[mapserver-commits] r12871 - trunk/docs/en/development/rfc
Thu Dec 8 06:58:22 EST 2011
Author: tbonfort
Date: 2011-12-08 03:58:22 -0800 (Thu, 08 Dec 2011)
New Revision: 12871
   trunk/docs/en/development/rfc/ms-rfc-80.txt
formatting fixups, add more details to implementation, backwards incompatibility,
and error reporting
Modified: trunk/docs/en/development/rfc/ms-rfc-80.txt
--- trunk/docs/en/development/rfc/ms-rfc-80.txt	2011-12-08 09:25:13 UTC (rev 12870)
+++ trunk/docs/en/development/rfc/ms-rfc-80.txt	2011-12-08 11:58:22 UTC (rev 12871)
@@ -12,59 +12,128 @@
 :Version: MapServer 6.2
 :Id: $Id$
-1. Overview
+1. Overview
-This RFC proposes allowing for the definition of fallback fonts for labels, to be used when a glyph is not available in the initial font.
+This RFC proposes allowing for the definition of fallback fonts for labels, to
+be used when a glyph is not available in the initial font.
-Presently, if a glyph is not available in the font of a label, the font's error glyph is drawn (usually an empty box). This is problematic when rendering international data, as it may contain a wide range of unicode charachters. Up to now, this can only be fixed using a (near-)complete unicode font. The free "unifont" contains all glyphs of the basic unicode set (~60.000), but does not look very pleasing as a default font.
+Presently, if a glyph is not available in the font of a label, the font's error
+glyph is drawn (usually an empty box). This is problematic when rendering
+international data, as it may contain a wide range of unicode charachters. Up
+to now, this can only be fixed using a (near-)complete unicode font. The free
+"unifont" contains all glyphs of the basic unicode set (~60.000), but does not
+look very pleasing as a default font.
-With fallback fonts, glyph lookup would try a set of fonts, in a given order, before accepting the error glyph. This way, a unicode font like unifont would only be used as "last resort" on a glyph-by-glyph basis.
+With fallback fonts, glyph lookup would try a set of fonts, in a given order,
+before accepting the error glyph. This way, a unicode font like unifont would
+only be used as "last resort" on a glyph-by-glyph basis.
-In the mapfile, a list of fonts would be given as a comma-separated string like "font1,font2,font3", where each font is listed in the fonts.lst as usual. If only one font is specified, this functionality has no effect. The same fontlist support is availabe for attribute binding.
+In the mapfile, a list of fonts would be given as a comma-separated string like
+"font1,font2,font3", where each font is listed in the fonts.lst as usual. If
+only one font is specified, this functionality has no effect. The same fontlist
+support is availabe for attribute binding.
 2. Proposed Technical Change
 2.1 Core Object Changes
-The Label Style Object would need to support multiple fonts. The proposed implementation uses a hard limit to the number of fonts, to avoid overhead. The number of fonts can be changed using the MS_MAX_LABEL_FONTS define, the suggested default is 5.
+The Label Style Object would need to support multiple fonts. The proposed
+implementation uses a hard limit to the number of fonts, to avoid overhead. The
+number of fonts can be changed using the MS_MAX_LABEL_FONTS define, the
+suggested default is 5.
 2.2 Label Rendering Changes
-The function pointer signature of GetTruetypeTextBBox needs to be changed to be able to recieve multiple fonts and their count. This requires a change to every renderer, as does the change of the labelStyleObj.
-Renderers supporting single-glyph operation like cairo and agg can use the font list passed in to implement the glyph fallback. Renderers operating on complete strings can use fonts[0] for no change in behavior.
+The function pointer signature of GetTruetypeTextBBox needs to be changed to be
+able to recieve multiple fonts and their count. This requires a change to every
+renderer, as does the change of the labelStyleObj.
+Renderers supporting single-glyph operation like cairo and agg can use the font
+list passed in to implement the glyph fallback. Renderers operating on complete
+strings can use fonts[0] for no change in behavior.
 2.3 MapScript
+The mapscript getters and setters are unchanged, but the semantics
+of the string passed to labelObj->setFont() is modified as it now
+expects a comma-separated list of fontset keys.
 3. Implementation Details
-The proposed implementation adds font fallback support to the cairo and agg renderers.
+The proposed implementation adds font fallback support to the cairo and agg
+renderers.
+The labelObj is unchanged, but its "char* font" member semantics
+is changed to contain a comma separated list of fontset keys instead of a
+single fontset key. This ensures minimal backwards incompatibility for
+mapscript applications and datasource bindings.
+A new function "msFontsetLookupFonts()" is called before labelling
+renderer-specific functions are called, and maps the comma-separated
+labelObj->font into an array of full font filenames, by iterating
+through the labelObj->font keys and calling msFontsetLookup.
+The renderer-specific labelling function signatures are modified to take
+a list of font filenames instead of a single filename as is the case now.
+Renderers that do not (yet?) support multiple font fallbacks are slightly
+modified to use the first entry of the font array, while the other renderers
+use some specific code to detect missing characters and use the fallback
+fonts when needed.
 3.1. Files Affected
-  maprendering.c: lookup and set list of fonts on labelStyleObj
-  mapagg.cpp: glyph fallback
-  mapgd.c: use fonts[0]
-  mapserver.h: add msFontsetLookupFonts function and MS_MAX_LABEL_FONTS define, change labelStyleObj char* font to char* font[MS_MAX_LABEL_FONTS]
-  mapsymbol.c: symbol font fallback adoptions
-  maputil.c: only bind font from shape if it's different
-  maplabel.c: add msFontsetLookupFonts implementation and use it
-  mapkmlrenderer.h: getTruetypeTextBBox adoption
-  mapcairo.c: glyph fallback
-  mapogl.cpp: use fonts[0]
-  mapdummyrenderer.c: getTruetypeTextBBox adoption
-  mapkml.c: getTruetypeTextBBox adoption
+* maplabel.c:
+ * add msFontsetLookupFonts implementation that splits the input
+   font on commas and looks up each font key in the fontset.
+ * call msFontsetLookupFonts before calling the renderer vtable
+   boundingbox calculation functions.
+* maprendering.c: call msFontsetLookupFonts to set list of fonts
+  in labelStyleObj
+* mapagg.cpp: glyph fallback implementation, agg specific
+* mapcairo.c: glyph fallback implementation, cairo and freetype specific
+* mapgd.c, mapkml.c, mapogl.cpp:
+ * use only the first font of the given font list
+ * getTruetypeTextBBox function signature update
+* mapserver.h:
+ * add msFontsetLookupFonts function and MS_MAX_LABEL_FONTS define
+ * change labelStyleObj char* font to char* font[MS_MAX_LABEL_FONTS]
+* mapsymbol.c: symbol font fallback adoptions
+* maputil.c: only bind font from shape if it's different
+* mapdummyrenderer.c: getTruetypeTextBBox signature change
 3.2 Bug ID
- * http://trac.osgeo.org/mapserver/ticket/4114
-4. Enhancements
+* http://trac.osgeo.org/mapserver/ticket/4114
-5. Voting history
+4. Backwards compatibility issues
+None expected, unless existing fontset keys contained commas. I'm not
+sure this was valid syntax anyways, and was definitely bad practice.
+5. Error reporting
+The hard limit on the maximum number of fonts allowed is enforced in
+msFontsetLookupFonts() which will halt processing and return an error
+message stating that the maximum number of fonts is set to
+MS_MAX_LABEL_FONTS. The renderers themselves will report the usual
+error message if one of the referenced fonts could not be loaded (due
+to an inaccessible or corrupt ttf file).
+4. Voting history
+TBD
