[mapserver-commits] r10004 - trunk/mapserver
Wed Mar 24 23:33:56 EDT 2010
Author: warmerdam
Date: 2010-03-24 23:33:56 -0400 (Wed, 24 Mar 2010)
New Revision: 10004
   trunk/mapserver/mapdrawgdal.c
do not use GDAL mask api unless we have gdal 1.5 or later (#2640)
Modified: trunk/mapserver/mapdrawgdal.c
--- trunk/mapserver/mapdrawgdal.c	2010-03-25 03:31:57 UTC (rev 10003)
+++ trunk/mapserver/mapdrawgdal.c	2010-03-25 03:33:56 UTC (rev 10004)
@@ -829,6 +829,7 @@
 /*      load it as massage it so it will function as our alpha for      */
 /*      transparency purposes.                                          */
+#if defined(GDAL_VERSION_NUM) && GDAL_VERSION_NUM >= 1500
     if( hBandAlpha == NULL )
         int nMaskFlags = GDALGetMaskFlags(hBand1);
@@ -891,6 +892,7 @@
+#endif /* defined(GDAL_VERSION_NUM) && GDAL_VERSION_NUM >= 1500 */
 /*      Single band plus colormap with alpha blending to 8bit.          */
