[mapserver-commits] r12870 - branches/branch-6-0/docs/en/mapfile trunk/docs/en/mapfile
Thu Dec 8 04:25:13 EST 2011
Author: havatv
Date: 2011-12-08 01:25:13 -0800 (Thu, 08 Dec 2011)
New Revision: 12870
   branches/branch-6-0/docs/en/mapfile/join.txt
   trunk/docs/en/mapfile/join.txt
Updated the join document - mysql example (#4077)
Modified: branches/branch-6-0/docs/en/mapfile/join.txt
--- branches/branch-6-0/docs/en/mapfile/join.txt	2011-12-07 18:23:44 UTC (rev 12869)
+++ branches/branch-6-0/docs/en/mapfile/join.txt	2011-12-08 09:25:13 UTC (rev 12870)
@@ -109,8 +109,8 @@
 TYPE [ONE-TO-ONE|ONE-TO-MANY]
     The type of join. Default is one-to-one.
-Example 1: Join from SHP file to DBF file
+Example 1: Join from Shape dataset to DBF file
 Mapfile Layer
@@ -184,8 +184,8 @@
   </tr>
-Example 2: Join from SHP file to PostgreSQL table
+Example 2: Join from Shape dataset to PostgreSQL table
 Mapfile Layer
@@ -249,8 +249,8 @@
   </tr>
-Example 3: Join from SHP file to CSV file
+Example 3: Join from Shape dataset to CSV file
 Mapfile Layer
@@ -275,6 +275,7 @@
         FOOTER "../htdocs/cgi-query-templates/footer.html"
         JOIN
           NAME "test"
+          CONNECTIONTYPE CSV
           TABLE "../data/lookup.csv"
           FROM "ID"
           TO "IDENT"
@@ -335,3 +336,39 @@
     <td align="left">[NAME]</td>
     <td align="left">[test_VAL]</td>
   </tr>
+Example 4: Join from Shape dataset to MySQL
+Mapfile Layer
+.. code-block:: mapfile
+      LAYER
+        NAME "prov_bound"
+        TYPE POLYGON
+        STATUS DEFAULT
+        DATA "prov.shp"
+        CLASS
+          NAME "Province"
+          STYLE
+            OUTLINECOLOR 120 120 120
+            COLOR 255 255 0
+          END # style
+        END # class
+        TOLERANCE 20
+        TEMPLATE "../htdocs/cgi-query-templates/prov.html"
+        HEADER "../htdocs/cgi-query-templates/prov-header.html"
+        FOOTER "../htdocs/cgi-query-templates/footer.html"
+        JOIN
+          NAME "mysql-join"
+          CONNECTIONTYPE MYSQL
+          CONNECTION 'server:user:password:database'
+          TABLE "mysql-tablename"
+          FROM "ID"
+          TO "mysql-column"
+          TYPE ONE-TO-ONE
+        END # join
+      END # layer
Modified: trunk/docs/en/mapfile/join.txt
--- trunk/docs/en/mapfile/join.txt	2011-12-07 18:23:44 UTC (rev 12869)
+++ trunk/docs/en/mapfile/join.txt	2011-12-08 09:25:13 UTC (rev 12870)
@@ -109,8 +109,8 @@
 Mapfile Layer
@@ -184,8 +184,8 @@
   </tr>
 Mapfile Layer
@@ -249,8 +249,8 @@
   </tr>
 Mapfile Layer
@@ -275,6 +275,7 @@
         JOIN
           NAME "test"
           FROM "ID"
           TO "IDENT"
   </tr>
+Mapfile Layer
+      LAYER
+        NAME "prov_bound"
+        TYPE POLYGON
+        STATUS DEFAULT
+        DATA "prov.shp"
+        CLASS
+          NAME "Province"
+          STYLE
+            COLOR 255 255 0
+          END # style
+        END # class
+        TOLERANCE 20
+        JOIN
+          NAME "mysql-join"
+          FROM "ID"
+          TO "mysql-column"
+          TYPE ONE-TO-ONE
+        END # join
+      END # layer
