[mapserver-commits] r11127 - trunk/mapserver
Wed Mar 9 14:05:25 EST 2011
Author: assefa
Date: 2011-03-09 11:05:25 -0800 (Wed, 09 Mar 2011)
New Revision: 11127
   trunk/mapserver/Makefile.vc
   trunk/mapserver/mapdraw.c
   trunk/mapserver/maperror.c
   trunk/mapserver/mapoutput.c
   trunk/mapserver/mapserver.h
remove swf references #3721
Modified: trunk/mapserver/Makefile.vc
--- trunk/mapserver/Makefile.vc	2011-03-09 05:29:39 UTC (rev 11126)
+++ trunk/mapserver/Makefile.vc	2011-03-09 19:05:25 UTC (rev 11127)
@@ -34,7 +34,7 @@
 		mapraster.obj cgiutil.obj mapsde.obj mapogr.obj maptime.obj \
 		maptemplate.obj mappostgis.obj maplayer.obj mapresample.obj \
 		mapwms.obj mapwmslayer.obj mapgml.obj maporaclespatial.obj \
-		mapprojhack.obj mapdraw.obj mapgd.obj mapoutput.obj mapswf.obj \
+		mapprojhack.obj mapdraw.obj mapgd.obj mapoutput.obj \
 		mapgdal.obj mapwfs.obj mapwfs11.obj mapwfslayer.obj mapows.obj maphttp.obj \
 		mapcontext.obj mapdrawgdal.obj mapjoin.obj mapgraticule.obj \
 		mapmygis.obj mapimagemap.obj mapcopy.obj maprasterquery.obj \
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c	2011-03-09 05:29:39 UTC (rev 11126)
+++ trunk/mapserver/mapdraw.c	2011-03-09 19:05:25 UTC (rev 11127)
@@ -172,14 +172,6 @@
         image = msImageCreate(map->width, map->height, map->outputformat,
                               map->web.imagepath, map->web.imageurl, map->resolution, map->defresolution, &map->imagecolor);
-#ifdef USE_MING_FLASH
-    else if( MS_RENDERER_SWF(map->outputformat) )
-        image = msImageCreateSWF(map->width, map->height, map->outputformat,
-                                 map->web.imagepath, map->web.imageurl,
-                                 map->resolution, map->defresolution);
-#endif
     else
         image = NULL;
@@ -394,10 +386,6 @@
 #ifdef USE_WMS_LYR
         if(MS_RENDERER_PLUGIN(image->format) || MS_RENDERER_RAWDATA(image->format))
           status = msDrawWMSLayerLow(map->layerorder[i], pasOWSReqInfo, numOWSRequests,  map, lp, image);
-        else if(MS_RENDERER_SWF(image->format))
-          status = msDrawWMSLayerSWF(map->layerorder[i], pasOWSReqInfo, numOWSRequests, map, lp, image);
-#endif
         else {
           msSetError(MS_WMSCONNERR, "Output format '%s' doesn't support WMS layers.", "msDrawMap()", image->format->name);
           status = MS_FAILURE;
@@ -510,10 +498,6 @@
 #ifdef USE_WMS_LYR
-      else if(MS_RENDERER_SWF(image->format) )
-#endif
 #else
@@ -789,22 +773,7 @@
   int *classgroup = NULL;
   double minfeaturesize = -1;
-/*      For Flash, we use a metadata called SWFOUTPUT that              */
-/*      is used to render vector layers as rasters. It is also true     */
-/*      if  the output movie  format indicated in the map file is       */
-/*      SINGLE.                                                         */
-  if(image &&  MS_RENDERER_SWF(image->format))
-    if ((msLookupHashTable(&(layer->metadata), "SWFOUTPUT") &&
-        strcasecmp(msLookupHashTable(&(layer->metadata), "SWFOUTPUT"),"RASTER")==0) ||
-        strcasecmp(msGetOutputFormatOption(image->format,"OUTPUT_MOVIE", ""),
-                   "MULTIPLE") != 0)
-    return msDrawVectorLayerAsRasterSWF(map, layer, image);
-#endif
   //TODO TBT: draw as raster layer in vector renderers
@@ -822,14 +791,6 @@
   if(status != MS_SUCCESS) return MS_FAILURE;
   /* build item list */
-/*      For Flash, we use a metadata called SWFDUMPATTRIBUTES that      */
-/*      contains a list of attributes that we want to write to the      */
-/*      flash movie for query purpose.                                  */
-    status = msLayerWhichItems(layer, MS_FALSE, msLookupHashTable(&(layer->metadata), "SWFDUMPATTRIBUTES"));
-  else
     status = msLayerWhichItems(layer, MS_FALSE, NULL);
   if(status != MS_SUCCESS) {
@@ -1295,10 +1256,6 @@
         else if( MS_RENDERER_RAWDATA(image->format) )
             return msDrawRasterLayerLow(map, layer, image, NULL);
-        else if( MS_RENDERER_SWF(image->format) )
-            return  msDrawRasterLayerSWF(map, layer, image);
-#endif
     return MS_FAILURE;
@@ -1346,11 +1303,6 @@
             nStatus = msDrawWMSLayerLow(1, asReqInfo, numReq,
                                         map, layer, image) ;
-            nStatus = msDrawWMSLayerSWF(1, asReqInfo, numReq,
-                                        map, layer, image);
-#endif
         else
@@ -2280,16 +2232,7 @@
   if(!string) return MS_SUCCESS; /* not an error, just don't need to do anything more */
   if(strlen(string) == 0) return MS_SUCCESS; /* not an error, just don't need to do anything more */
-  /*      TODO : This is a temporary hack to call the drawlableswf directly. */
-  /*      Normally the only functions that should be wrapped here is         */
-  /*      draw_text. We did this since msGetLabelSize has not yet been       */
-  /*      implemented for MING FDB fonts.                                    */
-  if ( MS_RENDERER_SWF(image->format) )
-    return msDrawLabelSWF(image, labelPnt, string, label, &(map->fontset), scalefactor);
-#endif
   if(label->type == MS_TRUETYPE) {
     size = label->size * scalefactor;
@@ -2646,10 +2589,7 @@
       return MS_SUCCESS; /* necessary? */
     } else if( MS_RENDERER_IMAGEMAP(image->format) )
       nReturnVal = msDrawLabelCacheIM(image, map);
-      nReturnVal = msDrawLabelCacheSWF(image, map);
-#endif
   return nReturnVal;
@@ -2685,10 +2625,7 @@
             msImageStartLayerIM(map, layer, image);
-            msImageStartLayerSWF(map, layer, image);
-#endif
@@ -2722,10 +2659,7 @@
 		  if (image->format->vtable->startShape)
 			image->format->vtable->startShape(image, shape);
-            msDrawStartShapeSWF(map, layer, image, shape);
-#endif
Modified: trunk/mapserver/maperror.c
--- trunk/mapserver/maperror.c	2011-03-09 05:29:39 UTC (rev 11126)
+++ trunk/mapserver/maperror.c	2011-03-09 19:05:25 UTC (rev 11127)
@@ -511,10 +511,6 @@
 #ifdef USE_PDF
   strcat(version, " OUTPUT=PDF");
 #endif
-  strcat(version, " OUTPUT=SWF");
-#endif
-  strcat(version, " OUTPUT=SVG");
 #ifdef USE_KML
   strcat(version, " OUTPUT=KML");
 #endif
Modified: trunk/mapserver/mapoutput.c
--- trunk/mapserver/mapoutput.c	2011-03-09 05:29:39 UTC (rev 11126)
+++ trunk/mapserver/mapoutput.c	2011-03-09 19:05:25 UTC (rev 11127)
@@ -268,17 +268,8 @@
 #endif
-    if( strcasecmp(driver,"swf") == 0 )
-        format = msAllocOutputFormat( map, "swf", driver );
-        format->mimetype = msStrdup("application/x-shockwave-flash");
-        format->imagemode = MS_IMAGEMODE_PC256;
-        format->extension = msStrdup("swf");
-        format->renderer = MS_RENDER_WITH_SWF;
-#endif
 #ifdef USE_GDAL
     if( strncasecmp(driver,"gdal/",5) == 0 )
@@ -363,9 +354,7 @@
     if( msSelectOutputFormat( map, "jpeg" ) == NULL )
         msCreateDefaultOutputFormat( map, "AGG/JPEG" );
-    if( msSelectOutputFormat( map, "swf" ) == NULL )
-        msCreateDefaultOutputFormat( map, "swf" );
     if( msSelectOutputFormat( map, "imagemap" ) == NULL )
         msCreateDefaultOutputFormat( map, "imagemap" );
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2011-03-09 05:29:39 UTC (rev 11126)
+++ trunk/mapserver/mapserver.h	2011-03-09 19:05:25 UTC (rev 11127)
@@ -1601,9 +1601,6 @@
 #ifndef SWIG
   union {
     void *plugin;
-    void *swf;
-#endif
     char *imagemap;
     short *raw_16bit;
@@ -2446,35 +2443,8 @@
 MS_DLL_EXPORT int msHexDecode(const char *in, unsigned char *out, int numchars);
-/*      prototypes for functions in mapswf.c                            */
-MS_DLL_EXPORT imageObj *msImageCreateSWF(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, double resolution, double defresolution);
-MS_DLL_EXPORT void msImageStartLayerSWF(mapObj *map, layerObj *layer, imageObj *image);
-MS_DLL_EXPORT int msDrawLabelSWF(imageObj *image, pointObj labelPnt, char *string, labelObj *label, fontSetObj *fontset, double scalefactor);
-MS_DLL_EXPORT int msDrawLabelCacheSWF(imageObj *image, mapObj *map);
-MS_DLL_EXPORT void msDrawLineSymbolSWF(symbolSetObj *symbolset, imageObj *image, shapeObj *p, styleObj *style, double scalefactor);
-MS_DLL_EXPORT void msDrawShadeSymbolSWF(symbolSetObj *symbolset, imageObj *image, shapeObj *p, styleObj *style, double scalefactor);
-MS_DLL_EXPORT void msDrawMarkerSymbolSWF(symbolSetObj *symbolset, imageObj *image, pointObj *p, styleObj *style, double scalefactor);
-MS_DLL_EXPORT int msDrawRasterLayerSWF(mapObj *map, layerObj *layer, imageObj *image);
-MS_DLL_EXPORT int msDrawVectorLayerAsRasterSWF(mapObj *map, layerObj *layer, imageObj*image);
-#ifdef USE_WMS_LYR
-MS_DLL_EXPORT int msDrawWMSLayerSWF(int nLayerId, httpRequestObj *pasReqInfo, int numRequests, mapObj *map,
-                                   layerObj *layer, imageObj *image);
-#endif
-MS_DLL_EXPORT void msTransformShapeSWF(shapeObj *shape, rectObj extent, double cellsize);
-MS_DLL_EXPORT int msSaveImageSWF(imageObj *image, char *filename);
-MS_DLL_EXPORT void msFreeImageSWF(imageObj *image);
-MS_DLL_EXPORT int draw_textSWF(imageObj *image, pointObj labelPnt, char *string, labelObj *label, fontSetObj *fontset, double scalefactor);
-MS_DLL_EXPORT void msDrawStartShapeSWF(mapObj *map, layerObj *layer, imageObj *image, shapeObj *shape);
-#endif /* USE_MING_FLASH */
-/*      End of prototypes for functions in mapswf.c                     */
 /*      prototypes for functions in mapgeomtransform.c                  */
 enum MS_GEOMTRANSFORM_TYPE {
