[mapserver-commits] r9950 - in trunk/mapserver: . mapscript/php mapscript/swiginc
Wed Mar 17 11:20:28 EDT 2010
Author: aboudreault
Date: 2010-03-17 11:20:27 -0400 (Wed, 17 Mar 2010)
New Revision: 9950
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/cgiutil.c
   trunk/mapserver/cgiutil.h
   trunk/mapserver/mapscript/php/mapscript_i.c
   trunk/mapserver/mapscript/php/owsrequest.c
   trunk/mapserver/mapscript/php/php_mapscript.c
   trunk/mapserver/mapscript/php/php_mapscript.h
   trunk/mapserver/mapscript/swiginc/owsrequest.i
   trunk/mapserver/mapserv.c
Fixed PHP/MapScript owsRequestObj->loadParams() method when using php in a non cgi/fcgi/cli mode. (#1975)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2010-03-17 02:25:35 UTC (rev 9949)
+++ trunk/mapserver/HISTORY.TXT	2010-03-17 15:20:27 UTC (rev 9950)
@@ -14,6 +14,8 @@
 Current Version (SVN trunk):
+- Fixed PHP/MapScript owsRequestObj->loadParams() method when using php in a non cgi/fcgi/cli mode. (#1975)
 - Ensure that non-file raster datasets work (#3253)
 - Correct mutex locking problem with rasters with no inherent georef. (#3368)
Modified: trunk/mapserver/cgiutil.c
--- trunk/mapserver/cgiutil.c	2010-03-17 02:25:35 UTC (rev 9949)
+++ trunk/mapserver/cgiutil.c	2010-03-17 15:20:27 UTC (rev 9950)
@@ -76,7 +76,6 @@
     data[data_max] = '\0';
     return data;
   /*      Otherwise read in chunks to the end.                            */
@@ -112,12 +111,24 @@
   return data;
-int loadParams(cgiRequestObj *request) {
+static char* msGetEnv(const char *name, void* thread_context)
+    return getenv(name);
+int loadParams(cgiRequestObj *request,
+               char* (*getenv2)(const char*, void* thread_context),
+               char *raw_post_data,
+               uint raw_post_data_length,
+               void* thread_context) {
   register int x,m=0;
-  char *s;
+  char *s, *queryString = NULL, *httpCookie = NULL;
   int debuglevel;
+  if (getenv2==NULL)
+      getenv2 = &msGetEnv;
-  if(getenv("REQUEST_METHOD")==NULL) {
+  if(getenv2("REQUEST_METHOD", thread_context)==NULL) {
     msIO_printf("This script can only be used to decode form results and \n");
     msIO_printf("should be initiated as a CGI process via a httpd server.\n");
     exit(0);
@@ -125,12 +136,12 @@
   debuglevel = (int)msGetGlobalDebugLevel();
-  if(strcmp(getenv("REQUEST_METHOD"),"POST") == 0) { /* we've got a post from a form */
+  if(strcmp(getenv2("REQUEST_METHOD", thread_context),"POST") == 0) { /* we've got a post from a form */
     char *post_data;
+    int data_len;
     request->type = MS_POST_REQUEST;
-    s = getenv("CONTENT_TYPE");
+    s = getenv2("CONTENT_TYPE", thread_context);
     if (s != NULL)
       request->contenttype = strdup(s);
      /* we've to set default content-type which is
@@ -138,11 +149,19 @@
       * W3 RFC 2626 section 7.2.1 */
     else request->contenttype = strdup("application/octet-stream");
-    post_data = readPostBody( request );
-    if(strcmp(request->contenttype, "application/x-www-form-urlencoded"))
-      request->postrequest = post_data;
+    if (raw_post_data) {
+        post_data = strdup(raw_post_data);
+        data_len = raw_post_data_length;
     else {
-      int data_len = strlen(post_data);
+        post_data = readPostBody( request );
+        data_len = strlen(post_data);
+    /* if the content_type is application/x-www-form-urlencoded,
+       we have to parse it like the QUERY_STRING variable */
+    if(strcmp(request->contenttype, "application/x-www-form-urlencoded") == 0)
       while( data_len > 0 && isspace(post_data[data_len-1]) )
         post_data[--data_len] = '\0';
@@ -151,7 +170,6 @@
           msIO_printf("Too many name/value pairs, aborting.\n");
           exit(0);
         request->ParamValues[m] = makeword(post_data,'&');
         plustospace(request->ParamValues[m]);
         unescape_url(request->ParamValues[m]);
@@ -160,20 +178,24 @@
       free( post_data );
+    else
+        request->postrequest = post_data;
     /* check the QUERY_STRING even in the post request since it can contain
        information. Eg a wfs request with  */
-    s = getenv("QUERY_STRING");
+    s = getenv2("QUERY_STRING", thread_context);
     if(s) {
       if (debuglevel >= MS_DEBUGLEVEL_DEBUG)
 		  msDebug("loadParams() QUERY_STRING: %s\n", s);
-      for(x=0;s[0] != '\0';x++) {
+      queryString = strdup(s);
+      for(x=0;queryString[0] != '\0';x++) {
         if(m >= MS_MAX_CGI_PARAMS) {
+          free(queryString);
           exit(0);
-        request->ParamValues[m] = makeword(s,'&');
+        request->ParamValues[m] = makeword(queryString,'&');
         request->ParamNames[m] = makeword(request->ParamValues[m],'=');
@@ -181,35 +203,38 @@
   } else {
-    if(strcmp(getenv("REQUEST_METHOD"),"GET") == 0) { /* we've got a get request */
+    if(strcmp(getenv2("REQUEST_METHOD", thread_context),"GET") == 0) { /* we've got a get request */
       request->type = MS_GET_REQUEST;
       if(s == NULL) {
         msIO_printf("Content-type: text/html%c%c",10,10);
         msIO_printf("No query information to decode. QUERY_STRING not set.\n");
         exit(1);
+      if (debuglevel >= MS_DEBUGLEVEL_DEBUG)
+          msDebug("loadParams() QUERY_STRING: %s\n", s);
-	  if (debuglevel >= MS_DEBUGLEVEL_DEBUG)
-		  msDebug("loadParams() QUERY_STRING: %s\n", s);
       if(strlen(s)==0) {
         msIO_printf("No query information to decode. QUERY_STRING is set, but empty.\n");
         exit(1);
-        if(m >= MS_MAX_CGI_PARAMS) {
+      /* don't modify the string returned by getenv2 */
+          if(m >= MS_MAX_CGI_PARAMS) {
           exit(0);
-        plustospace(request->ParamValues[m]);
-        unescape_url(request->ParamValues[m]);
-        request->ParamNames[m] = makeword(request->ParamValues[m],'=');
-        m++;
+          plustospace(request->ParamValues[m]);
+          unescape_url(request->ParamValues[m]);
+          request->ParamNames[m] = makeword(request->ParamValues[m],'=');
+          m++;
     } else {
@@ -219,21 +244,28 @@
   /* check for any available cookies */
-  s = getenv("HTTP_COOKIE");
+  s = getenv2("HTTP_COOKIE", thread_context);
   if(s != NULL) {
+    httpCookie = strdup(s);
     request->httpcookiedata = strdup(s);
+    for(x=0;httpCookie[0] != '\0';x++) {
+        free(httpCookie);
         exit(0);
-      request->ParamValues[m] = makeword(s,';');
+      request->ParamValues[m] = makeword(httpCookie,';');
       request->ParamNames[m] = makeword_skip(request->ParamValues[m],'=',' ');
       m++;
+  if (queryString)
+  if (httpCookie)
+      free(httpCookie);
   return(m);
@@ -270,12 +302,12 @@
 char *makeword(char *line, char stop) {
-  int x = 0,y;
+    int x = 0,y;
   char *word = (char *) malloc(sizeof(char) * (strlen(line) + 1));
   for(x=0;((line[x]) && (line[x] != stop));x++)
     word[x] = line[x];
   word[x] = '\0';
   if(line[x]) ++x;
   y=0;
Modified: trunk/mapserver/cgiutil.h
--- trunk/mapserver/cgiutil.h	2010-03-17 02:25:35 UTC (rev 9949)
+++ trunk/mapserver/cgiutil.h	2010-03-17 15:20:27 UTC (rev 9950)
@@ -74,7 +74,8 @@
 ** Function prototypes
 #ifndef SWIG
-MS_DLL_EXPORT  int loadParams(cgiRequestObj *);
+MS_DLL_EXPORT int loadParams(cgiRequestObj *request, char* (*getenv2)(const char*, void* thread_context),
+                             char *raw_post_data, uint raw_post_data_length, void* thread_context);
 MS_DLL_EXPORT void getword(char *, char *, char);
 MS_DLL_EXPORT char *makeword_skip(char *, char, char);
 MS_DLL_EXPORT char *makeword(char *, char);
Modified: trunk/mapserver/mapscript/php/mapscript_i.c
--- trunk/mapserver/mapscript/php/mapscript_i.c	2010-03-17 02:25:35 UTC (rev 9949)
+++ trunk/mapserver/mapscript/php/mapscript_i.c	2010-03-17 15:20:27 UTC (rev 9950)
@@ -1422,10 +1422,14 @@
     return request;
-int cgirequestObj_loadParams(cgiRequestObj *self)
+int cgirequestObj_loadParams(cgiRequestObj *self,
-  self->NumParams = loadParams(self);
-  return self->NumParams;
+    self->NumParams = loadParams(self, getenv2, raw_post_data, raw_post_data_length, thread_context);
+    return self->NumParams;
Modified: trunk/mapserver/mapscript/php/owsrequest.c
--- trunk/mapserver/mapscript/php/owsrequest.c	2010-03-17 02:25:35 UTC (rev 9949)
+++ trunk/mapserver/mapscript/php/owsrequest.c	2010-03-17 15:20:27 UTC (rev 9950)
@@ -30,7 +30,11 @@
 #include "php_mapscript.h"
+#include "SAPI.h"
+#include "php_variables.h"
+char *owsrequest_getenv(const char *name, void *thread_context);
 zend_class_entry *mapscript_ce_owsrequest;
 ZEND_BEGIN_ARG_INFO_EX(owsrequest___get_args, 0, 0, 1)
@@ -148,8 +152,16 @@
 PHP_METHOD(OWSRequestObj, loadParams)
     zval *zobj = getThis();
+    zval **val;
     php_owsrequest_object *php_owsrequest;
+    void *thread_context;
+#ifdef ZTS
+    thread_context = (void*)TSRMLS_C;
+#else
+    thread_context = NULL;
+#endif
     PHP_MAPSCRIPT_ERROR_HANDLING(TRUE);
     if (zend_parse_parameters_none() == FAILURE) {
         PHP_MAPSCRIPT_RESTORE_ERRORS(TRUE);
@@ -159,8 +171,35 @@
     php_owsrequest = (php_owsrequest_object *) zend_object_store_get_object(zobj TSRMLS_CC);
-    cgirequestObj_loadParams(php_owsrequest->cgirequest);
+    if ( (STRING_EQUAL(sapi_module.name,"cli")) ||
+         (STRING_EQUAL(sapi_module.name,"cgi")) ||
+         (STRING_EQUAL(sapi_module.name,"cgi-fcgi")) )
+        cgirequestObj_loadParams(php_owsrequest->cgirequest, NULL, NULL, 0, thread_context);
+    else
+        // check if we have input data for GET method
+        if (SG(request_info).request_method &&
+            STRING_EQUAL(SG(request_info).request_method, "GET"))
+            zend_is_auto_global("_SERVER", sizeof("_SERVER")-1 TSRMLS_CC);
+            if ( PG(http_globals)[TRACK_VARS_SERVER] &&
+                 (zend_hash_find(PG(http_globals)[TRACK_VARS_SERVER]->value.ht, "QUERY_STRING", sizeof("QUERY_STRING"), (void **) &val) == SUCCESS) &&
+                 (Z_TYPE_PP(val) == IS_STRING) &&
+                 (Z_STRLEN_PP(val) > 0) )
+                cgirequestObj_loadParams(php_owsrequest->cgirequest, owsrequest_getenv, NULL, 0, thread_context);
+        else
+                                     SG(request_info).raw_post_data,
+                                     SG(request_info).raw_post_data_length, thread_context);
     RETURN_LONG(php_owsrequest->cgirequest->NumParams);
@@ -286,6 +325,52 @@
     {NULL, NULL, NULL}
+    zval **val, **ppzval;
+    zval *cookie_result, *key;
+    HashTable *cookies;
+    char *string_key = NULL, *cookie_tmp;
+    ulong num_key;
+    int numElements, i = 0;
+    TSRMLS_FETCH_FROM_CTX(thread_context);
+    if  (STRING_EQUAL(name, "HTTP_COOKIE"))
+        cookies = PG(http_globals)[TRACK_VARS_COOKIE]->value.ht;
+        numElements = zend_hash_num_elements(cookies);
+        MAKE_STD_ZVAL(cookie_result);
+        ZVAL_STRING(cookie_result, "",1);
+        for(zend_hash_internal_pointer_reset(cookies);
+            zend_hash_has_more_elements(cookies) == SUCCESS;
+            zend_hash_move_forward(cookies), ++i)
+            zend_hash_get_current_data(cookies, (void **)&ppzval);
+            zend_hash_get_current_key(cookies, &string_key, &num_key, 1);
+            cookie_tmp = malloc((strlen(string_key)+Z_STRLEN_PP(ppzval)+3) * sizeof(char));
+            sprintf(cookie_tmp, "%s=%s;",string_key,Z_STRVAL_PP(ppzval));
+            MAKE_STD_ZVAL(key);
+            ZVAL_STRING(key, cookie_tmp,1);
+            add_string_to_string(cookie_result,cookie_result, key);
+            zval_dtor(key);
+            free(cookie_tmp);
+        return Z_STRVAL_P(cookie_result);
+    else
+             (zend_hash_find(PG(http_globals)[TRACK_VARS_SERVER]->value.ht, name, strlen(name)+1, (void **) &val) == SUCCESS) &&
+             (Z_TYPE_PP(val) == IS_STRING))
+            return Z_STRVAL_PP(val);
+    return NULL;
 void mapscript_create_owsrequest(cgiRequestObj *cgirequest, zval *return_value TSRMLS_DC)
     php_owsrequest_object * php_owsrequest;
@@ -327,6 +412,7 @@
                              mapscript_owsrequest_object_new);
     mapscript_ce_owsrequest->ce_flags |= ZEND_ACC_FINAL_CLASS;
     return SUCCESS;
Modified: trunk/mapserver/mapscript/php/php_mapscript.c
--- trunk/mapserver/mapscript/php/php_mapscript.c	2010-03-17 02:25:35 UTC (rev 9949)
+++ trunk/mapserver/mapscript/php/php_mapscript.c	2010-03-17 15:20:27 UTC (rev 9950)
@@ -1208,15 +1208,15 @@
     PHP_MINIT(shapefile)(INIT_FUNC_ARGS_PASSTHRU);
     PHP_MINIT(layer)(INIT_FUNC_ARGS_PASSTHRU);
     PHP_MINIT(map)(INIT_FUNC_ARGS_PASSTHRU);
     return SUCCESS;
 PHP_MSHUTDOWN_FUNCTION(mapscript)
     /* Cleanup MapServer resources */
-    msCleanup();
+    msCleanup();
     return SUCCESS;
Modified: trunk/mapserver/mapscript/php/php_mapscript.h
--- trunk/mapserver/mapscript/php/php_mapscript.h	2010-03-17 02:25:35 UTC (rev 9949)
+++ trunk/mapserver/mapscript/php/php_mapscript.h	2010-03-17 15:20:27 UTC (rev 9950)
@@ -735,7 +735,11 @@
 cgiRequestObj *cgirequestObj_new();
-int cgirequestObj_loadParams(cgiRequestObj *self);
+                             void* thread_context);
 void cgirequestObj_setParameter(cgiRequestObj *self, char *name, char *value);
 char *cgirequestObj_getName(cgiRequestObj *self, int index);
 char *cgirequestObj_getValue(cgiRequestObj *self, int index);
Modified: trunk/mapserver/mapscript/swiginc/owsrequest.i
--- trunk/mapserver/mapscript/swiginc/owsrequest.i	2010-03-17 02:25:35 UTC (rev 9949)
+++ trunk/mapserver/mapscript/swiginc/owsrequest.i	2010-03-17 15:20:27 UTC (rev 9950)
@@ -76,7 +76,7 @@
     int loadParams()
-	self->NumParams = loadParams( self );
+	self->NumParams = loadParams( self, NULL, NULL, 0, NULL);
Modified: trunk/mapserver/mapserv.c
--- trunk/mapserver/mapserv.c	2010-03-17 02:25:35 UTC (rev 9949)
+++ trunk/mapserver/mapserv.c	2010-03-17 15:20:27 UTC (rev 9950)
@@ -1207,7 +1207,7 @@
       writeError();
-    mapserv->request->NumParams = loadParams(mapserv->request);
+    mapserv->request->NumParams = loadParams(mapserv->request, NULL, NULL, 0, NULL);
     if( mapserv->request->NumParams == -1 ) {
 #ifdef USE_FASTCGI
       /* FCGI_ --- return to top of loop */
