[mapserver-commits] r9892 - trunk/mapserver
Tue Feb 23 23:47:00 EST 2010
Author: warmerdam
Date: 2010-02-23 23:46:59 -0500 (Tue, 23 Feb 2010)
New Revision: 9892
   trunk/mapserver/mapfile.c
   trunk/mapserver/mapoutput.c
   trunk/mapserver/mapserver.h
improved outputformat/renderer error checking a bit
Modified: trunk/mapserver/mapfile.c
--- trunk/mapserver/mapfile.c	2010-02-24 03:53:51 UTC (rev 9891)
+++ trunk/mapserver/mapfile.c	2010-02-24 04:46:59 UTC (rev 9892)
@@ -3839,7 +3839,8 @@
         format->inmapfile = MS_TRUE;
-        msOutputFormatValidate( format );
+        if( !msOutputFormatValidate( format, MS_TRUE ) )
+            return -1;
         return(0);
     case(NAME):
Modified: trunk/mapserver/mapoutput.c
--- trunk/mapserver/mapoutput.c	2010-02-24 03:53:51 UTC (rev 9891)
+++ trunk/mapserver/mapoutput.c	2010-02-24 04:46:59 UTC (rev 9892)
@@ -665,7 +665,7 @@
     if( format != NULL )
+        msOutputFormatValidate( format, MS_FALSE );
     return format;
@@ -686,7 +686,6 @@
     outputFormatObj *formatToFree = NULL;
     assert( target != NULL );
     if( *target != NULL && --((*target)->refcount) < 1 )
@@ -701,7 +700,7 @@
         return;
 /*      Do we need to change any values?  If not, then just apply       */
@@ -1032,7 +1031,7 @@
 /*      possible.                                                       */
-int msOutputFormatValidate( outputFormatObj *format )
+int msOutputFormatValidate( outputFormatObj *format, int issue_error )
     int result = MS_TRUE;
@@ -1043,9 +1042,16 @@
     /* Enforce the requirement that GD/JPEG be RGB and TRANSPARENT=OFF */
     if( strcasecmp(format->driver,"GD/JPEG") == 0 && format->transparent )
-        msDebug( "GD/JPEG OUTPUTFORMAT %s has TRANSPARENT set ON, but this is not supported.\n"
-                 "It has been disabled.\n",
-                 format->name );
+        if( issue_error )
+            msSetError( MS_MISCERR,
+                        "GD/JPEG OUTPUTFORMAT %s has TRANSPARENT set ON, but this is not supported.\n"
+                        "It has been disabled.\n",
+                        "msOutputFormatValidate()", format->name );
+        else
+            msDebug( "GD/JPEG OUTPUTFORMAT %s has TRANSPARENT set ON, but this is not supported.\n"
+                     format->name );
         format->transparent = MS_FALSE;
         result = MS_FALSE;
@@ -1053,32 +1059,64 @@
         && format->imagemode == MS_IMAGEMODE_RGBA )
-        msDebug( "GD/JPEG OUTPUTFORMAT %s has IMAGEMODE RGBA, but this is not supported.\n"
-                 "IMAGEMODE forced to RGB.\n",
-                 format->name );
+        if( issue_error )
+                        "GD/JPEG OUTPUTFORMAT %s has IMAGEMODE RGBA, but this is not supported.\n"
+                        "IMAGEMODE forced to RGB.\n",
+        else
+            msDebug( "GD/JPEG OUTPUTFORMAT %s has IMAGEMODE RGBA, but this is not supported.\n"
+                     format->name );
         format->imagemode = MS_IMAGEMODE_RGB;
         result = MS_FALSE;
     if( format->transparent && format->imagemode == MS_IMAGEMODE_RGB )
-        msDebug( "OUTPUTFORMAT %s has TRANSPARENT set ON, but an IMAGEMODE\n"
-                 " of RGB instead of RGBA.  Changing imagemode to RGBA.\n",
-                 format->name );
+        if( issue_error )
+                   "OUTPUTFORMAT %s has TRANSPARENT set ON, but an IMAGEMODE\n"
+                   "of RGB instead of RGBA.  Changing imagemode to RGBA.\n",
+        else
+            msDebug("OUTPUTFORMAT %s has TRANSPARENT set ON, but an IMAGEMODE\n"
+                    format->name );
         format->imagemode = MS_IMAGEMODE_RGBA;
         result = MS_FALSE;
-    /* see bug 724 */
-    if( ( format->imagemode == MS_IMAGEMODE_INT16
-          || format->imagemode == MS_IMAGEMODE_FLOAT32
-          || format->imagemode == MS_IMAGEMODE_BYTE )
-        && format->renderer != MS_RENDER_WITH_RAWDATA )
-        format->renderer = MS_RENDER_WITH_RAWDATA;
+    /* Special checking around RAWMODE image modes. */
+    if( format->imagemode == MS_IMAGEMODE_INT16
+        || format->imagemode == MS_IMAGEMODE_FLOAT32
+        || format->imagemode == MS_IMAGEMODE_BYTE )
+        if( strncmp(format->driver,"GDAL/",5) != 0 )
+            result = MS_FALSE;
+            if( issue_error )
+                            "OUTPUTFORMAT %s has IMAGEMODE BYTE/INT16/FLOAT32, but this is only supported for GDAL drivers.",
+            else
+                msDebug( "OUTPUTFORMAT %s has IMAGEMODE BYTE/INT16/FLOAT32, but this is only supported for GDAL drivers.",
+                         format->name );
+        if( format->renderer != MS_RENDER_WITH_RAWDATA ) /* see bug 724 */
+            format->renderer = MS_RENDER_WITH_RAWDATA;
     return result;
+/*                     msInitializeRendererVTable()                     */
 int msInitializeRendererVTable(outputFormatObj *format) {
     assert(format);
     if(format->vtable) {
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2010-02-24 03:53:51 UTC (rev 9891)
+++ trunk/mapserver/mapserver.h	2010-02-24 04:46:59 UTC (rev 9892)
@@ -2307,7 +2307,8 @@
 MS_DLL_EXPORT void msGetOutputFormatMimeListImg( mapObj *map, char **mime_list, int max_mime );
 MS_DLL_EXPORT void msGetOutputFormatMimeListWMS( mapObj *map, char **mime_list, int max_mime );
 MS_DLL_EXPORT outputFormatObj *msCloneOutputFormat( outputFormatObj *format );
-MS_DLL_EXPORT int msOutputFormatValidate( outputFormatObj *format );
+MS_DLL_EXPORT int msOutputFormatValidate( outputFormatObj *format,
+                                          int issue_error );
 #ifndef gdImageTrueColor
 #  define gdImageTrueColor(x) (0)
