[mapserver-commits] r10416 - branches/branch-5-6/docs/en/mapfile
Thu Jul 29 15:43:28 EDT 2010
Author: jmckenna
Date: 2010-07-29 19:43:27 +0000 (Thu, 29 Jul 2010)
New Revision: 10416
   branches/branch-5-6/docs/en/mapfile/layer.txt
add PLUGIN parameter (ticket:3135)
Modified: branches/branch-5-6/docs/en/mapfile/layer.txt
--- branches/branch-5-6/docs/en/mapfile/layer.txt	2010-07-29 19:03:38 UTC (rev 10415)
+++ branches/branch-5-6/docs/en/mapfile/layer.txt	2010-07-29 19:43:27 UTC (rev 10416)
@@ -42,7 +42,7 @@
         See :ref:`vector` for specific connection information for various
         data sources.
-CONNECTIONTYPE [local|sde|ogr|postgis|oraclespatial|wms]
+CONNECTIONTYPE [local|sde|ogr|postgis|oraclespatial|wms|plugin]
     Type of connection. Default is local. See additional documentation for
     any other type.
@@ -374,7 +374,19 @@
     This is only needed in the case of RGB output formats, and should be used
     only when necessary as it is expensive to render transparent pixmap
     symbols onto an RGB map image.
+PLUGIN [filename]
+    Additional library to load by MapServer, for this layer.  This is commonly
+    used to load specific support for SDE and Microsoft SQL Server layers,
+    such as:
+      .. code-block:: mapfile
+        CONNECTIONTYPE PLUGIN
+        CONNECTION "hostname,port:xxx,database,username,password"
+        PLUGIN "C:/ms4w/Apache/specialplugins/msplugin_sde_92.dll"
+        DATA "layername,geometrycolumn,SDE.DEFAULT"
 POSTLABELCACHE [true|false]
     Tells MapServer to render this layer after all labels in the cache have
     been drawn. Useful for adding neatlines and similar elements.
