[mapserver-commits] r8736 - trunk/mapserver
Mon Mar 9 16:48:10 EDT 2009
Author: tomkralidis
Date: 2009-03-09 16:48:10 -0400 (Mon, 09 Mar 2009)
New Revision: 8736
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapwms.c
add support for disabling SLD (#1395)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2009-03-09 20:46:00 UTC (rev 8735)
+++ trunk/mapserver/HISTORY.TXT	2009-03-09 20:48:10 UTC (rev 8736)
@@ -29,6 +29,8 @@
 - clean up GEOS init and cleanup functions (#2929)
+- add support for disabling SLD (#1395)
 Version 5.4.0-beta3 (2009-3-5):
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c	2009-03-09 20:46:00 UTC (rev 8735)
+++ trunk/mapserver/mapwms.c	2009-03-09 20:48:10 UTC (rev 8736)
@@ -388,6 +388,7 @@
   int status = 0;
   char *bboxrequest=NULL;
+  const char *sldenabled=NULL;
    epsgbuf[0]='\0';
    srsbuffer[0]='\0';
@@ -410,24 +411,32 @@
     /* check if SLD is passed.  If yes, check for OGR support */
     if (strcasecmp(names[i], "SLD") == 0 || strcasecmp(names[i], "SLD_BODY") == 0)
-      if (ogrEnabled == 0)
-        msSetError(MS_WMSERR, "OGR support is not available.", "msWMSLoadGetMapParams()");
-        return msWMSException(map, nVersion, NULL);
-      else
-        if (strcasecmp(names[i], "SLD") == 0)
-            if ((status = msSLDApplySLDURL(map, values[i], -1, NULL)) != MS_SUCCESS)
-        if (strcasecmp(names[i], "SLD_BODY") == 0)
-            if ((status =msSLDApplySLD(map, values[i], -1, NULL)) != MS_SUCCESS)
+       sldenabled = msOWSLookupMetadata(&(map->web.metadata), "MO", "sld_enabled");
+       if (sldenabled == NULL)
+         sldenabled = strdup("true");
+       if (ogrEnabled == 0)
+          msSetError(MS_WMSERR, "OGR support is not available.", "msWMSLoadGetMapParams()");
+          return msWMSException(map, nVersion, NULL);
+       else
+          if (strcasecmp(sldenabled, "true") == 0)
+            if (strcasecmp(names[i], "SLD") == 0)
+              if ((status = msSLDApplySLDURL(map, values[i], -1, NULL)) != MS_SUCCESS)
+            if (strcasecmp(names[i], "SLD_BODY") == 0)
+              if ((status =msSLDApplySLD(map, values[i], -1, NULL)) != MS_SUCCESS)
     if (strcasecmp(names[i], "LAYERS") == 0)
@@ -1869,10 +1878,16 @@
   char szVersionBuf[OWS_VERSION_MAXLEN];
   char *schemalocation = NULL;
   const char *updatesequence=NULL;
   int i;
   updatesequence = msOWSLookupMetadata(&(map->web.metadata), "MO", "updatesequence");
   if (requested_updatesequence != NULL) {
       i = msOWSNegotiateUpdateSequence(requested_updatesequence, updatesequence);
       if (i == 0) { /* current */
@@ -2128,43 +2143,39 @@
                        NULL);
-    if (nVersion == OWS_1_3_0)
-      msWMSPrintRequestCap(nVersion, "sld:DescribeLayer", script_url_encoded,
-                           "text/xml",
-                           NULL);
-    else
-      msWMSPrintRequestCap(nVersion, "DescribeLayer", script_url_encoded,
-                           "text/xml",
-                           NULL);
+    if (strcasecmp(sldenabled, "true") == 0) {
+        if (nVersion == OWS_1_3_0)
+           msWMSPrintRequestCap(nVersion, "sld:DescribeLayer", script_url_encoded, "text/xml", NULL);
+        else
+           msWMSPrintRequestCap(nVersion, "DescribeLayer", script_url_encoded, "text/xml", NULL);
-    msGetOutputFormatMimeListGD(map,mime_list,sizeof(mime_list)/sizeof(char*));
+        msGetOutputFormatMimeListGD(map,mime_list,sizeof(mime_list)/sizeof(char*));
-    if (nVersion >= OWS_1_1_1) {
-          msWMSPrintRequestCap(nVersion, "sld:GetLegendGraphic", script_url_encoded,
+        if (nVersion >= OWS_1_1_1) {
+              msWMSPrintRequestCap(nVersion, "sld:GetLegendGraphic", script_url_encoded,
                     mime_list[0], mime_list[1], mime_list[2], mime_list[3],
                     mime_list[4], mime_list[5], mime_list[6], mime_list[7],
                     mime_list[8], mime_list[9], mime_list[10], mime_list[11],
                     mime_list[12], mime_list[13], mime_list[14], mime_list[15],
                     mime_list[16], mime_list[17], mime_list[18], mime_list[19],
                     NULL );
-          msWMSPrintRequestCap(nVersion, "ms:GetStyles", script_url_encoded, "text/xml", NULL);
-        else
-            msWMSPrintRequestCap(nVersion, "GetLegendGraphic", script_url_encoded,
+              msWMSPrintRequestCap(nVersion, "ms:GetStyles", script_url_encoded, "text/xml", NULL);
+           else
+              msWMSPrintRequestCap(nVersion, "GetLegendGraphic", script_url_encoded,
                     NULL );
-            msWMSPrintRequestCap(nVersion, "GetStyles", script_url_encoded, "text/xml", NULL);
+              msWMSPrintRequestCap(nVersion, "GetStyles", script_url_encoded, "text/xml", NULL);
   msIO_printf("  </Request>\n");
@@ -3080,7 +3091,13 @@
     int nWidth = -1, nHeight =-1;
     char *pszStyle = NULL;
     char *sld_version = NULL;
+    const char *sldenabled = NULL;
      for(i=0; map && i<numentries; i++)
          if (strcasecmp(names[i], "LAYER") == 0)
@@ -3102,10 +3119,10 @@
 /*      xml string.                                                     */
          else if (strcasecmp(names[i], "SLD") == 0 &&
-                  values[i] && strlen(values[i]) > 0)
+                  values[i] && strlen(values[i]) > 0 && strcasecmp(sldenabled, "true") == 0)
              msSLDApplySLDURL(map, values[i], -1, NULL);
          else if (strcasecmp(names[i], "SLD_BODY") == 0 &&
              msSLDApplySLD(map, values[i], -1, NULL);
          else if (strcasecmp(names[i], "RULE") == 0)
            psRule = values[i];
