[mapserver-commits] r10317 - branches/branch-4-10/mapserver
Thu Jul 8 17:14:44 EDT 2010
Author: dmorissette
Date: 2010-07-08 21:14:44 +0000 (Thu, 08 Jul 2010)
New Revision: 10317
   branches/branch-4-10/mapserver/HISTORY.TXT
   branches/branch-4-10/mapserver/README.CONFIGURE
   branches/branch-4-10/mapserver/configure
   branches/branch-4-10/mapserver/configure.in
   branches/branch-4-10/mapserver/mapserv.c
Disable insecure mapserv cgi command-line debug params by default (#3485)
Modified: branches/branch-4-10/mapserver/HISTORY.TXT
--- branches/branch-4-10/mapserver/HISTORY.TXT	2010-07-08 21:13:49 UTC (rev 10316)
+++ branches/branch-4-10/mapserver/HISTORY.TXT	2010-07-08 21:14:44 UTC (rev 10317)
@@ -13,7 +13,14 @@
 Current Version (SVN branch, may never be released):
+- Disabled some insecure (and potentially exploitable) mapserv command-line
+  debug arguments (#3485). The --enable-cgi-cl-debug-args configure switch
+  can be used to re-enable them for devs who really cannot get away without
+  them and who understand the potential security risk (not recommended for
+  production servers or those who don't understand the security implications).
+- Fixed possible buffer overflow in msTmpFile() (#3484)
 Version 4.10.5 (2009-07-23)
Modified: branches/branch-4-10/mapserver/README.CONFIGURE
--- branches/branch-4-10/mapserver/README.CONFIGURE	2010-07-08 21:13:49 UTC (rev 10316)
+++ branches/branch-4-10/mapserver/README.CONFIGURE	2010-07-08 21:14:44 UTC (rev 10317)
@@ -89,6 +89,12 @@
                           msDebug() output to stderr (i.e. server log file).
   --disable-debug         Do not include -g in CFLAGS and disable msDebug()
                           output (the default).
+  --enable-cgi-cl-debug-args
+                          Enable mapserv CGI command-line debug arguments
+                          (disabled by default). These command-line args may
+                          be insecure and should be enabled only on
+                          development servers and only if you understand the
+                          security implications.
   --with-php=DIR          Specify directory where PHP4's include files are
                           installed (or a pointer to the full source tree)
                           Required in order to compile the PHP/MapScript
@@ -534,6 +540,13 @@
   --enable-runpath        Include runtime library path flags (-Wl,-R) in link.
                           Required on *BSD systems.
   --disable-runpath       Do not link with runtime lib path (the default).
Modified: branches/branch-4-10/mapserver/configure
--- branches/branch-4-10/mapserver/configure	2010-07-08 21:13:49 UTC (rev 10316)
+++ branches/branch-4-10/mapserver/configure	2010-07-08 21:14:44 UTC (rev 10317)
@@ -820,6 +820,12 @@
   --disable-debug         Do not include "-g" in CFLAGS and disable msDebug()
   --enable-coverage       Enable coverage testing
   --enable-perlv-ld-detect (applies to --with-php only)
                           Use perl -V output to figure the command to use to
@@ -1002,7 +1008,7 @@
     else
       echo "$as_me: WARNING: no configuration information is in $ac_dir" >&2
     fi
-    cd "$ac_popdir"
+    cd $ac_popdir
   done
 fi
@@ -1918,7 +1924,8 @@
   cat conftest.err >&5
   echo "$as_me:$LINENO: \$? = $ac_status" >&5
   (exit $ac_status); } &&
-	 { ac_try='test -z "$ac_c_werror_flag"			 || test ! -s conftest.err'
+	 { ac_try='test -z "$ac_c_werror_flag"
+			 || test ! -s conftest.err'
   { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -1976,7 +1983,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -2092,7 +2100,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -2146,7 +2155,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -2191,7 +2201,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -2235,7 +2246,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -2419,7 +2431,8 @@
-	 { ac_try='test -z "$ac_cxx_werror_flag"			 || test ! -s conftest.err'
+	 { ac_try='test -z "$ac_cxx_werror_flag"
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -2477,7 +2490,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -2548,7 +2562,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -2592,7 +2607,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -2787,7 +2803,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -2853,7 +2870,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -2942,7 +2960,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -3051,7 +3070,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -3114,7 +3134,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -3178,7 +3199,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -3254,7 +3276,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -3324,7 +3347,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -3641,7 +3665,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -3854,7 +3879,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -3949,7 +3975,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -4044,7 +4071,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -4139,7 +4167,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -4234,7 +4263,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -4448,7 +4478,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -4617,7 +4648,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -4766,7 +4798,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -4921,7 +4954,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -5004,7 +5038,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -5150,7 +5185,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -5265,7 +5301,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -5332,7 +5369,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -5436,7 +5474,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -5503,7 +5542,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -5671,7 +5711,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -5743,7 +5784,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -5856,7 +5898,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -5928,7 +5971,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6055,7 +6099,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6123,7 +6168,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6191,7 +6237,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6259,7 +6306,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6328,7 +6376,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6397,7 +6446,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6466,7 +6516,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6535,7 +6586,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6609,7 +6661,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6682,7 +6735,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6749,7 +6803,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6816,7 +6871,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6883,7 +6939,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6951,7 +7008,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7019,7 +7077,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7087,7 +7146,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7155,7 +7215,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7335,7 +7396,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7402,7 +7464,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7469,7 +7532,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7536,7 +7600,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7603,7 +7668,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7739,7 +7805,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7806,7 +7873,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7944,7 +8012,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -8055,7 +8124,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -8179,7 +8249,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -8243,7 +8314,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -8304,7 +8376,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -8365,7 +8438,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -8458,7 +8532,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -8519,7 +8594,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -8580,7 +8656,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -9112,7 +9189,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -9903,7 +9981,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -10206,6 +10285,21 @@
   CFLAGS=`echo "$CFLAGS " | sed "s/-g //"`
 fi
+{ echo "$as_me:$LINENO: checking whether we should enable mapserv CGI command-line debug arguments..." >&5
+echo "$as_me: checking whether we should enable mapserv CGI command-line debug arguments..." >&6;}
+# Check whether --enable-cgi-cl-debug-args or --disable-cgi-cl-debug-args was given.
+if test "${enable_cgi_cl_debug_args+set}" = set; then
+  enableval="$enable_cgi_cl_debug_args"
+fi;
+if test "$enable_cgi_cl_debug_args" = "yes" ; then
+  DEBUG_FLAGS="$DEBUG_FLAGS -DMS_ENABLE_CGI_CL_DEBUG_ARGS"
+  echo "$as_me:$LINENO: result:         Enabling (potentially insecure) mapserv CGI command-line debug arguments: -DMS_ENABLE_CGI_CL_DEBUG_ARGS." >&5
+echo "${ECHO_T}        Enabling (potentially insecure) mapserv CGI command-line debug arguments: -DMS_ENABLE_CGI_CL_DEBUG_ARGS." >&6
+fi
 DEBUG_FLAGS=$DEBUG_FLAGS
 ALL_ENABLED="$DEBUG_FLAGS $ALL_ENABLED"
@@ -11838,6 +11932,11 @@
+  if test x"$ac_file" != x-; then
+    { echo "$as_me:$LINENO: creating $ac_file" >&5
+echo "$as_me: creating $ac_file" >&6;}
+    rm -f "$ac_file"
+  fi
   # Let's still pretend it is `configure' which instantiates (i.e., don't
   # use $as_me), people would be surprised to read:
   #    /* config.h.  Generated by config.status.  */
@@ -11876,12 +11975,6 @@
 	 fi;;
       esac
     done` || { (exit 1); exit 1; }
-  if test x"$ac_file" != x-; then
-    { echo "$as_me:$LINENO: creating $ac_file" >&5
-echo "$as_me: creating $ac_file" >&6;}
-    rm -f "$ac_file"
-  fi
 _ACEOF
 cat >>$CONFIG_STATUS <<_ACEOF
   sed "$ac_vpsub
Modified: branches/branch-4-10/mapserver/configure.in
--- branches/branch-4-10/mapserver/configure.in	2010-07-08 21:13:49 UTC (rev 10316)
+++ branches/branch-4-10/mapserver/configure.in	2010-07-08 21:14:44 UTC (rev 10317)
@@ -1852,6 +1852,24 @@
 fi
+dnl ---------------------------------------------------------------------
+dnl Check --enable-cgi-cl-debug-args option (OFF by default)
+AC_CHECKING(whether we should enable mapserv CGI command-line debug arguments)
+AC_ARG_ENABLE(cgi-cl-debug-args,
+[  --enable-cgi-cl-debug-args
+                          security implications.],,)
+  AC_MSG_RESULT([        Enabling (potentially insecure) mapserv CGI command-line debug arguments: -DMS_ENABLE_CGI_CL_DEBUG_ARGS.])
+fi
 AC_SUBST(DEBUG_FLAGS, $DEBUG_FLAGS)
Modified: branches/branch-4-10/mapserver/mapserv.c
--- branches/branch-4-10/mapserver/mapserv.c	2010-07-08 21:13:49 UTC (rev 10316)
+++ branches/branch-4-10/mapserver/mapserv.c	2010-07-08 21:14:44 UTC (rev 10317)
@@ -1164,11 +1164,21 @@
     for( iArg = 1; iArg < argc; iArg++ )
+        /* Keep only "-v" and "QUERY_STRING=..." enabled by default.
+         * The others will require an explicit -DMS_ENABLE_CGI_CL_DEBUG_ARGS
+         * at compile time.
         if( strcmp(argv[iArg],"-v") == 0 ) {
             printf("%s\n", msGetVersion());
             fflush(stdout);
             exit(0);
+        else if ( strncmp(argv[iArg], "QUERY_STRING=", 13) == 0) {
+            /* Debugging hook... pass "QUERY_STRING=..." on the command-line */
+            putenv( "REQUEST_METHOD=GET" );
+            putenv( argv[1] );
+#ifdef MS_ENABLE_CGI_CL_DEBUG_ARGS
         else if( iArg < argc-1 && strcmp(argv[iArg], "-tmpbase") == 0) {
             msForceTmpFileBase( argv[++iArg] );
@@ -1189,11 +1199,7 @@
             exit(0);
-        else if ( strncmp(argv[iArg], "QUERY_STRING=", 13) == 0) {
-            /* Debugging hook... pass "QUERY_STRING=..." on the command-line */
-            putenv( "REQUEST_METHOD=GET" );
-            putenv( argv[1] );
+#endif /* MS_ENABLE_CGI_CL_DEBUG_ARGS */
         else
             /* we don't produce a usage message as some web servers pass
