[mapserver-commits] r9709 - branches/branch-5-6/mapserver
Mon Jan 18 13:55:31 EST 2010
Author: aboudreault
Date: 2010-01-18 13:55:29 -0500 (Mon, 18 Jan 2010)
New Revision: 9709
   branches/branch-5-6/mapserver/HISTORY.TXT
   branches/branch-5-6/mapserver/mapogr.cpp
Backporting implementation of RFC 52 LayerResultsGetShape support for OGR connection type in branch 5-6. (#3069)
Modified: branches/branch-5-6/mapserver/HISTORY.TXT
--- branches/branch-5-6/mapserver/HISTORY.TXT	2010-01-18 18:22:36 UTC (rev 9708)
+++ branches/branch-5-6/mapserver/HISTORY.TXT	2010-01-18 18:55:29 UTC (rev 9709)
@@ -15,6 +15,8 @@
 Current Version (SVN branch-5-6):
+- Implemented RFC 52 LayerResultsGetShape support for OGR connection type. (#3069)
 - Fixed problem with the oracle driver w/FUNCTION=NONE (#3260)
 Version 5.6.1 (2010-01-08):
Modified: branches/branch-5-6/mapserver/mapogr.cpp
--- branches/branch-5-6/mapserver/mapogr.cpp	2010-01-18 18:22:36 UTC (rev 9708)
+++ branches/branch-5-6/mapserver/mapogr.cpp	2010-01-18 18:55:29 UTC (rev 9709)
@@ -75,6 +75,8 @@
   struct ms_ogr_file_info_t *poCurTile; /* exists on tile index, -> tiles */
   rectObj     rect;                     /* set by WhichShapes */
+  int         last_record_index_read;
 } msOGRFileInfo;
 static int msOGRLayerIsOpen(layerObj *layer);
@@ -1485,6 +1487,7 @@
   psInfo->poCurTile = NULL;
   psInfo->rect.minx = psInfo->rect.maxx = 0;
   psInfo->rect.miny = psInfo->rect.maxy = 0;
+  psInfo->last_record_index_read = -1;
   return psInfo;
@@ -1629,6 +1632,7 @@
  * Reset current feature pointer
   OGR_L_ResetReading( psInfo->hLayer );
   RELEASE_OGR_LOCK;
@@ -1741,6 +1745,7 @@
       if( (hFeature = OGR_L_GetNextFeature( psInfo->hLayer )) == NULL )
           if( CPLGetLastErrorType() == CE_Failure )
               msSetError(MS_OGRERR, "%s", "msOGRFileNextShape()",
@@ -1757,6 +1762,8 @@
+      psInfo->last_record_index_read++;
       if(layer->numitems > 0)
           shape->values = msOGRGetValues(layer, hFeature);
@@ -1804,7 +1811,7 @@
       shape->type = MS_SHAPE_NULL;
-  shape->index = OGR_F_GetFID( hFeature );
+  shape->index = psInfo->last_record_index_read;
   shape->tileindex = psInfo->nTileId;
   if (layer->debug >= MS_DEBUGLEVEL_VVV)
@@ -1830,7 +1837,7 @@
 static int
 msOGRFileGetShape(layerObj *layer, shapeObj *shape, long record,
-                  msOGRFileInfo *psInfo )
+                  msOGRFileInfo *psInfo, int record_is_fid )
   OGRFeatureH hFeature;
@@ -1841,19 +1848,59 @@
     return(MS_FAILURE);
- * Handle shape geometry...
+/*      Clear previously loaded shape.                                  */
   msFreeShape(shape);
-  ACQUIRE_OGR_LOCK;
-  if( (hFeature = OGR_L_GetFeature( psInfo->hLayer, record )) == NULL )
+/*      Support reading feature by fid.                                 */
+  if( record_is_fid )
-      RELEASE_OGR_LOCK;
-      return MS_FAILURE;
+      ACQUIRE_OGR_LOCK;
+      if( (hFeature = OGR_L_GetFeature( psInfo->hLayer, record )) == NULL )
+          RELEASE_OGR_LOCK;
+          return MS_FAILURE;
+/*      Support reading shape by offset within the current              */
+/*      resultset.                                                      */
+  else if( !record_is_fid )
+      ACQUIRE_OGR_LOCK;
+      if( record <= psInfo->last_record_index_read
+          || psInfo->last_record_index_read == -1 )
+          OGR_L_ResetReading( psInfo->hLayer );
+      hFeature = NULL;
+      while( psInfo->last_record_index_read < record )
+          if( hFeature != NULL )
+              OGR_F_Destroy( hFeature );
+              hFeature = NULL;
+          if( (hFeature = OGR_L_GetNextFeature( psInfo->hLayer )) == NULL )
+              RELEASE_OGR_LOCK;
+ * Handle shape geometry...
   // shape->type will be set if geom is compatible with layer type
   if (ogrConvertGeometry(OGR_F_GetGeometryRef( hFeature ), shape,
                          layer->type) != MS_SUCCESS)
@@ -1886,7 +1933,7 @@
+  shape->index = record;
   // Keep ref. to last feature read in case we need style info.
@@ -2509,12 +2556,12 @@
  *                     msOGRLayerGetShape()
- * Returns shape from OGR data source by id.
+ * Returns shape from OGR data source by fid.
  * Returns MS_SUCCESS/MS_FAILURE
 int msOGRLayerGetShape(layerObj *layer, shapeObj *shape, int tile,
-                       long record)
+                       long fid)
 #ifdef USE_OGR
   msOGRFileInfo *psInfo =(msOGRFileInfo*)layer->layerinfo;
@@ -2527,7 +2574,7 @@
   if( layer->tileindex == NULL )
-      return msOGRFileGetShape(layer, shape, record, psInfo );
+      return msOGRFileGetShape(layer, shape, fid, psInfo, TRUE );
   else
       if( psInfo->poCurTile == NULL
@@ -2537,7 +2584,7 @@
               return MS_FAILURE;
-      return msOGRFileGetShape(layer, shape, record, psInfo->poCurTile );
+      return msOGRFileGetShape(layer, shape, fid, psInfo->poCurTile, TRUE );
 #else
@@ -2552,6 +2599,52 @@
+ *                     msOGRLayerResultGetShape()
+ * Returns shape from OGR data source by index into the current results
+ * set.
+ * Returns MS_SUCCESS/MS_FAILURE
+int msOGRLayerResultGetShape(layerObj *layer, shapeObj *shape, int tile,
+                             long record)
+#ifdef USE_OGR
+  msOGRFileInfo *psInfo =(msOGRFileInfo*)layer->layerinfo;
+  if (psInfo == NULL || psInfo->hLayer == NULL)
+    msSetError(MS_MISCERR, "Assertion failed: OGR layer not opened!!!",
+               "msOGRLayerNextShape()");
+    return(MS_FAILURE);
+  if( layer->tileindex == NULL )
+      return msOGRFileGetShape(layer, shape, record, psInfo, FALSE );
+  else
+      if( psInfo->poCurTile == NULL
+          || psInfo->poCurTile->nTileId != tile )
+          if( msOGRFileReadTile( layer, psInfo, tile ) != MS_SUCCESS )
+      return msOGRFileGetShape(layer, shape, record, psInfo->poCurTile, FALSE );
+#else
+ * OGR Support not included...
+  msSetError(MS_MISCERR, "OGR support is not available.",
+             "msOGRLayerGetShape()");
+#endif /* USE_OGR */
  *                     msOGRLayerGetExtent()
  * Returns the layer extents.
@@ -2684,12 +2777,13 @@
   ACQUIRE_OGR_LOCK;
   if (psInfo->hLastFeature == NULL ||
-      OGR_F_GetFID( psInfo->hLastFeature ) != record)
+      psInfo->last_record_index_read != record)
-      if (psInfo->hLastFeature)
-          OGR_F_Destroy( psInfo->hLastFeature );
-      psInfo->hLastFeature = OGR_L_GetFeature( psInfo->hLayer, record );
+      RELEASE_OGR_LOCK;
+                 "Assertion failed: AutoStyle not requested on loaded shape.",
+                 "msOGRLayerGetAutoStyle()");
@@ -3378,7 +3472,7 @@
     layer->vtable->LayerIsOpen = msOGRLayerIsOpen;
     layer->vtable->LayerWhichShapes = msOGRLayerWhichShapes;
     layer->vtable->LayerNextShape = msOGRLayerNextShape;
-    layer->vtable->LayerResultsGetShape = msOGRLayerGetShape; /* no special version, use ...GetShape() */
+    layer->vtable->LayerResultsGetShape = msOGRLayerResultGetShape;
     layer->vtable->LayerGetShape = msOGRLayerGetShape;
     layer->vtable->LayerClose = msOGRLayerClose;
     layer->vtable->LayerGetItems = msOGRLayerGetItems;
