[mapserver-commits] r9665 - in trunk/mapserver: . mapscript/php3
Mon Jan 4 14:33:50 EST 2010
Author: aboudreault
Date: 2010-01-04 14:33:47 -0500 (Mon, 04 Jan 2010)
New Revision: 9665
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapscript/php3/php_mapscript.c
PHP/Mapscript: added layerObj units property (#3249)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2010-01-04 17:10:19 UTC (rev 9664)
+++ trunk/mapserver/HISTORY.TXT	2010-01-04 19:33:47 UTC (rev 9665)
@@ -14,6 +14,8 @@
 Current Version (SVN trunk):
+- PHP/Mapscript: added layerObj units property (#3249)
 - Changed the query map rendering implementation without adding extra layers to the map (#3069)
 - SQL Server 2008 plugin is not handling null field values correctly (#2893)
Modified: trunk/mapserver/mapscript/php3/php_mapscript.c
--- trunk/mapserver/mapscript/php3/php_mapscript.c	2010-01-04 17:10:19 UTC (rev 9664)
+++ trunk/mapserver/mapscript/php3/php_mapscript.c	2010-01-04 19:33:47 UTC (rev 9665)
@@ -6772,7 +6772,7 @@
     add_property_double(return_value, "tolerance",  player->tolerance);
     add_property_long(return_value,   "toleranceunits",player->toleranceunits);
     add_property_long(return_value,   "sizeunits",  player->sizeunits);
+    add_property_long(return_value,  "units",     player->units);
     add_property_double(return_value, "symbolscaledenom",player->symbolscaledenom);
     add_property_double(return_value, "minscaledenom",   player->minscaledenom);
     add_property_double(return_value, "maxscaledenom",   player->maxscaledenom);
@@ -6988,6 +6988,7 @@
     else IF_SET_DOUBLE("tolerance",  self->tolerance)
     else IF_SET_LONG(  "toleranceunits",self->toleranceunits)
     else IF_SET_LONG(  "sizeunits",  self->sizeunits)
+    else IF_SET_LONG(  "units",       self->units)
     else IF_SET_DOUBLE("symbolscaledenom",self->symbolscaledenom)
     else IF_SET_DOUBLE("minscaledenom",   self->minscaledenom)
     else IF_SET_DOUBLE("maxscaledenom",   self->maxscaledenom)
