[mapserver-commits] r9948 - trunk/msautotest/mspython
Tue Mar 16 22:19:01 EDT 2010
Author: warmerdam
Date: 2010-03-16 22:19:00 -0400 (Tue, 16 Mar 2010)
New Revision: 9948
Added:
   trunk/msautotest/mspython/ogr_query.map
   trunk/msautotest/mspython/ogr_query.py
add ogr query testing
Added: trunk/msautotest/mspython/ogr_query.map
--- trunk/msautotest/mspython/ogr_query.map	                        (rev 0)
+++ trunk/msautotest/mspython/ogr_query.map	2010-03-17 02:19:00 UTC (rev 9948)
@@ -0,0 +1,31 @@
+# Simple OGR Render.
+# REQUIRES: INPUT=OGR OUTPUT=PNG
+MAP
+STATUS ON
+EXTENT 478300 4762880 481650 4765610
+SIZE 400 300
+IMAGETYPE png
+LAYER
+  NAME shppoly
+  TYPE polygon
+  DUMP TRUE
+  TEMPLATE "junk.tmpl"
+  CONNECTIONTYPE OGR
+  CONNECTION "../misc/data/shppoly"
+  DATA "poly"
+  STATUS default
+  CLASSITEM "AREA"
+  CLASS
+    NAME "test1"
+    COLOR 0 255 0
+    OUTLINECOLOR 255 0 0
+  END
+END
+END
Added: trunk/msautotest/mspython/ogr_query.py
--- trunk/msautotest/mspython/ogr_query.py	                        (rev 0)
+++ trunk/msautotest/mspython/ogr_query.py	2010-03-17 02:19:00 UTC (rev 9948)
@@ -0,0 +1,328 @@
+#!/usr/bin/env python
+# Project:  MapServer
+# Purpose:  Test OGR queries, partly intended to confirm correct operation
+#           after the one pass query overhaul.
+# Author:   Frank Warmerdam, warmerdam at pobox.com
+#  Copyright (c) 2010, Frank Warmerdam <warmerdam at pobox.com>
+#  Permission is hereby granted, free of charge, to any person obtaining a
+#  copy of this software and associated documentation files (the "Software"),
+#  to deal in the Software without restriction, including without limitation
+#  the rights to use, copy, modify, merge, publish, distribute, sublicense,
+#  and/or sell copies of the Software, and to permit persons to whom the
+#  Software is furnished to do so, subject to the following conditions:
+#  The above copyright notice and this permission notice shall be included
+#  in all copies or substantial portions of the Software.
+#  THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
+#  OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+#  FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+#  THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+#  LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+#  FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+#  DEALINGS IN THE SOFTWARE.
+import sys
+import math
+sys.path.append( '../pymod' )
+import pmstestlib
+import mapscript
+# Dump query result set ... used when debugging this test script.
+def dumpResultSet( layer ):
+    layer.open()
+    for i in range(1000):
+        result = layer.getResult( i )
+        if result is None:
+            break
+        print '(%d,%d)' % (result.shapeindex, result.tileindex)
+        s = layer.getFeature( result.shapeindex, result.tileindex )
+        for i in range(layer.numitems):
+            print '%s: %s' % (layer.getItem(i), s.getValue(i))
+    layer.close()
+# Open map and get working layer.
+def ogr_query_1():
+    pmstestlib.map = mapscript.mapObj('ogr_query.map')
+    pmstestlib.layer = pmstestlib.map.getLayer(0)
+    return 'success'
+# Execute region query.
+def ogr_query_2():
+    line = mapscript.lineObj()
+    line.add( mapscript.pointObj( 479000, 4763000 ) )
+    line.add( mapscript.pointObj( 480000, 4763000 ) )
+    line.add( mapscript.pointObj( 480000, 4764000 ) )
+    line.add( mapscript.pointObj( 479000, 4764000 ) )
+    poly = mapscript.shapeObj( mapscript.MS_SHAPE_POLYGON )
+    poly.add( line )
+    pmstestlib.layer.queryByShape( pmstestlib.map, poly )
+    return 'success'
+# Scan results, checking count and the first shape information.
+def ogr_query_3():
+    layer = pmstestlib.layer
+    # Check result count.
+    layer.open()
+    count = 0
+            break
+        count = count + 1
+    if count != 2:
+        pmstestlib.post_reason( 'got %d results instead of expected %d.' \
+                             % (count, 55) )
+        return 'fail'
+    # Check first shape attributes.
+    result = layer.getResult( 0 )
+    s = mapscript.shapeObj( mapscript.MS_SHAPE_POLYGON )
+    layer.resultsGetShape( s, result.shapeindex, result.tileindex )
+    if pmstestlib.check_items( layer, s,
+                               [('EAS_ID','        158')] ) == 0:
+        return 'fail'
+    # Check first shape geometry.
+    if s.type != mapscript.MS_SHAPE_POLYGON:
+        pmstestlib.post_reason( 'query result is not a polygon.' )
+        return 'fail'
+    if s.numlines != 1:
+        pmstestlib.post_reason( 'query has other than 1 lines.' )
+        return 'fail'
+    try:
+        l = s.getLine( 0 )
+    except:
+        l = s.get( 0 )
+    if l.numpoints != 61:
+        pmstestlib.post_reason( 'raster query has %d points, instead of expected number.' % l.numpoints )
+        return 'fail'
+    try:
+        p = l.getPoint(0)
+    except:
+        p = l.get(5)
+    if abs(p.x-480984.25) > 0.01 or abs(p.y-4764875.0) > 0.01:
+        print p.x, p.y
+        pmstestlib.post_reason( 'got wrong location.' )
+        return 'fail'
+    # Check last shape attributes.
+    result = layer.getResult( 1 )
+                               [('EAS_ID','        165')] ) == 0:
+        return 'fail'
+    layer.close()
+    layer.close() # discard resultset.
+    return 'success'
+# Execute multiple point query, and check result.
+def ogr_query_4():
+    rect = mapscript.rectObj()
+    rect.minx = 479000
+    rect.maxx = 480000
+    rect.miny = 4763000
+    rect.maxy = 4764000
+    pmstestlib.layer.queryByRect( pmstestlib.map, rect )
+    return 'success'
+def ogr_query_5():
+    layer.open()
+    count = 0
+            break
+        count = count + 1
+    if count != 2:
+                             % (count, 55) )
+        return 'fail'
+        return 'fail'
+        return 'fail'
+        return 'fail'
+    try:
+    except:
+        l = s.get( 0 )
+        return 'fail'
+    try:
+        p = l.getPoint(0)
+    except:
+        p = l.get(5)
+        print p.x, p.y
+        return 'fail'
+        return 'fail'
+    layer.close()
+    return 'success'
+# Change the map extents and see if our query results have been altered.
+# With the current implementation they will be.
+def ogr_query_6():
+    map = pmstestlib.map
+    map.draw()
+    layer.open()
+    count = 0
+            break
+        count = count + 1
+    if count != 2:
+                             % (count, 55) )
+        return 'fail'
+                               [('EAS_ID','        168')] ) == 0:
+        return 'fail'
+    layer.close()
+    return 'success'
+# Cleanup.
+def ogr_query_cleanup():
+    pmstestlib.layer = None
+    pmstestlib.map = None
+    return 'success'
+test_list = [
+    ogr_query_1,
+    ogr_query_2,
+    ogr_query_3,
+    ogr_query_4,
+    ogr_query_5,
+    ogr_query_6,
+    ogr_query_cleanup ]
+if __name__ == '__main__':
+    pmstestlib.setup_run( 'ogr_query' )
+    pmstestlib.run_tests( test_list )
+    pmstestlib.summarize()
+    mapscript.msCleanup()
Property changes on: trunk/msautotest/mspython/ogr_query.py
___________________________________________________________________
Added: svn:executable
