[mapserver-commits] r10005 - in trunk/msautotest/gdal: . data expected
Thu Mar 25 00:27:04 EDT 2010
Author: warmerdam
Date: 2010-03-25 00:27:02 -0400 (Thu, 25 Mar 2010)
New Revision: 10005
Added:
   trunk/msautotest/gdal/data/red_square.tif
   trunk/msautotest/gdal/expected/nodata_rgb.png
   trunk/msautotest/gdal/nodata_rgb.map
add rgb nodata test (#2404)
Added: trunk/msautotest/gdal/data/red_square.tif
(Binary files differ)
Property changes on: trunk/msautotest/gdal/data/red_square.tif
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/msautotest/gdal/expected/nodata_rgb.png
Property changes on: trunk/msautotest/gdal/expected/nodata_rgb.png
Added: trunk/msautotest/gdal/nodata_rgb.map
--- trunk/msautotest/gdal/nodata_rgb.map	                        (rev 0)
+++ trunk/msautotest/gdal/nodata_rgb.map	2010-03-25 04:27:02 UTC (rev 10005)
@@ -0,0 +1,27 @@
+# Test rendering of an RGB image with nodata values that should give
+# equivelent processing to "OFFSET 0 0 0".
+MAP
+  IMAGETYPE PNG24
+  IMAGECOLOR 255 255 255
+  SIZE 100 100
+  EXTENT 0 -90 180 90
+  PROJECTION
+  "init=epsg:4326"
+  END
+LAYER
+  NAME "TEST"
+  STATUS DEFAULT
+  TYPE RASTER
+  DUMP TRUE
+  DATA "data/red_square.tif"
+  PROJECTION
+    "init=epsg:4326"
+  END
+END
+END # end of map file
