[mapserver-commits] r11128 - trunk/mapserver
Wed Mar 9 15:38:48 EST 2011
Author: dmorissette
Date: 2011-03-09 12:38:48 -0800 (Wed, 09 Mar 2011)
New Revision: 11128
   trunk/mapserver/mapdebug.c
   trunk/mapserver/maperror.h
   trunk/mapserver/mapobject.c
   trunk/mapserver/shp2img.c
   trunk/mapserver/sortshp.c
Support for MS_ERRORFILE relative to mapfile path (#2853)
Modified: trunk/mapserver/mapdebug.c
--- trunk/mapserver/mapdebug.c	2011-03-09 19:05:25 UTC (rev 11127)
+++ trunk/mapserver/mapdebug.c	2011-03-09 20:38:48 UTC (rev 11128)
@@ -129,12 +129,27 @@
 ** Set output target, ready to write to it, open file if necessary
+** If pszRelToPath != NULL then we will try to make the value relative to
+** this path if it is not absolute already and it's not one of the special
+** values (stderr, stdout, windowsdebug)
 ** Returns MS_SUCCESS/MS_FAILURE
-int msSetErrorFile(const char *pszErrorFile)
+int msSetErrorFile(const char *pszErrorFile, const char *pszRelToPath)
+    char extended_path[MS_MAXPATHLEN];
     debugInfoObj *debuginfo = msGetDebugInfoObj();
+    if (strcmp(pszErrorFile, "stderr") != 0 &&
+        strcmp(pszErrorFile, "stdout") != 0 &&
+        strcmp(pszErrorFile, "windowsdebug") != 0)
+        /* Try to make the path relative */
+        if(msBuildPath(extended_path, pszRelToPath, pszErrorFile) == NULL)
+            return MS_FAILURE;
+        pszErrorFile = extended_path;
     if (debuginfo && debuginfo->errorfile && pszErrorFile &&
         strcmp(debuginfo->errorfile, pszErrorFile) == 0)
@@ -271,7 +286,7 @@
     if( (val=getenv( "MS_ERRORFILE" )) != NULL )
-        if ( msSetErrorFile(val) != MS_SUCCESS )
+        if ( msSetErrorFile(val, NULL) != MS_SUCCESS )
             return MS_FAILURE;
Modified: trunk/mapserver/maperror.h
--- trunk/mapserver/maperror.h	2011-03-09 19:05:25 UTC (rev 11127)
+++ trunk/mapserver/maperror.h	2011-03-09 20:38:48 UTC (rev 11128)
@@ -159,7 +159,7 @@
 MS_DLL_EXPORT void msDebug( const char * pszFormat, ... );
-MS_DLL_EXPORT int msSetErrorFile(const char *pszErrorFile);
+MS_DLL_EXPORT int msSetErrorFile(const char *pszErrorFile, const char *pszRelToPath);
 MS_DLL_EXPORT void msCloseErrorFile( void );
 MS_DLL_EXPORT const char *msGetErrorFile( void );
 MS_DLL_EXPORT void msSetGlobalDebugLevel(int level);
Modified: trunk/mapserver/mapobject.c
--- trunk/mapserver/mapobject.c	2011-03-09 19:05:25 UTC (rev 11127)
+++ trunk/mapserver/mapobject.c	2011-03-09 20:38:48 UTC (rev 11128)
@@ -191,10 +191,12 @@
     /* Same for MS_ERRORFILE, we want it to kick in as early as possible
-     * to catch parsing errors */
+     * to catch parsing errors.
+     * Value can be relative to mapfile, unless it's already absolute
     if( strcasecmp(key,"MS_ERRORFILE") == 0 )
-        if (msSetErrorFile( value ) != MS_SUCCESS)
+        if (msSetErrorFile( value, map->mappath ) != MS_SUCCESS)
             return MS_FAILURE;
@@ -245,7 +247,7 @@
         else if( strcasecmp(key,"MS_ERRORFILE") == 0 )
-            msSetErrorFile( value );
+            msSetErrorFile( value, map->mappath );
         else
Modified: trunk/mapserver/shp2img.c
--- trunk/mapserver/shp2img.c	2011-03-09 19:05:25 UTC (rev 11127)
+++ trunk/mapserver/shp2img.c	2011-03-09 20:38:48 UTC (rev 11128)
@@ -64,7 +64,7 @@
         /* Send output to stderr by default */
         if (msGetErrorFile() == NULL)
-            msSetErrorFile("stderr");
+            msSetErrorFile("stderr", NULL);
         continue;
@@ -213,7 +213,7 @@
     if(strcmp(argv[i], "-layer_debug") == 0) /* debug */
@@ -235,7 +235,7 @@
     if(strcmp(argv[i],"-e") == 0) { /* change extent */
Modified: trunk/mapserver/sortshp.c
--- trunk/mapserver/sortshp.c	2011-03-09 19:05:25 UTC (rev 11127)
+++ trunk/mapserver/sortshp.c	2011-03-09 20:38:48 UTC (rev 11128)
@@ -104,7 +104,7 @@
       exit(0);
   /*       Open the shapefile                                                        */
