[mapserver-commits] r11960 - in sandbox/inspire_soc2011: mapserver msautotest/wxs msautotest/wxs/expected
Tue Jul 19 12:00:35 EDT 2011
Author: stefanl
Date: 2011-07-19 09:00:35 -0700 (Tue, 19 Jul 2011)
New Revision: 11960
   sandbox/inspire_soc2011/mapserver/mapows.c
   sandbox/inspire_soc2011/mapserver/rfc73.rst
   sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario1_cap130.xml
   sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario1_cap130_eng.xml
   sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario1_cap130_ger.xml
   sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario2_cap130.xml
   sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario2_cap130_eng.xml
   sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario2_cap130_ger.xml
   sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario2.map
conformity is always set to notEvaluated
Modified: sandbox/inspire_soc2011/mapserver/mapows.c
--- sandbox/inspire_soc2011/mapserver/mapows.c	2011-07-19 12:53:49 UTC (rev 11959)
+++ sandbox/inspire_soc2011/mapserver/mapows.c	2011-07-19 16:00:35 UTC (rev 11960)
@@ -960,7 +960,13 @@
         msOWSPrintEncodeMetadata(stream, &(map->web.metadata), namespaces, "onlineresource", OWS_NOERR, "    <inspire_common:ResourceLocator>\n      <inspire_common:URL>%s</inspire_common:URL>\n    </inspire_common:ResourceLocator>\n", NULL);
         msIO_fprintf(stream,"    <inspire_common:ResourceType>service</inspire_common:ResourceType>\n");
         msOWSPrintEncodeMetadata(stream, &(map->web.metadata), namespaces, "inspire_temporal_reference", OWS_WARN, "    <inspire_common:TemporalReference>\n      <inspire_common:DateOfLastRevision>%s</inspire_common:DateOfLastRevision>\n    </inspire_common:TemporalReference>\n", "");
-        msOWSPrintEncodeMetadata(stream, &(map->web.metadata), namespaces, "inspire_conformity", OWS_WARN, "    <inspire_common:Conformity>\n      <inspire_common:Degree>%s</inspire_common:Degree>\n    </inspire_common:Conformity>\n", "");
+        msIO_fprintf(stream, "    <inspire_common:Conformity>\n");
+        msIO_fprintf(stream, "      <inspire_common:Specification>\n");
+        msIO_fprintf(stream, "        <inspire_common:Title>-</inspire_common:Title>\n");
+        msOWSPrintEncodeMetadata(stream, &(map->web.metadata), namespaces, "inspire_temporal_reference", OWS_NOERR, "        <inspire_common:DateOfLastRevision>%s</inspire_common:DateOfLastRevision>\n", "");
+        msIO_fprintf(stream, "      </inspire_common:Specification>\n");
+        msIO_fprintf(stream, "      <inspire_common:Degree>notEvaluated</inspire_common:Degree>\n");
+        msIO_fprintf(stream, "    </inspire_common:Conformity>\n");
         msIO_fprintf(stream, "    <inspire_common:MetadataPointOfContact>\n");
         msOWSPrintEncodeMetadata(stream, &(map->web.metadata), namespaces, "inspire_mpoc_name", OWS_WARN, "      <inspire_common:OrganisationName>%s</inspire_common:OrganisationName>\n", "");
         msOWSPrintEncodeMetadata(stream, &(map->web.metadata), namespaces, "inspire_mpoc_email", OWS_WARN, "      <inspire_common:EmailAddress>%s</inspire_common:EmailAddress>\n", "");
Modified: sandbox/inspire_soc2011/mapserver/rfc73.rst
--- sandbox/inspire_soc2011/mapserver/rfc73.rst	2011-07-19 12:53:49 UTC (rev 11959)
+++ sandbox/inspire_soc2011/mapserver/rfc73.rst	2011-07-19 16:00:35 UTC (rev 11960)
@@ -137,7 +137,6 @@
     "wms_inspire_capabilities" "embed"
     "wms_inspire_languages" "eng,ger"                         #first default, values according ISO 639-2/B
     "wms_inspire_temporal_reference" "2011-09-19"             #date of last revision, value according YYYY-MM-DD
-    "wms_inspire_conformity" "not evaluated"                  #value either "conformant"|"not conformant"|default "not evaluated"
     "wms_inspire_mpoc_name" "mympocname"                      #point of contact
     "wms_inspire_mpoc_email" "mympoc at e.mail"                  #point of contact
     "wms_inspire_metadatadate" "2011-09-19"                   #value according YYYY-MM-DD
@@ -157,6 +156,7 @@
 - several fields require certain values, these values are not validated by MapServer itself, instead a manual validation against the `INSPIRE schemas`_ or the `WMS INSPIRE tester`_ is recommended
 - only one keyword through "wms_inspire_keyword" is supported, a possibly provided "wms_keywordlist" will be ignored
 - as suggested in this document_ regarding scenario 2, <inspire_common:ResourceType> is always set to service and <inspire_common:SpatialDataServiceType> is always set to view, both values can't be altered through the mapfile
+- conformity is always set to not evaluated, based on the latest `INSPIRE Metadata Implementing Rules`_ (page 7), a specification document, the specification date and a specification URI or URL need to be provided for degree conformant/not conformant, which is currently not implemented
 5. Style section for root layer and possibly existing group layers
@@ -327,6 +327,7 @@
 .. _runtime-substitution: http://mapserver.org/cgi/runsub.html
 .. _inspire_soc2011: https://svn.osgeo.org/mapserver/sandbox/inspire_soc2011
 .. _document: http://www.neogeo-online.net/blog/wp-content/uploads/2011/04/MAPSERVER_INSPIRE.pdf
+.. _`INSPIRE Metadata Implementing Rules`: http://inspire.jrc.ec.europa.eu/documents/Metadata/Changes_to_MD_Guidelines_from_v1-1_to_v1-2_20100616-1.pdf
 .. _`concept of GROUP and CLASSGROUP`: http://lists.osgeo.org/pipermail/mapserver-inspire/2011-April/000027.html
 .. _3608: http://trac.osgeo.org/mapserver/ticket/3608
 .. _3850: http://trac.osgeo.org/mapserver/ticket/3850
Modified: sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario1_cap130.xml
--- sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario1_cap130.xml	2011-07-19 12:53:49 UTC (rev 11959)
+++ sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario1_cap130.xml	2011-07-19 16:00:35 UTC (rev 11960)
@@ -49,8 +49,6 @@
       <Format>image/jpeg</Format>
       <Format>image/gif</Format>
       <Format>image/png; mode=8bit</Format>
-      <Format>application/x-pdf</Format>
-      <Format>image/svg+xml</Format>
       <Format>image/tiff</Format>
       <Format>application/vnd.google-earth.kml+xml</Format>
       <Format>application/vnd.google-earth.kmz</Format>
Modified: sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario1_cap130_eng.xml
--- sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario1_cap130_eng.xml	2011-07-19 12:53:49 UTC (rev 11959)
+++ sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario1_cap130_eng.xml	2011-07-19 16:00:35 UTC (rev 11960)
@@ -49,8 +49,6 @@
Modified: sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario1_cap130_ger.xml
--- sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario1_cap130_ger.xml	2011-07-19 12:53:49 UTC (rev 11959)
+++ sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario1_cap130_ger.xml	2011-07-19 16:00:35 UTC (rev 11960)
@@ -49,8 +49,6 @@
Modified: sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario2_cap130.xml
--- sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario2_cap130.xml	2011-07-19 12:53:49 UTC (rev 11959)
+++ sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario2_cap130.xml	2011-07-19 16:00:35 UTC (rev 11960)
@@ -49,8 +49,6 @@
@@ -86,16 +84,11 @@
       <inspire_common:DateOfLastRevision>2011-09-19</inspire_common:DateOfLastRevision>
-      <inspire_common:Specification xsi:type="inspire_common:citationInspireInteroperabilityRegulation_eng">
-        <inspire_common:Title>COMMISSION REGULATION (EU) No 1089/2010 of 23 November 2010 implementing Directive 2007/2/EC of the European Parliament and of the Council as regards interoperability of spatial data sets and services</inspire_common:Title>
-        <inspire_common:DateOfPublication>2010-12-08</inspire_common:DateOfPublication>
-        <inspire_common:URI>OJ:L:2010:323:0011:0102:EN:PDF</inspire_common:URI>
-        <inspire_common:ResourceLocator>
-          <inspire_common:URL>http://eur-lex.europa.eu/LexUriServ/LexUriServ.do?uri=OJ:L:2010:323:0011:0102:EN:PDF</inspire_common:URL>
-          <inspire_common:MediaType>application/pdf</inspire_common:MediaType>
-        </inspire_common:ResourceLocator>
+      <inspire_common:Specification>
+        <inspire_common:Title>-</inspire_common:Title>
+        <inspire_common:DateOfLastRevision>2011-09-19</inspire_common:DateOfLastRevision>
-      <inspire_common:Degree>conformant</inspire_common:Degree>
+      <inspire_common:Degree>notEvaluated</inspire_common:Degree>
       <inspire_common:OrganisationName>mympocname</inspire_common:OrganisationName>
@@ -106,13 +99,6 @@
     <inspire_common:MandatoryKeyword xsi:type='inspire_common:classificationOfSpatialDataService'>
       <inspire_common:KeywordValue>infoMapAccessService</inspire_common:KeywordValue>
     </inspire_common:MandatoryKeyword>
-    <inspire_common:Keyword xsi:type="inspire_common:inspireTheme_eng">
-      <inspire_common:OriginatingControlledVocabulary>
-        <inspire_common:Title>GEMET - INSPIRE themes</inspire_common:Title>
-        <inspire_common:DateOfPublication>2008-06-01</inspire_common:DateOfPublication>
-      </inspire_common:OriginatingControlledVocabulary>
-      <inspire_common:KeywordValue>Transport networks</inspire_common:KeywordValue>
-    </inspire_common:Keyword>
     <inspire_common:SupportedLanguages>
       <inspire_common:DefaultLanguage><inspire_common:Language>eng</inspire_common:Language></inspire_common:DefaultLanguage>
       <inspire_common:SupportedLanguage><inspire_common:Language>ger</inspire_common:Language></inspire_common:SupportedLanguage>
Modified: sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario2_cap130_eng.xml
--- sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario2_cap130_eng.xml	2011-07-19 12:53:49 UTC (rev 11959)
+++ sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario2_cap130_eng.xml	2011-07-19 16:00:35 UTC (rev 11960)
@@ -49,8 +49,6 @@
@@ -86,16 +84,11 @@
@@ -106,13 +99,6 @@
Modified: sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario2_cap130_ger.xml
--- sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario2_cap130_ger.xml	2011-07-19 12:53:49 UTC (rev 11959)
+++ sandbox/inspire_soc2011/msautotest/wxs/expected/wms_inspire_scenario2_cap130_ger.xml	2011-07-19 16:00:35 UTC (rev 11960)
@@ -49,8 +49,6 @@
@@ -86,16 +84,11 @@
@@ -106,13 +99,6 @@
-    <inspire_common:Keyword xsi:type="inspire_common:inspireTheme_ger">
-      <inspire_common:KeywordValue>Verkehrsnetze</inspire_common:KeywordValue>
Modified: sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario2.map
--- sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario2.map	2011-07-19 12:53:49 UTC (rev 11959)
+++ sandbox/inspire_soc2011/msautotest/wxs/wms_inspire_scenario2.map	2011-07-19 16:00:35 UTC (rev 11960)
@@ -37,7 +37,6 @@
   "wms_inspire_capabilities" "embed"                                            #enables inspire using scenario 2
