[mapserver-commits] r10668 - trunk/docs/en/output
Mon Oct 25 10:59:14 EDT 2010
Author: jmckenna
Date: 2010-10-25 07:59:14 -0700 (Mon, 25 Oct 2010)
New Revision: 10668
   trunk/docs/en/output/index.txt
   trunk/docs/en/output/ogr_output.txt
minor formatting changes
Modified: trunk/docs/en/output/index.txt
--- trunk/docs/en/output/index.txt	2010-10-25 14:28:00 UTC (rev 10667)
+++ trunk/docs/en/output/index.txt	2010-10-25 14:59:14 UTC (rev 10668)
@@ -14,8 +14,8 @@
    flash
    html_legend
    imagemaps
+   ogr_output
    pdf
    svg
    tile_mode
-   ogr_output
Modified: trunk/docs/en/output/ogr_output.txt
--- trunk/docs/en/output/ogr_output.txt	2010-10-25 14:28:00 UTC (rev 10667)
+++ trunk/docs/en/output/ogr_output.txt	2010-10-25 14:59:14 UTC (rev 10668)
@@ -6,9 +6,7 @@
 :Author: Frank Warmerdam
 :Contact: warmerdam at pobox.com
-:Revision: $Revision$
-:Date: $Date$
-:Last Updated: 2010/10/22
+:Last Updated: 2010-10-25
 .. contents:: Table of Contents
     :depth: 2
@@ -28,14 +26,16 @@
 OUTPUTFORMAT Declarations
-Details of OGR output formats allowed are controlled by an OUTPUTFORMAT
+Details of OGR output formats allowed are controlled by an :ref:`OUTPUTFORMAT`
 declaration.  The declarations define the OGR format driver to be used,
 creation options specific to that driver, and more general instructions to
 MapServer on how to package multi-file results and whether to try and
 build the result on disk or in memory.
-Examples::
+Examples:
+.. code-block:: mapfile
   OUTPUTFORMAT
     NAME "CSV"
     DRIVER "OGR/CSV"
