[mapserver-commits] r9708 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Jan 18 13:22:37 EST 2010
Author: aboudreault
Date: 2010-01-18 13:22:36 -0500 (Mon, 18 Jan 2010)
New Revision: 9708
trunk/mapserver/HISTORY.TXT
trunk/mapserver/configure
trunk/mapserver/configure.in
trunk/mapserver/maphttp.c
Fixed curl proxy auth support for http connections (#571)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2010-01-18 17:47:01 UTC (rev 9707)
+++ trunk/mapserver/HISTORY.TXT 2010-01-18 18:22:36 UTC (rev 9708)
@@ -14,6 +14,8 @@
Current Version (SVN trunk):
+- Fixed curl proxy auth support for http connections (#571)
- PHP/MapScript: removed deprecated class properties (#2170)
- Fixed OGR datasource double free (#3261)
Modified: trunk/mapserver/configure
--- trunk/mapserver/configure 2010-01-18 17:47:01 UTC (rev 9707)
+++ trunk/mapserver/configure 2010-01-18 18:22:36 UTC (rev 9708)
@@ -11917,6 +11917,7 @@
CURL_VERNUM=`$LIBCURL_CONFIG --vernum`
CURL_VER=`$LIBCURL_CONFIG --version | awk '{print $2}'`
+ CURL_FLAGS=""
echo "$as_me:$LINENO: result: found libcurl version $CURL_VER" >&5
echo "${ECHO_T} found libcurl version $CURL_VER" >&6
@@ -11927,6 +11928,17 @@
{ (exit 1); exit 1; }; }
fi
+ echo "$as_me:$LINENO: checking for CURLOPT_PROXYAUTH support" >&5
+echo $ECHO_N "checking for CURLOPT_PROXYAUTH support... $ECHO_C" >&6
+ if test -z "$CURL_VERNUM" -o `expr "0x$CURL_VERNUM" \>= "0x070a07"` = 1; then
+ echo "$as_me:$LINENO: result: yes." >&5
+echo "${ECHO_T}yes." >&6
+ CURL_FLAGS="-DUSE_CURLOPT_PROXYAUTH"
+ else
+ echo "$as_me:$LINENO: result: no." >&5
+echo "${ECHO_T}no." >&6
+ fi
if test "$WMS_REQUESTED" = "yes" ; then
WMS_LYR_ENABLED="-DUSE_WMS_LYR"
echo "$as_me:$LINENO: result: OGC WMS Client Connections enabled ($WMS_LYR_ENABLED)." >&5
@@ -11941,7 +11953,7 @@
CURL_INC=`$LIBCURL_CONFIG --cflags`
CURL_LIB=`$LIBCURL_CONFIG --libs`
- CURL_ENABLED=-DUSE_CURL
+ CURL_ENABLED="-DUSE_CURL $CURL_FLAGS"
fi
Modified: trunk/mapserver/configure.in
--- trunk/mapserver/configure.in 2010-01-18 17:47:01 UTC (rev 9707)
+++ trunk/mapserver/configure.in 2010-01-18 18:22:36 UTC (rev 9708)
@@ -1923,6 +1923,7 @@
+ CURL_FLAGS=""
AC_MSG_RESULT([ found libcurl version $CURL_VER])
@@ -1931,6 +1932,15 @@
AC_MSG_ERROR([libcurl version 7.10.1 or more recent is required.])
fi
+ dnl Verify if the the PROXYAUTH support is avaible (>= 7.10.7)
+ AC_MSG_CHECKING(for CURLOPT_PROXYAUTH support)
+ AC_MSG_RESULT([yes.])
+ else
+ AC_MSG_RESULT([no.])
+ fi
dnl set WMS_LYR_ENABLED/WFS_LYR_ENABLED here, Makefile substitutions are
dnl done only further down, after checking for libxml2
@@ -1945,7 +1955,7 @@
fi
Modified: trunk/mapserver/maphttp.c
--- trunk/mapserver/maphttp.c 2010-01-18 17:47:01 UTC (rev 9707)
+++ trunk/mapserver/maphttp.c 2010-01-18 18:22:36 UTC (rev 9708)
@@ -442,7 +442,7 @@
&& strlen(pasReqInfo[i].pszProxyPassword) > 0)
char szUsernamePasswd[128];
-#ifdef CURLOPT_PROXYAUTH
+#ifdef USE_CURLOPT_PROXYAUTH
long nProxyAuthType = CURLAUTH_BASIC;
/* CURLOPT_PROXYAUTH available only in Curl 7.10.7 and up */
nProxyAuthType = msGetCURLAuthType(pasReqInfo[i].eProxyAuthType);
More information about the mapserver-commits
