[mapserver-commits] r9666 - trunk/mapserver
Tue Jan 5 06:55:03 EST 2010
Author: tamas
Date: 2010-01-05 06:55:01 -0500 (Tue, 05 Jan 2010)
New Revision: 9666
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapgd.c
Changed msSaveImageBufferGD to be in accordance with msSaveImageGD (#3201)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2010-01-04 19:33:47 UTC (rev 9665)
+++ trunk/mapserver/HISTORY.TXT	2010-01-05 11:55:01 UTC (rev 9666)
@@ -14,6 +14,8 @@
 Current Version (SVN trunk):
+- Changed msSaveImageBufferGD to be in accordance with msSaveImageGD (#3201)
 - PHP/Mapscript: added layerObj units property (#3249)
 - Changed the query map rendering implementation without adding extra layers to the map (#3069)
Modified: trunk/mapserver/mapgd.c
--- trunk/mapserver/mapgd.c	2010-01-04 19:33:47 UTC (rev 9665)
+++ trunk/mapserver/mapgd.c	2010-01-05 11:55:01 UTC (rev 9666)
@@ -3506,100 +3506,14 @@
   unsigned char *imgbytes;
-  if(format->imagemode == MS_IMAGEMODE_RGBA)
-    gdImageSaveAlpha(img->img.gd, 1);
-  else if(format->imagemode == MS_IMAGEMODE_RGB)
-    gdImageSaveAlpha(img->img.gd, 0);
+   gdIOCtx *ctx = gdNewDynamicCtx (2048, NULL);
+  if (msSaveImageGDCtx( img, ctx, format ) == MS_SUCCESS)
+    imgbytes = gdDPExtractData (ctx, size_ptr);
+  else
+    imgbytes = NULL;
-  if(strcasecmp("ON", msGetOutputFormatOption(format, "INTERLACE", "ON" )) == 0)
-    gdImageInterlace(img->img.gd, 1);
+  ctx->gd_free(ctx);
-  if(format->transparent)
-    gdImageColorTransparent(img->img.gd, 0);
-  if(strcasecmp(format->driver, "gd/gif") == 0) {
-#ifdef USE_GD_GIF
-    imgbytes = gdImageGifPtr(img->img.gd, size_ptr);
-#else
-    msSetError(MS_IMGERR, "GIF output is not available.", "msSaveImageBufferGD()");
-    return NULL;
-#endif
-  } else if (strcasecmp(format->driver, "gd/png") == 0) {
-#ifdef USE_GD_PNG
-    int force_pc256 = MS_FALSE;
-    int force_palette = MS_FALSE;
-    if( format->imagemode == MS_IMAGEMODE_RGB  || format->imagemode == MS_IMAGEMODE_RGBA ) {
-      const char *force_string = msGetOutputFormatOption( format, "QUANTIZE_FORCE", "OFF" );
-      if( strcasecmp(force_string,"on") == 0  || strcasecmp(force_string,"yes") == 0 || strcasecmp(force_string,"true") == 0 )
-        force_pc256 = MS_TRUE;
-      force_string = msGetOutputFormatOption( format, "PALETTE_FORCE", "OFF" );
-        force_palette = MS_TRUE;
-    if( force_palette ) {
-      gdImagePtr gdPImg;
-      int method=0;
-      const char *palette = msGetOutputFormatOption( format, "PALETTE", "palette.txt");
-      const char *palette_method = msGetOutputFormatOption( format, "PALETTE_MEM", "0");
-      if(strcasecmp(palette_method,"conservative")==0)
-          method=1;
-      else if(strcasecmp(palette_method,"liberal")==0)
-          method=2;
-      gdPImg = msImageCreateWithPaletteGD(img->img.gd, palette, gdImageSX(img->img.gd), gdImageSY(img->img.gd));
-      if(!gdPImg) return NULL; /* most likely a bad palette */
-      msImageCopyForcePaletteGD(img->img.gd, gdPImg, method);
-      imgbytes = gdImagePngPtr(gdPImg, size_ptr);
-      gdImageDestroy(gdPImg);
-    else if ( force_pc256 ) {
-      int dither, i;
-      int colorsWanted = atoi(msGetOutputFormatOption( format, "QUANTIZE_COLORS", "256"));
-      const char *dither_string = msGetOutputFormatOption( format, "QUANTIZE_DITHER", "YES");
-      if( strcasecmp(dither_string,"on") == 0 || strcasecmp(dither_string,"yes") == 0 || strcasecmp(dither_string,"true") == 0 )
-        dither = 1;
-      else
-        dither = 0;
-      gdPImg = gdImageCreatePaletteFromTrueColor(img->img.gd,dither,colorsWanted);
-      /* It seems there is a bug in gd 2.0.33 and earlier that leaves the
-         colors open[] flag set to one. */
-      for( i = 0; i < gdPImg->colorsTotal; i++ )
-        gdPImg->open[i] = 0;
-    else
-      imgbytes = gdImagePngPtr(img->img.gd, size_ptr);
-#else
-    msSetError(MS_IMGERR, "PNG output is not available.", "msSaveImageBufferGD()");
-    return NULL;
-#endif
-  } else if (strcasecmp(format->driver, "gd/jpeg") == 0) {
-#ifdef USE_GD_JPEG
-    imgbytes = gdImageJpegPtr(img->img.gd, size_ptr, atoi(msGetOutputFormatOption(format, "QUALITY", "75" )));
-#else
-    msSetError(MS_IMGERR, "JPEG output is not available.", "msSaveImageBufferGD()");
-    return NULL;
-#endif
-  } else if (strcasecmp(format->driver, "gd/wbmp") == 0) {
-#ifdef USE_GD_WBMP
-    imgbytes = gdImageWBMPPtr(img->img.gd, size_ptr, 1);
-#else
-    msSetError(MS_IMGERR, "WBMP output is not available.", "msSaveImageBufferGD()");
-    return NULL;
-#endif
-  } else {
-    msSetError(MS_IMGERR, "Unknown output image type driver: %s.", "msSaveImageBufferGD()", format->driver );
-    return NULL;
   return imgbytes;
