[mapserver-commits] r11129 - trunk/mapserver
Wed Mar 9 16:08:07 EST 2011
Author: dmorissette
Date: 2011-03-09 13:08:07 -0800 (Wed, 09 Mar 2011)
New Revision: 11129
   trunk/mapserver/MIGRATION_GUIDE.TXT
Fix typo, + add mention of deprecated Flash/SWF and MyGIS
Modified: trunk/mapserver/MIGRATION_GUIDE.TXT
--- trunk/mapserver/MIGRATION_GUIDE.TXT	2011-03-09 20:38:48 UTC (rev 11128)
+++ trunk/mapserver/MIGRATION_GUIDE.TXT	2011-03-09 21:08:07 UTC (rev 11129)
@@ -193,7 +193,7 @@
 The OUTPUTFORMAT parameter validation when reading from the mapfile
 will now trigger an error on some problems that in the past were
 silently fixed up.  For instance using RGBA IMAGEMODE with JPEG format
-not triggers an error instead of switching to IMAGEMODE RGB silently.
+now triggers an error instead of switching to IMAGEMODE RGB silently.
 Rasters
@@ -204,7 +204,20 @@
   the GDAL library.
 * The above change also means there is no longer support for EPPL raster layers.
+Deprecated features
+- Support for Flash/SWF output has been removed as part of the rendering overhaul
+  because it was no longer compatible with the new architecture.
+  Support for Flash/SWF could be reintroduced but would require a nono trivial
+  amount of work (i.e. would require funding).
+- Support for "CONNECTIONTYPE MyGIS" has been dropped since it was no longer
+  being maintained and there are better ways to use MySQL data sources theses
+  days, going through OGR for instance.
 MapServer 5.4 to 5.6 Migration Guide
