[mapserver-commits] r9949 - trunk/msautotest/mspython
Tue Mar 16 22:25:35 EDT 2010
Author: warmerdam
Date: 2010-03-16 22:25:35 -0400 (Tue, 16 Mar 2010)
New Revision: 9949
   trunk/msautotest/mspython/ogr_query.py
do some modest testing of OGR queries
Modified: trunk/msautotest/mspython/ogr_query.py
--- trunk/msautotest/mspython/ogr_query.py	2010-03-17 02:19:00 UTC (rev 9948)
+++ trunk/msautotest/mspython/ogr_query.py	2010-03-17 02:25:35 UTC (rev 9949)
@@ -257,10 +257,37 @@
     return 'success'
+# Confirm that we can still fetch features not in the result set directly
+# by their feature id.
+def ogr_query_6():
+    layer = pmstestlib.layer
+    layer.open()
+    # Check first shape attributes.
+    result = layer.getResult( 0 )
+    s = mapscript.shapeObj( mapscript.MS_SHAPE_POLYGON )
+    layer.resultsGetShape( s, 9, 0 )
+    if pmstestlib.check_items( layer, s,
+                               [('EAS_ID','        170')] ) == 0:
+        return 'fail'
+    layer.close()
+    layer.close() # discard resultset.
+    return 'success'
 # Change the map extents and see if our query results have been altered.
-# With the current implementation they will be.
+# With the current implementation they will be, though this might be
+# considered to be a defect.
-def ogr_query_6():
+def ogr_query_7():
     map = pmstestlib.map
     map.draw()
@@ -314,6 +341,7 @@
     ogr_query_4,
     ogr_query_5,
     ogr_query_6,
+    ogr_query_7,
     ogr_query_cleanup ]
 if __name__ == '__main__':
