[mapserver-commits] r10415 - trunk/docs/en/mapfile
Thu Jul 29 15:03:38 EDT 2010
Author: jmckenna
Date: 2010-07-29 19:03:38 +0000 (Thu, 29 Jul 2010)
New Revision: 10415
   trunk/docs/en/mapfile/layer.txt
add min/maxgeowidth parameters (ticket:2738)
Modified: trunk/docs/en/mapfile/layer.txt
--- trunk/docs/en/mapfile/layer.txt	2010-07-29 18:58:02 UTC (rev 10414)
+++ trunk/docs/en/mapfile/layer.txt	2010-07-29 19:03:38 UTC (rev 10415)
@@ -275,6 +275,16 @@
 .. index::
     pair: MAXSCALEDENOM; LAYER
+MAXGEOWIDTH [double]
+    Maximum width, in the map's geographic units, at which this LAYER is drawn.
+    If MAXSCALEDENOM is also specified then MAXSCALEDENOM will be used instead.
+    *(added in MapServer 5.4.0)*
+    The width of a map in geographic units can be found by calculating the
+    following from the extents::
+      [maxx] - [minx]
 MAXSCALEDENOM [double]
     Maximum scale at which this LAYER is drawn.  Scale is given as the
@@ -312,6 +322,16 @@
 .. index::
     pair: MINSCALEDENOM; LAYER
+MINGEOWIDTH [double]
+    Minimum width, in the map's geographic units, at which this LAYER is drawn.
+    If MINSCALEDENOM is also specified then MINSCALEDENOM will be used instead.
+      [maxx] - [minx]
 MINSCALEDENOM [double]
     Minimum scale at which this LAYER is drawn.  Scale is given as the
     denominator of the actual scale fraction, for example for a map at a scale
