[mapserver-commits] r9891 - trunk/mapserver
Tue Feb 23 22:53:52 EST 2010
Author: warmerdam
Date: 2010-02-23 22:53:51 -0500 (Tue, 23 Feb 2010)
New Revision: 9891
   trunk/mapserver/mapoutput.c
cleanup whitespace
Modified: trunk/mapserver/mapoutput.c
--- trunk/mapserver/mapoutput.c	2010-02-23 21:38:47 UTC (rev 9890)
+++ trunk/mapserver/mapoutput.c	2010-02-24 03:53:51 UTC (rev 9891)
@@ -209,7 +209,7 @@
         format->imagemode = MS_IMAGEMODE_PC256; // ???
         format->extension = strdup("jpg");
         format->renderer = MS_RENDER_WITH_GD2;
 #endif
 #ifdef USE_GD_WBMP
     if( strcasecmp(driver,"GD/WBMP") == 0 )
@@ -270,23 +270,21 @@
         format->renderer = MS_RENDER_WITH_CAIRO_RASTER;
     if( strcasecmp(driver,"CAIRO/PDF") == 0 )
-		format = msAllocOutputFormat( map, "cairopdf", driver );
-		format->mimetype = strdup("application/x-pdf");
-		format->imagemode = MS_IMAGEMODE_RGB;
-		format->extension = strdup("pdf");
-		format->renderer = MS_RENDER_WITH_CAIRO_PDF;
+        format = msAllocOutputFormat( map, "cairopdf", driver );
+        format->mimetype = strdup("application/x-pdf");
+        format->imagemode = MS_IMAGEMODE_RGB;
+        format->extension = strdup("pdf");
+        format->renderer = MS_RENDER_WITH_CAIRO_PDF;
     if( strcasecmp(driver,"CAIRO/SVG") == 0 )
-		format = msAllocOutputFormat( map, "cairosvg", driver );
-		format->mimetype = strdup("image/svg+xml");
-		format->extension = strdup("svg");
-		format->renderer = MS_RENDER_WITH_CAIRO_SVG;
+        format = msAllocOutputFormat( map, "cairosvg", driver );
+        format->mimetype = strdup("image/svg+xml");
+        format->extension = strdup("svg");
+        format->renderer = MS_RENDER_WITH_CAIRO_SVG;
 #endif
 #if defined(USE_OGL)
@@ -299,8 +297,6 @@
         format->renderer = MS_RENDER_WITH_OGL;
 #endif
 #ifdef USE_MING_FLASH
     if( strcasecmp(driver,"swf") == 0 )
@@ -323,13 +319,13 @@
 #endif
     if( strcasecmp(driver,"agg2png") == 0 )
-		format = msAllocOutputFormat( map, "agg2png", driver );
-		format->mimetype = strdup("image/png");
-		format->extension = strdup("png");
-		format->renderer = MS_RENDER_WITH_AGG2;
+        format = msAllocOutputFormat( map, "agg2png", driver );
+        format->mimetype = strdup("image/png");
+        format->extension = strdup("png");
+        format->renderer = MS_RENDER_WITH_AGG2;
 #ifdef USE_GDAL
     if( strncasecmp(driver,"gdal/",5) == 0 )
@@ -365,15 +361,15 @@
     if( strcasecmp(driver,"template") == 0 ) {
-      format = msAllocOutputFormat( map, "template", driver );
-      format->mimetype = strdup("text/html");
-      format->extension = strdup("html");
-      format->imagemode = 0;
-      format->renderer = MS_RENDER_WITH_TEMPLATE;
+        format = msAllocOutputFormat( map, "template", driver );
+        format->mimetype = strdup("text/html");
+        format->extension = strdup("html");
+        format->imagemode = 0;
+        format->renderer = MS_RENDER_WITH_TEMPLATE;
     if( format != NULL )
-      format->inmapfile = MS_FALSE;
+        format->inmapfile = MS_FALSE;
     if( format!= NULL && MS_RENDERER_PLUGIN(format) ) {
         msInitializeRendererVTable(format);
@@ -924,7 +920,7 @@
 void msGetOutputFormatMimeListImg( mapObj *map, char **mime_list, int max_mime )
-  int mime_count = 0, i,j;
+    int mime_count = 0, i,j;
     const char *format_list = NULL;
     char **tokens = NULL;
     int numtokens = 0;
