[mapserver-commits] r10667 - trunk/docs/en/output
    svn at osgeo.org
    svn at osgeo.org
    Mon Oct 25 10:28:00 EDT 2010
Author: warmerdam
Date: 2010-10-25 07:28:00 -0700 (Mon, 25 Oct 2010)
New Revision: 10667
Added:
   trunk/docs/en/output/ogr_output.txt
Removed:
   trunk/docs/en/output/ogr.txt
rename to ogr_output for consistency with references
Deleted: trunk/docs/en/output/ogr.txt
--- trunk/docs/en/output/ogr.txt	2010-10-25 13:08:49 UTC (rev 10666)
+++ trunk/docs/en/output/ogr.txt	2010-10-25 14:28:00 UTC (rev 10667)
@@ -1,319 +0,0 @@
-.. _ogr_output:
- OGR Output
-:Author: Frank Warmerdam
-:Contact: warmerdam at pobox.com
-:Revision: $Revision$
-:Date: $Date$
-:Last Updated: 2010/10/22
-.. contents:: Table of Contents
-    :depth: 2
-    :backlinks: top
-Introduction
-OGR output support was added to MapServer 6.0.  It provides an output driver
-to produce feature style output suitable as a return result from WMS
-GetFeatureInfo or WFS GetFeature requests.  OGR feature output depends on
-MapServer being built against the GDAL/OGR library.  The OGR output driver
-should be enabled in MapServer 6.0 or newer when INPUT=OGR appears in the
-version string.
-OUTPUTFORMAT Declarations
-Details of OGR output formats allowed are controlled by an OUTPUTFORMAT
-declaration.  The declarations define the OGR format driver to be used,
-creation options specific to that driver, and more general instructions to
-MapServer on how to package multi-file results and whether to try and
-build the result on disk or in memory.
-Examples::
-  OUTPUTFORMAT
-    NAME "CSV"
-    DRIVER "OGR/CSV"
-    MIMETYPE "text/csv"
-    FORMATOPTION "LCO:GEOMETRY=AS_WKT"
-    FORMATOPTION "STORAGE=memory"
-    FORMATOPTION "FORM=simple"
-    FORMATOPTION "FILENAME=result.csv"
-  END
-  OUTPUTFORMAT
-    NAME "OGRGML"
-    DRIVER "OGR/GML"
-    FORMATOPTION "STORAGE=filesystem"
-    FORMATOPTION "FORM=multipart"
-    FORMATOPTION "FILENAME=result.gml"
-  END
-  OUTPUTFORMAT
-    NAME "SHAPEZIP"
-    DRIVER "OGR/ESRI Shapefile"
-    FORMATOPTION "FORM=zip"
-    FORMATOPTION "FILENAME=result.zip"
-  END
-The OGR format driver to be used is determined by the name appearing
-after "OGR/" in the DRIVER argument.  This name should match one of
-the formats listed as supported for the "-f" argument to ogr2ogr in the
-ogr2ogr usage message.
-The IMAGEMODE for OGR output is FEATURE, but this is implicit and does
-not need to be explicitly stated for OGR output driver declarations.
-The OGR renderer will support the following FORMATOPTION declarations:
-**DSCO:\***
-  Anything prefixed by DSCO: is used as a dataset creation option with the
-  OGR driver. See the OGR web page for the particular format driver to see
-  layer creation options available.
-**LCO:\***
-  Anything prefixed by LCO: is used as a layer creation option.  See
-  the OGR web page for the particular format driver to see layer creation
-  options available.w
-**FORM=simple/zip/multipart**
-  Indicates whether the result should be a simple single file (single), a
-  mime multipart attachment (multipart) or a zip file (zip).  "zip" is
-  the default.
-**STORAGE=memory/filesystem/stream**
-  Indicates where the datasource should be stored while being written.
-  "file" is the default.
-  If "memory" then it will be created in /vsimem/ - but this is only suitable
-  for drivers supporting VSI*L which we can't easily determine automatically.
-  If "file" then a temporary directory will be created under the IMAGEPATH
-  were the file(s) will be written and then read back to stream to the
-  client.
-  If "stream" then the datasource will be created with a name "/vsistdout"
-  as an attempt to write directly to stdout.  Only a few OGR drivers will
-  work properly in this mode (ie. CSV, perhaps kml, gml).
-**FILENAME=name**
-  Provides a name for the datasource created, default is "result.dat".
-LAYER Metadata
-The OGR output driver utilizes several items from the LAYER level METADATA
-object.  Some of these were originally intended for GML output or are
-primarily intended to support WFS.
-**wfs_getfeature_formatlist**
-  (Optional) A comma delimited list of formats supported for WFS GetFeature
-  responses.  The OUTPUTFORMAT NAME values should be listed.
-    "wfs_getfeature_formatlist" "OGRGML,SHAPEZIP,CSV"
-**gml_include_items**
-  (Optional) A comma delimited list of items to include, or keyword
-  "all".  You can enable full exposure by using the keyword "all".
-    "gml_include_items" "all"
-  You can specify a list of attributes (fields) for partial exposure, such as:
-    "gml_include_items" "Name,ID"
-  The new default behaviour is to expose no attributes at all.
-  "all". As of MapServer 4.6, you can control how many attributes (fields) you expose
-  for your data layer with this metadata. The previous behaviour was simply to expose
-  all attributes all of the time. You can enable full exposure by using the keyword "all",
-  such as:
-**gml_[item name]_alias**
-  (Optional) An alias for an attribute's name.  The resulting file will refer
-  to this attribute by the alias.  Here is an example:
-    "gml_province_alias" "prov"
-**gml_[item name]_type**
-  (Optional) Specifies the type of the attribute.  Valid values
-  are Integer|Real|Character|Date|Boolean.
-**gml_[item name]_width**
-  (Optional) Specifies the width of the indicated field for formats where
-  this is significant, such as Shapefiles.
-**gml_[item name]_precision**
-  (Optional) Specifies the precision of the indicated field for formats where
-  this is significant, such as Shapefiles.  Precision is the number of decimal
-  places, and is only needed for "Real" fields.
-**gml_types**
-  (Optional) If this field is "auto" then some input feature drivers (ie.
-  OGR, and native shapefiles) will automatically populate the type, width and
-  precision metadata for the layer based on the source file.
-    "gml_types"   "auto"
-**ows/wfs_geomtype**
-  (Optional) Set the geometry type of OGR layers created from this MapServer
-  LAYER.  One of "Point", "LineString", "Polygon", "MultiPoint",
-  "MultiLineString", "MultiPolygon", "GeometryCollection", "Geometry",
-  or "None".  Most are fairly obvious, but "Geometry" can be used to represent
-  a mix of geometry types, and "None" is sometimes suitable for layers without
-  geometry.  Note that layers which are a mix of polygon and multipolygon
-  would normally have to be described as "Geometry".
-    "ows_geomtype"  "Polygon"
-MAP / WEB Metadata
-**wms_feature_info_mime_type**
-  In order for WMS GetFeatureInfo to allow selection of OGR output formats,
-  the mime type associated with the OUTPUTFORMAT must be listed in this metadata
-  item.
-    "wms_feature_info_mime_type" "text/csv"
-Geometry Types Supported
-In MapServer we have POINT, LINE and POLYGON layers which also allow for
-features with multiple points, lines or polygons.  However, in the OGC Simple
-Feature geometry model used by OGR a point and multipoint layer are quite
-distinct.  Likewise for a LineString and MultiLineString and Polygon an
-MultiPolygon layer type.
-To work around the mismatches between the MapServer and OGR geometry models,
-there is a mechanism to specify the geometry type to be used when exporting
-through OGR.  This is the "wfs/ows_geomtype" metadata item on the layer. It
-may be one of one of "Point", "LineString", "Polygon", "MultiPoint",
-"MultiLineString", "MultiPolygon", "GeometryCollection", "Geometry", or "None".
-If this item is not specified, then "Point", "LineString" or "Polygon" will
-be used depending on the TYPE of the LAYER.   In cases of mixed geometry
-types (ie. polygons and multipolygons) the geometry type should be set to
-"Geometry" which means any geometry type.
-    "ows_geomtype" "Geometry"
-Attribute Field Definitions
-For OGR output it is highly desirable to be able to create the output fields
-with the appropriate datatype, width and precision to reflect the source
-feature definition.
-It is possible to set the gml_[item]_type, gml_[item]_width and
-gml_[item]_precision metadata on the layer to provide detailed field
-definitions::
-    METADATA
-      "gml_ID_type"        "Integer"
-      "gml_ID_width"       "8"
-      "gml_AREA_type"      "Real"
-      "gml_AREA_width"     "15"
-      "gml_AREA_precision" "6"
-      "gml_NAME_type"      "Character"
-      "gml_NAME_width"     "64"
-However, doing this manually is tedious and error prone.  For that reason
-some feature sources (at least OGR, Shapefiles, POSTGIS and ORACLESPATIAL)
-support a mechanism to automatically populate this information from the
-source datastore.  To accomplish this specify::
-If no effort is made to set type, width and precision information for
-attribute fields, they will all be treated as variable length character
-fields when writing through OGR.
-Return Packaging
-One of the challenges returning generalized feature formats is that
-many such formats consists of multiple files which must be returned in
-the result.  There are three approaches taken to this based on the
-FORM FORMATOPTION in the OUTPUTFORMAT declaration.
-**simple**
-  In this case a single result is returned.  This is suitable for format
-  drivers that produce a single file.  The return result will have the
-  mimetype listed in the OUTPUTFORMAT declaration.  Note that if the OGR
-  driver actually returns multiple files, only the primary one (the one
-  with a name matching the filename passed into the OGR CreateDataSource call)
-  will be returned.  The return result will have a suggested filename based
-  on the FILENAME FORMATOPTION.
-**multipart**
-  In this case all the files produced are returned as a multipart mime
-  result.  In this case the MIMETYPE of the OUTPUTFORMAT is ignored.  All
-  component files are returned with a mime type of "application/binary" and
-  the whole package is "multipart/mixed".
-**zip**
-  In this case all the files produced are bundled into one .zip file and
-  this zip file is returned with a mimetype of "application/zip".   The
-  OUTPUTFORMAT MIMETYPE is ignored.
-One caveat with "zip" results is that this option is only available if
-the GDAL/OGR version is 1.8 or newer (or a 1.8 development later than
-approximately Oct 15, 2010).  Earlier versions of GDAL/OGR lacked the
-zipping capability needed.
-Test Suite Example
-The MSAutoTest test suite contains a test case for use of OGR Output from
-WFS.   The mapfile is at:
-  http://svn.osgeo.org/mapserver/trunk/msautotest/wxs/wfs_ogr.map
-The comments at the start of the file have a variety of sample requests
-that can be run against the map, as long as [MAPFILE] is replaced with the
-mapfile name.  They requests should be run against mapserv sitting in the
-msautotest/wxs directory.
Copied: trunk/docs/en/output/ogr_output.txt (from rev 10665, trunk/docs/en/output/ogr.txt)
--- trunk/docs/en/output/ogr_output.txt	                        (rev 0)
+++ trunk/docs/en/output/ogr_output.txt	2010-10-25 14:28:00 UTC (rev 10667)
@@ -0,0 +1,319 @@
+.. _ogr_output:
+ OGR Output
+:Author: Frank Warmerdam
+:Contact: warmerdam at pobox.com
+:Revision: $Revision$
+:Date: $Date$
+:Last Updated: 2010/10/22
+.. contents:: Table of Contents
+    :depth: 2
+    :backlinks: top
+Introduction
+OGR output support was added to MapServer 6.0.  It provides an output driver
+to produce feature style output suitable as a return result from WMS
+GetFeatureInfo or WFS GetFeature requests.  OGR feature output depends on
+MapServer being built against the GDAL/OGR library.  The OGR output driver
+should be enabled in MapServer 6.0 or newer when INPUT=OGR appears in the
+version string.
+OUTPUTFORMAT Declarations
+Details of OGR output formats allowed are controlled by an OUTPUTFORMAT
+declaration.  The declarations define the OGR format driver to be used,
+creation options specific to that driver, and more general instructions to
+MapServer on how to package multi-file results and whether to try and
+build the result on disk or in memory.
+Examples::
+  OUTPUTFORMAT
+    NAME "CSV"
+    DRIVER "OGR/CSV"
+    MIMETYPE "text/csv"
+    FORMATOPTION "LCO:GEOMETRY=AS_WKT"
+    FORMATOPTION "STORAGE=memory"
+    FORMATOPTION "FORM=simple"
+    FORMATOPTION "FILENAME=result.csv"
+  END
+  OUTPUTFORMAT
+    NAME "OGRGML"
+    DRIVER "OGR/GML"
+    FORMATOPTION "STORAGE=filesystem"
+    FORMATOPTION "FORM=multipart"
+    FORMATOPTION "FILENAME=result.gml"
+  END
+  OUTPUTFORMAT
+    NAME "SHAPEZIP"
+    DRIVER "OGR/ESRI Shapefile"
+    FORMATOPTION "FORM=zip"
+    FORMATOPTION "FILENAME=result.zip"
+  END
+The OGR format driver to be used is determined by the name appearing
+after "OGR/" in the DRIVER argument.  This name should match one of
+the formats listed as supported for the "-f" argument to ogr2ogr in the
+ogr2ogr usage message.
+The IMAGEMODE for OGR output is FEATURE, but this is implicit and does
+not need to be explicitly stated for OGR output driver declarations.
+The OGR renderer will support the following FORMATOPTION declarations:
+**DSCO:\***
+  Anything prefixed by DSCO: is used as a dataset creation option with the
+  OGR driver. See the OGR web page for the particular format driver to see
+  layer creation options available.
+**LCO:\***
+  Anything prefixed by LCO: is used as a layer creation option.  See
+  the OGR web page for the particular format driver to see layer creation
+  options available.w
+**FORM=simple/zip/multipart**
+  Indicates whether the result should be a simple single file (single), a
+  mime multipart attachment (multipart) or a zip file (zip).  "zip" is
+  the default.
+**STORAGE=memory/filesystem/stream**
+  Indicates where the datasource should be stored while being written.
+  "file" is the default.
+  If "memory" then it will be created in /vsimem/ - but this is only suitable
+  for drivers supporting VSI*L which we can't easily determine automatically.
+  If "file" then a temporary directory will be created under the IMAGEPATH
+  were the file(s) will be written and then read back to stream to the
+  client.
+  If "stream" then the datasource will be created with a name "/vsistdout"
+  as an attempt to write directly to stdout.  Only a few OGR drivers will
+  work properly in this mode (ie. CSV, perhaps kml, gml).
+**FILENAME=name**
+  Provides a name for the datasource created, default is "result.dat".
+LAYER Metadata
+The OGR output driver utilizes several items from the LAYER level METADATA
+object.  Some of these were originally intended for GML output or are
+primarily intended to support WFS.
+**wfs_getfeature_formatlist**
+  (Optional) A comma delimited list of formats supported for WFS GetFeature
+  responses.  The OUTPUTFORMAT NAME values should be listed.
+    "wfs_getfeature_formatlist" "OGRGML,SHAPEZIP,CSV"
+**gml_include_items**
+  (Optional) A comma delimited list of items to include, or keyword
+  "all".  You can enable full exposure by using the keyword "all".
+    "gml_include_items" "all"
+  You can specify a list of attributes (fields) for partial exposure, such as:
+    "gml_include_items" "Name,ID"
+  The new default behaviour is to expose no attributes at all.
+  "all". As of MapServer 4.6, you can control how many attributes (fields) you expose
+  for your data layer with this metadata. The previous behaviour was simply to expose
+  all attributes all of the time. You can enable full exposure by using the keyword "all",
+  such as:
+**gml_[item name]_alias**
+  (Optional) An alias for an attribute's name.  The resulting file will refer
+  to this attribute by the alias.  Here is an example:
+    "gml_province_alias" "prov"
+**gml_[item name]_type**
+  (Optional) Specifies the type of the attribute.  Valid values
+  are Integer|Real|Character|Date|Boolean.
+**gml_[item name]_width**
+  (Optional) Specifies the width of the indicated field for formats where
+  this is significant, such as Shapefiles.
+**gml_[item name]_precision**
+  (Optional) Specifies the precision of the indicated field for formats where
+  this is significant, such as Shapefiles.  Precision is the number of decimal
+  places, and is only needed for "Real" fields.
+**gml_types**
+  (Optional) If this field is "auto" then some input feature drivers (ie.
+  OGR, and native shapefiles) will automatically populate the type, width and
+  precision metadata for the layer based on the source file.
+    "gml_types"   "auto"
+**ows/wfs_geomtype**
+  (Optional) Set the geometry type of OGR layers created from this MapServer
+  LAYER.  One of "Point", "LineString", "Polygon", "MultiPoint",
+  "MultiLineString", "MultiPolygon", "GeometryCollection", "Geometry",
+  or "None".  Most are fairly obvious, but "Geometry" can be used to represent
+  a mix of geometry types, and "None" is sometimes suitable for layers without
+  geometry.  Note that layers which are a mix of polygon and multipolygon
+  would normally have to be described as "Geometry".
+    "ows_geomtype"  "Polygon"
+MAP / WEB Metadata
+**wms_feature_info_mime_type**
+  In order for WMS GetFeatureInfo to allow selection of OGR output formats,
+  the mime type associated with the OUTPUTFORMAT must be listed in this metadata
+  item.
+    "wms_feature_info_mime_type" "text/csv"
+Geometry Types Supported
+In MapServer we have POINT, LINE and POLYGON layers which also allow for
+features with multiple points, lines or polygons.  However, in the OGC Simple
+Feature geometry model used by OGR a point and multipoint layer are quite
+distinct.  Likewise for a LineString and MultiLineString and Polygon an
+MultiPolygon layer type.
+To work around the mismatches between the MapServer and OGR geometry models,
+there is a mechanism to specify the geometry type to be used when exporting
+through OGR.  This is the "wfs/ows_geomtype" metadata item on the layer. It
+may be one of one of "Point", "LineString", "Polygon", "MultiPoint",
+"MultiLineString", "MultiPolygon", "GeometryCollection", "Geometry", or "None".
+If this item is not specified, then "Point", "LineString" or "Polygon" will
+be used depending on the TYPE of the LAYER.   In cases of mixed geometry
+types (ie. polygons and multipolygons) the geometry type should be set to
+"Geometry" which means any geometry type.
+    "ows_geomtype" "Geometry"
+Attribute Field Definitions
+For OGR output it is highly desirable to be able to create the output fields
+with the appropriate datatype, width and precision to reflect the source
+feature definition.
+It is possible to set the gml_[item]_type, gml_[item]_width and
+gml_[item]_precision metadata on the layer to provide detailed field
+definitions::
+    METADATA
+      "gml_ID_type"        "Integer"
+      "gml_ID_width"       "8"
+      "gml_AREA_type"      "Real"
+      "gml_AREA_width"     "15"
+      "gml_AREA_precision" "6"
+      "gml_NAME_type"      "Character"
+      "gml_NAME_width"     "64"
+However, doing this manually is tedious and error prone.  For that reason
+some feature sources (at least OGR, Shapefiles, POSTGIS and ORACLESPATIAL)
+support a mechanism to automatically populate this information from the
+source datastore.  To accomplish this specify::
+If no effort is made to set type, width and precision information for
+attribute fields, they will all be treated as variable length character
+fields when writing through OGR.
+Return Packaging
+One of the challenges returning generalized feature formats is that
+many such formats consists of multiple files which must be returned in
+the result.  There are three approaches taken to this based on the
+FORM FORMATOPTION in the OUTPUTFORMAT declaration.
+**simple**
+  In this case a single result is returned.  This is suitable for format
+  drivers that produce a single file.  The return result will have the
+  mimetype listed in the OUTPUTFORMAT declaration.  Note that if the OGR
+  driver actually returns multiple files, only the primary one (the one
+  with a name matching the filename passed into the OGR CreateDataSource call)
+  will be returned.  The return result will have a suggested filename based
+  on the FILENAME FORMATOPTION.
+**multipart**
+  In this case all the files produced are returned as a multipart mime
+  result.  In this case the MIMETYPE of the OUTPUTFORMAT is ignored.  All
+  component files are returned with a mime type of "application/binary" and
+  the whole package is "multipart/mixed".
+**zip**
+  In this case all the files produced are bundled into one .zip file and
+  this zip file is returned with a mimetype of "application/zip".   The
+  OUTPUTFORMAT MIMETYPE is ignored.
+One caveat with "zip" results is that this option is only available if
+the GDAL/OGR version is 1.8 or newer (or a 1.8 development later than
+approximately Oct 15, 2010).  Earlier versions of GDAL/OGR lacked the
+zipping capability needed.
+Test Suite Example
+The MSAutoTest test suite contains a test case for use of OGR Output from
+WFS.   The mapfile is at:
+  http://svn.osgeo.org/mapserver/trunk/msautotest/wxs/wfs_ogr.map
+The comments at the start of the file have a variety of sample requests
+that can be run against the map, as long as [MAPFILE] is replaced with the
+mapfile name.  They requests should be run against mapserv sitting in the
+msautotest/wxs directory.
More information about the mapserver-commits
