+        renderer->renderPolygon=&msDrawPolygonOgl;
+        renderer->renderGlyphs=&msRenderGlyphsOgl;
+        renderer->renderEllipseSymbol = &msRenderEllipseOgl;
+        renderer->renderVectorSymbol = &msRenderVectorSymbolOgl;
+        renderer->renderPixmapSymbol = &msRenderPixmapOgl;
+        renderer->mergeRasterBuffer = &msMergeImagesOgl;
+        renderer->getTruetypeTextBBox = &msGetTruetypeTextBBoxOgl;
+        renderer->createPixmapSymbolTile = &msCreateTilePixmapOgl;
+        renderer->createVectorSymbolTile = &msCreateTileVectorOgl;
+        renderer->createEllipseSymbolTile = &msCreateTileEllipseOgl;
+        renderer->createTruetypeSymbolTile = &msCreateTileTruetypeOgl;
+        renderer->renderTile = &msRenderTileOgl;
+        renderer->renderPolygonTiled = &msDrawPolygonTiledOgl;
+        renderer->renderLineTiled = &msDrawLineTiledOgl;
+        renderer->freeTile = &msFreeTileOgl;
+        renderer->freeSymbol = &msFreeSymbolOgl;
+        renderer->freeImage=&msFreeImageOgl;
+		renderer->startShape = msStartShapeOgl;
+		renderer->endShape = msEndShapeOgl;
+        return MS_SUCCESS;
+    #else
+        msSetError(MS_MISCERR,"OGL driver requested but it is not compiled in this release",
+                "msPopulateRendererVTableOGL()");
+        return MS_FAILURE;
+#endif
