[mapserver-commits] r8737 - in trunk/msautotest/wxs: . expected
Mon Mar 9 16:50:08 EDT 2009
Author: tomkralidis
Date: 2009-03-09 16:50:08 -0400 (Mon, 09 Mar 2009)
New Revision: 8737
Added:
   trunk/msautotest/wxs/expected/wms_nosld_cap.xml
   trunk/msautotest/wxs/expected/wms_nosld_get_map_line_sld.png
   trunk/msautotest/wxs/expected/wms_nosld_legend.png
   trunk/msautotest/wxs/wms_nosld.map
add support for disabling SLD (#1395)
Added: trunk/msautotest/wxs/expected/wms_nosld_cap.xml
--- trunk/msautotest/wxs/expected/wms_nosld_cap.xml	                        (rev 0)
+++ trunk/msautotest/wxs/expected/wms_nosld_cap.xml	2009-03-09 20:50:08 UTC (rev 8737)
@@ -0,0 +1,117 @@
+Content-type: application/vnd.ogc.wms_xml
+<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
+<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://ogc.dmsolutions.ca/wms/1.1.1/capabilities_1_1_1.dtd"
+ <!ELEMENT VendorSpecificCapabilities EMPTY>
+ ]>  <!-- end of DOCTYPE declaration -->
+<WMT_MS_Capabilities version="1.1.1">
+<Service>
+  <Name>OGC:WMS</Name>
+  <Title>Test simple wms</Title>
+  <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://localhost/path/to/wms_simple?"/>
+  <ContactInformation>
+  </ContactInformation>
+</Service>
+<Capability>
+  <Request>
+    <GetCapabilities>
+      <Format>application/vnd.ogc.wms_xml</Format>
+      <DCPType>
+        <HTTP>
+          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://localhost/path/to/wms_simple?"/></Get>
+          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://localhost/path/to/wms_simple?"/></Post>
+        </HTTP>
+      </DCPType>
+    </GetCapabilities>
+    <GetMap>
+      <Format>image/png</Format>
+      <Format>image/gif</Format>
+      <Format>image/png; mode=24bit</Format>
+      <Format>image/jpeg</Format>
+      <Format>image/vnd.wap.wbmp</Format>
+      <Format>image/tiff</Format>
+      <Format>image/svg+xml</Format>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </GetMap>
+    <GetFeatureInfo>
+      <Format>text/plain</Format>
+      <Format>application/vnd.ogc.gml</Format>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </GetFeatureInfo>
+  </Request>
+  <Exception>
+    <Format>application/vnd.ogc.se_xml</Format>
+    <Format>application/vnd.ogc.se_inimage</Format>
+    <Format>application/vnd.ogc.se_blank</Format>
+  </Exception>
+  <VendorSpecificCapabilities />
+  <UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0"/>
+  <Layer>
+    <Name>WMS_NOSLD</Name>
+    <SRS>EPSG:42304</SRS>
+    <SRS>EPSG:42101</SRS>
+    <SRS>EPSG:4269</SRS>
+    <SRS>EPSG:4326</SRS>
+    <LatLonBoundingBox minx="-67.5725" miny="42" maxx="-58.9275" maxy="48.5" />
+    <BoundingBox SRS="EPSG:4326"
+                minx="-67.5725" miny="42" maxx="-58.9275" maxy="48.5" />
+    <Layer queryable="0" opaque="0" cascaded="0">
+        <Name>province</Name>
+        <Title>province</Title>
+<!-- WARNING: Mandatory mapfile parameter '(at least one of) MAP.PROJECTION, LAYER.PROJECTION or wms_srs metadata' was missing in this context. -->
+        <LatLonBoundingBox minx="-66.7243" miny="41.7705" maxx="-57.7217" maxy="48.4773" />
+        <Style>
+          <Name>default</Name>
+          <Title>default</Title>
+          <LegendURL width="91" height="23">
+             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://localhost/path/to/wms_simple?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=province&amp;format=image/png&amp;STYLE=default"/>
+          </LegendURL>
+        </Style>
+    </Layer>
+        <Name>popplace</Name>
+        <Title>popplace</Title>
+        <LatLonBoundingBox minx="-66.3286" miny="42.5631" maxx="-59.6882" maxy="47.9413" />
+        <Style>
+          <LegendURL width="77" height="23">
+             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://localhost/path/to/wms_simple?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=popplace&amp;format=image/png&amp;STYLE=default"/>
+          </LegendURL>
+        </Style>
+    </Layer>
+        <Name>road</Name>
+        <Title>road</Title>
+        <LatLonBoundingBox minx="-66.6333" miny="42.3821" maxx="-59.2921" maxy="48.2955" />
+        <Style>
+          <LegendURL width="70" height="23">
+             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://localhost/path/to/wms_simple?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=road&amp;format=image/png&amp;STYLE=default"/>
+          </LegendURL>
+        </Style>
+    </Layer>
+  </Layer>
+</Capability>
+</WMT_MS_Capabilities>
Added: trunk/msautotest/wxs/expected/wms_nosld_get_map_line_sld.png
(Binary files differ)
Property changes on: trunk/msautotest/wxs/expected/wms_nosld_get_map_line_sld.png
___________________________________________________________________
   + application/octet-stream
Added: trunk/msautotest/wxs/expected/wms_nosld_legend.png
Property changes on: trunk/msautotest/wxs/expected/wms_nosld_legend.png
Added: trunk/msautotest/wxs/wms_nosld.map
--- trunk/msautotest/wxs/wms_nosld.map	                        (rev 0)
+++ trunk/msautotest/wxs/wms_nosld.map	2009-03-09 20:50:08 UTC (rev 8737)
@@ -0,0 +1,157 @@
+# Test WMS non-enabled SLD
+# REQUIRES: INPUT=GDAL OUTPUT=PNG SUPPORTS=WMS
+# GetCapabilities
+# RUN_PARMS: wms_nosld_cap.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities" > [RESULT_DEVERSION]
+# Generate map image with a new line symbology for the road layer.
+# RUN_PARMS: wms_nosld_get_map_line_sld.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-68.125,42,-58.375,48.5&FORMAT=image/png&WIDTH=300&HEIGHT=200&STYLES=&LAYERS=road&sld_body=%3CStyledLayerDescriptor+version%3D%221.0.0%22%3E%0D%0A%3CNamedLayer%3E%0D%0A%3CName%3Eroad%3C%2FName%3E%0D%0A%3CUserStyle%3E%0D%0A%3CTitle%3Exxx%3C%2FTitle%3E%0D%0A%3CFeatureTypeStyle%3E%0D%0A%3CRule%3E%0D%0A%3CLineSymbolizer%3E%0D%0A%3CGeometry%3E%0D%0A%3CPropertyName%3Ecenter-line%3C%2FPropertyName%3E%0D%0A%3C%2FGeometry%3E%0D%0A%3CStroke%3E%0D%0A%3CCssParameter+name%3D%22stroke%22%3E%230000ff%3C%2FCssParameter%3E%0D%0A%3C%2FStroke%3E%0D%0A%3C%2FLineSymbolizer%3E%0D%0A%3C%2FRule%3E%0D%0A%3C%2FFeatureTypeStyle%3E%0D%0A%3C%2FUserStyle%3E%0D%0A%3C%2FNamedLayer%3E%0D%0A%3C%2FStyledLayerDescriptor%3E%0D%0A" > [RESULT_DEMIME]
+# GetLegendGraphic
+# RUN_PARMS: wms_nosld_legend.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetLegendGraphic&FORMAT=image/png&LAYER=road&sld_body=%3CStyledLayerDescriptor+version%3D%221.0.0%22%3E%0D%0A%3CNamedLayer%3E%0D%0A%3CName%3Eroad%3C%2FName%3E%0D%0A%3CUserStyle%3E%0D%0A%3CTitle%3Exxx%3C%2FTitle%3E%0D%0A%3CFeatureTypeStyle%3E%0D%0A%3CRule%3E%0D%0A%3CLineSymbolizer%3E%0D%0A%3CGeometry%3E%0D%0A%3CPropertyName%3Ecenter-line%3C%2FPropertyName%3E%0D%0A%3C%2FGeometry%3E%0D%0A%3CStroke%3E%0D%0A%3CCssParameter+name%3D%22stroke%22%3E%230000ff%3C%2FCssParameter%3E%0D%0A%3C%2FStroke%3E%0D%0A%3C%2FLineSymbolizer%3E%0D%0A%3C%2FRule%3E%0D%0A%3C%2FFeatureTypeStyle%3E%0D%0A%3C%2FUserStyle%3E%0D%0A%3C%2FNamedLayer%3E%0D%0A%3C%2FStyledLayerDescriptor%3E%0D%0A" > [RESULT_DEMIME]
+NAME WMS_NOSLD
+STATUS ON
+SIZE 400 300
+#EXTENT   2018000 -73300 3410396 647400
+#UNITS METERS
+EXTENT -67.5725 42 -58.9275 48.5
+UNITS DD
+IMAGECOLOR 255 255 255
+SHAPEPATH ./data
+SYMBOLSET etc/symbols.sym
+FONTSET etc/fonts.txt
+OUTPUTFORMAT
+  NAME GDPNG
+  DRIVER "GD/PNG"
+  MIMETYPE "image/png"
+  IMAGEMODE RGB
+  EXTENSION "png"
+END
+# Start of web interface definition
+WEB
+ IMAGEPATH "/tmp/ms_tmp/"
+ IMAGEURL "/ms_tmp/"
+  METADATA
+    "wms_title"		   "Test simple wms"
+    "wms_onlineresource"   "http://localhost/path/to/wms_simple?"
+    "wms_srs"		   "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326"
+    "ows_schemas_location" "http://ogc.dmsolutions.ca"
+    "wms_sld_enabled"      "false"
+  END
+END
+PROJECTION
+#  "init=./data/epsg2:42304"
+#  "init=epsg:42304"
+   "init=epsg:4326"
+END
+# Start of layer definitions
+LAYER
+  NAME province
+  DATA province
+  METADATA
+    "wms_title"         "province"
+    "wms_description"   "province"
+    "wms_result_fields" "NAME_E YEAR_EST AREA_KMSQ"
+  END
+  TYPE POINT
+  STATUS ON
+  PROJECTION
+  "init=./data/epsg2:42304"
+  END
+  DUMP TRUE
+  CLASSITEM "Name_e"
+  CLASS
+    NAME "Province"
+    COLOR 200 255 0
+    OUTLINECOLOR 120 120 120
+  END
+END # Layer
+LAYER
+  NAME popplace
+  DATA popplace
+  METADATA
+    "wms_title"         "popplace"
+    "wms_description"   "Cities of I.P.E."
+    "wms_result_fields" "NAME"
+  END
+  TYPE POINT
+  STATUS ON
+  PROJECTION
+  END
+  DUMP TRUE
+  LabelItem "Name"
+  CLASSITEM "Capital"
+  CLASS
+    EXPRESSION /./
+    SYMBOL 2
+    SIZE 8
+    NAME "Cities"
+    LABEL
+      COLOR  0 0 0
+      FONT Vera
+      TYPE truetype
+      SIZE 8
+      POSITION AUTO
+      PARTIALS FALSE
+      OUTLINECOLOR 255 255 255
+    END
+    COLOR 0 0 0
+  END
+END # Layer
+LAYER
+  NAME road
+  DATA road
+  METADATA
+    "wms_title"       "road"
+    "wms_description" "Roads of I.P.E."
+  END
+  TYPE LINE
+  STATUS ON
+  PROJECTION
+  END
+  DUMP TRUE
+  CLASS
+    NAME "Roads"
+    SYMBOL 0
+    COLOR 220 0 0
+  END
+END # Layer
+END # Map File
