[mapserver-commits] r10003 - in trunk/msautotest/gdal: . data expected
Wed Mar 24 23:31:59 EDT 2010
Author: warmerdam
Date: 2010-03-24 23:31:57 -0400 (Wed, 24 Mar 2010)
New Revision: 10003
Added:
   trunk/msautotest/gdal/data/test_with_mask_1bit.tif
   trunk/msautotest/gdal/expected/mask_1.png
   trunk/msautotest/gdal/expected/mask_3.png
   trunk/msautotest/gdal/mask_1.map
   trunk/msautotest/gdal/mask_3.map
add testing for gdal masks (#2640)
Added: trunk/msautotest/gdal/data/test_with_mask_1bit.tif
(Binary files differ)
Property changes on: trunk/msautotest/gdal/data/test_with_mask_1bit.tif
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/msautotest/gdal/expected/mask_1.png
Property changes on: trunk/msautotest/gdal/expected/mask_1.png
Added: trunk/msautotest/gdal/expected/mask_3.png
Property changes on: trunk/msautotest/gdal/expected/mask_3.png
Added: trunk/msautotest/gdal/mask_1.map
--- trunk/msautotest/gdal/mask_1.map	                        (rev 0)
+++ trunk/msautotest/gdal/mask_1.map	2010-03-25 03:31:57 UTC (rev 10003)
@@ -0,0 +1,24 @@
+# Test support for GDAL masks on a one band file per GDAL RFC 15 and MS #2640
+MAP
+  IMAGETYPE PNG24
+  IMAGECOLOR 255 0 0
+  SIZE 200 200
+  EXTENT 0 0 19 19
+  LAYER
+    NAME "TEST"
+    GROUP "TEST"
+    STATUS DEFAULT
+    TYPE RASTER
+    DUMP TRUE
+    # A RGB image with a transparency mask
+    #DATA "test3_with_1mask_1bit.tif"
+    # A grey-level image with a transparency mask
+    DATA "data/test_with_mask_1bit.tif"
+  END
+END # end of map file
\ No newline at end of file
Added: trunk/msautotest/gdal/mask_3.map
--- trunk/msautotest/gdal/mask_3.map	                        (rev 0)
+++ trunk/msautotest/gdal/mask_3.map	2010-03-25 03:31:57 UTC (rev 10003)
@@ -0,0 +1,24 @@
+# Test support for GDAL masks on a 3 band file per GDAL RFC 15 and MS #2640
+MAP
+  IMAGETYPE PNG24
+  SIZE 200 200
+  EXTENT 0 0 19 19
+  LAYER
+    NAME "TEST"
+    GROUP "TEST"
+    STATUS DEFAULT
+    TYPE RASTER
+    DUMP TRUE
+    DATA "data/test3_with_1mask_1bit.tif"
+    #DATA "data/test_with_mask_1bit.tif"
+  END
