[mapserver-commits] r12840 - branches/branch-6-0/docs/en/output trunk/docs/en/output
Sat Dec 3 06:43:00 EST 2011
Author: havatv
Date: 2011-12-03 03:43:00 -0800 (Sat, 03 Dec 2011)
New Revision: 12840
   branches/branch-6-0/docs/en/output/ogr_output.txt
   trunk/docs/en/output/ogr_output.txt
Updated the STORAGE filesystem documentation in ogr_output (#4103).
Modified: branches/branch-6-0/docs/en/output/ogr_output.txt
--- branches/branch-6-0/docs/en/output/ogr_output.txt	2011-12-03 11:19:44 UTC (rev 12839)
+++ branches/branch-6-0/docs/en/output/ogr_output.txt	2011-12-03 11:43:00 UTC (rev 12840)
@@ -94,9 +94,9 @@
   If "memory" then it will be created in /vsimem/ - but this is only suitable
   for drivers supporting VSI*L which we can't easily determine automatically.
-  If "filesystem" then a temporary directory will be created under the IMAGEPATH
-  were the file(s) will be written and then read back to stream to the
-  client.
+  If "filesystem", then a directory for temporary files (specified
+  using :ref:`WEB` `TEMPPATH` or `MS_TEMPPATH`) will be used for
+  writing and reading back the file(s) to stream to the client.
   If "stream" then the datasource will be created with a name "/vsistdout"
   as an attempt to write directly to stdout.  Only a few OGR drivers will
Modified: trunk/docs/en/output/ogr_output.txt
--- trunk/docs/en/output/ogr_output.txt	2011-12-03 11:19:44 UTC (rev 12839)
+++ trunk/docs/en/output/ogr_output.txt	2011-12-03 11:43:00 UTC (rev 12840)
@@ -94,9 +94,9 @@
-  client.
