[mapserver-commits] r12839 - branches/branch-6-0/docs/en/mapfile trunk/docs/en/mapfile
Sat Dec 3 06:19:44 EST 2011
Author: havatv
Date: 2011-12-03 03:19:44 -0800 (Sat, 03 Dec 2011)
New Revision: 12839
   branches/branch-6-0/docs/en/mapfile/web.txt
   trunk/docs/en/mapfile/web.txt
Added documentation of TEMPPATH and MS_TEMPPATH to the WEB document (#3354).
Modified: branches/branch-6-0/docs/en/mapfile/web.txt
--- branches/branch-6-0/docs/en/mapfile/web.txt	2011-12-02 22:03:25 UTC (rev 12838)
+++ branches/branch-6-0/docs/en/mapfile/web.txt	2011-12-03 11:19:44 UTC (rev 12839)
@@ -191,6 +191,24 @@
        TEMPLATE 'http://someurl/somescript.cgi?mapext=[mapext]'
 .. index::
+   pair: WEB; TEMPPATH
+.. index::
+   pair: Environment variable; MS_TEMPPATH
+TEMPPATH
+   Path for storing temporary files.  If not set, the standard system
+   temporary file path will be used (e.g. \tmp for unix).  `TEMPPATH`
+   can also be set using the environment variable `MS_TEMPPATH`.
+   `TEMPPATH` is used in many contexts (see rfc66).
+   Make sure that that Mapserver has sufficient rights to read and
+   write files at the specified location.
+   .. versionadded:: 6.0
+.. index::
    pair: WEB; VALIDATION
 VALIDATION
Modified: trunk/docs/en/mapfile/web.txt
--- trunk/docs/en/mapfile/web.txt	2011-12-02 22:03:25 UTC (rev 12838)
+++ trunk/docs/en/mapfile/web.txt	2011-12-03 11:19:44 UTC (rev 12839)
@@ -195,6 +195,24 @@
 .. index::
+.. index::
+TEMPPATH
+.. index::
 VALIDATION
